This is a discussion on any market for a subwoofer enclosure? within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by hyo silver Have you any idea how much effort goes into making fibreglass parts light ? OK, ...
Old 05-25-2009, 11:39 AM   #21
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
Default Re: any market for a subwoofer enclosure?
Originally Posted by hyo silver View Post
Have you any idea how much effort goes into making fibreglass parts light? OK, so I won't be using any vacuum-bagging and excess resin extraction techniques.
MDF for the front face, at least, seems standard practice, though it sounds like I should incorporate more of it on the other surfaces, within the layers of glass. And maybe a short section of large diameter PVC pipe...
We're not going for light here buddy. We're going for strength!
Yes, use wood were possible and connect the sections with fiberglass. No PVC needed, we are not building a ported box. That would require more air space.
F8L is offline
Old 05-25-2009, 04:17 PM   #22
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
This is starting to sound more like a woodwork project and less like a fibreglass project.
In fact, if I can get flat panels of 1" MDF in there, I may not need fibreglass at all. It's not needed for making the joints airtight, and the box doesn't need to be waterproof. Hmmm. Time to play with some cardboard.
hyo silver is offline
Old 05-25-2009, 04:35 PM   #23
Gadgetdad
Gadgetdad's Avatar
Package: Premium w/ Solar Cells - CA
I'd be interested for my '10 if it fits. I'm not into replacing everything else too just to power the sub. Is there an uncomplicated way to "tap" existing amp to run one?
Lee
Gadgetdad is offline
Old 05-25-2009, 05:38 PM   #24
F8L
F8L's Avatar
Friends: 35
LOL you are cracking me up my friend.
3/4" MDF is more than enough for our baby subs. I'm sure you'll use fiberglass as well as wood. it would be much easier to fill in the large gaps between the wood AND you can eek out more air space that way.
F8L is offline
Old 05-25-2009, 06:17 PM   #25
F8L
F8L's Avatar
Friends: 35
Lee
You can easily "tap" into the existing system to feed a signal to the new subwoofer amplifier.
F8L is offline
Old 05-25-2009, 08:47 PM   #26
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Originally Posted by F8L View Post
...With our heavy duty subs we require 1" MDF for box construction. The thing needs to sound "dead". Like the different between knocking on sheet of tin or a sheet of 2" steel.
Well, we could use 2" steel plate. I think jayman has some extra lying around, and apparently he loves to play with a cutting torch.
But then, I won't be mailing any of these things anywhere, and it would only cut down on the interior volume of the enclosure, which I gather is on the low end of the scale as it is. And MDF's not the densest of woods - maybe I can scrounge up some Lignum Vitae or Ebony.
Heck, I could even try casting some out of concrete, but then we'd have to put one on each side to balance the car. Unless of course I installed an airbag suspension, which has other advantages, but that's maybe getting a little carried away.
My other high mileage, low emission vehicles are my bicycles and my shoes.
Old 05-26-2009, 04:39 PM   #27
PriusLewis
Management Scientist
PriusLewis's Avatar
Friends: 5
I'd go with forged Titanium, chemically machined to fit. Shouldn't cost more than $100K or so. As for concrete vs steel, during WW II they made boats from concrete that were lighter and stronger than steel. I always wondered how they kept them from leaking, considering every basement I've seen LOL.
PriusLewis is offline
Old 05-28-2009, 01:49 PM   #28
ashe
ashe's Avatar
interesting read. i'm having a fiberglass sub enclosure made for the passenger side cubby in the hatch. hopefully i'll be able to post some pics this weekend in a new thread.
ashe is offline
Old 05-28-2009, 11:16 PM   #29
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Let us know how it turns out.
And how much it costs.
Old 05-29-2009, 12:43 PM   #30
Yont283
i would be interested if the price was not to much.... do you have a price range?
Yont283 is offline
enclosure, market, subwoofer
subwoofer wbredin Gen II Prius Audio and Electronics 5 03-25-2008 10:19 AM
Custom subwoofer enclosure for 04 and 05 Prius viffer_pilot Gen II Prius Audio and Electronics 49 04-14-2007 02:57 PM
My Subwoofer Mod! GreenSpeed Gen II Prius Modifications 2 08-15-2006 06:36 PM
My Subwoofer Mod! GreenSpeed Gen II Prius Modifications 0 08-11-2006 02:27 AM
Ok, so how would i add a subwoofer plus amp? Kev1000000 Gen II Prius Audio and Electronics 18 11-11-2004 04:32 PM
