This is a discussion on jl audio FlatWedge™ Low-Profile Ported System within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by sacrefrancais Actually, I misspoke. The remote is for the AMP, not the sub. I'd post the link ...
Old 11-04-2009, 11:23 AM   #21
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
Default Re: jl audio FlatWedge™ Low-Profile Ported System
Originally Posted by sacrefrancais View Post
Actually, I misspoke. The remote is for the AMP, not the sub. I'd post the link but I'm under 5 posts so don't have that privilege yet. It's the Rockford Fosgate PEQ Remote Punch EQ though.
Says it acts as a treble or bass BOOST. I'd think I could lower the gain on the sub channels 3 and 4 to bring bass levels to the low end and then use the "boost" to increase the bass as needed. Is this still sounding on track?
I know what the PEQ is and unfortunately it works as a "bass boost" and this is different than a bass level control. A bass boost often has a center frequency as a peak instead of just increasing the entire frequency spectrum like a level or gain control would. The PEQ would definately allow you to lower or raise the volume of the subwoofer but it is centered at 45Hz (pretty darn low) and may have less of an effect at 80Hz. It really depends on the system setup so if you could get the shop to let you test it out in your system that would be great. Since it is an easy plug in that should not be too troublesome for them.
F8L is online now
Old 11-04-2009, 12:24 PM   #22
nspeer
Originally Posted by F8L View Post
Neil, I looked up your amplifier and it doesn't appear to have an option for a remote bass control. You may have to look into another option or go with a 4 channel line converter.
DOH! OK, so be it.
thanks for all your help!
Neil
nspeer is offline
Old 11-04-2009, 12:39 PM   #23
sacrefrancais
I found the RF bass boost remote for $25 on Amazon, so it looks like there will be some trial and error to see if I can find a decent range of control with it. It says 0dB to +18dB boost @ 45Hz. Otherwise I'll probably go the converter route. Thanks again.
sacrefrancais is offline
Old 11-04-2009, 03:14 PM   #24
sacrefrancais
Ok last question. I'm not sure if my amp has the best settings. I know trial and error is a good way to go, but what are your thoughts on these current settings:
Front channels (speakers) - All Pass, Freq. is 155 Hz. Gain is at about 5. Punch EQ set to 0.
Rear (sub) - Low Pass, Freq is 55 Hz, Gain 5, and Punch EQ about halfway.
I guess it's the frequencies I'm most clueless about. Any suggestions?
Old 11-04-2009, 03:30 PM   #25
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
...The only drawback is having to mount the knob somewhere. I'm lazy and mine is still sitting in my cupholder. Uhhhggg
The rest of your install is so clean, I thought you would have rewired one of the existing control knobs from the old system. I especially like the deck hiding in the little cubby. And you're being very helpful - you could have said the problem with the bass was that the system's about 1000 watts short.
hyo silver is offline
Old 11-04-2009, 06:19 PM   #26
F8L
F8L's Avatar
Friends: 35
I bet with a bit of tinkering you can find a happy medium between lowering the gain crontrol on the amp and using the bass knob to add more when needed. It may not be perfect but if you like it then that is all that matters right?
F8L is online now
Old 11-04-2009, 06:31 PM   #27
F8L
F8L's Avatar
Friends: 35
This is all very subjective but I'll give it my best shot without actually listening to the system.
  • The high pass frequency may be a tad bit too high. If it is fully variable try listening to bass heavy music or something with a lot of midbass in it (kick drums and bass guitar work too). Then work down to a lower frequency and see if you like it.
  • I generally try and xover subs at closer to 80Hz and then work my way down. 55Hz seems a tad low to me, especially for such a small sub.
  1. For gain settings:
  2. For best sound quality and amplifier efficiency I would start with the gains set at minimum.
  3. Play a quality recorded CD that is fairly dynamic (a lot of highs and lows coming in fast and hard. Modern Jazz works well).
  4. Turn the volume on the deck up to about 3/4 full volume and then starting turning up the gains on the amp till you start to hear distortion in the speakers. Turn the gain back down just a tad and leave it there. This should represent the highest you will ever listen to the system and it will reduce the likelyhood of damaging anything and you now have the highest signal possible coming out of the deck with a minimal amount of distortion or induced signal noise going to the amplifier.
  5. Do the same thing for the subwoofer gain control but this can be modified if you don't like the bass so loud.
If your rear speakers are run off of the stock deck then 3/4 volume might not work so just keep turning up the volume till you hear the rear speakers distort (while the amp gains are still at minimum) then back the volume down a tad and start adjusting the gains on the amplifier as described above.
This is the quick and dirty way to set an amp up without having to go through all the signal matching stuff or using other devices. It works in a lot of situations.
F8L is online now
Old 11-04-2009, 06:33 PM   #28
F8L
F8L's Avatar
Friends: 35
Well yeah, 1,000+ watts short and missing a few more 8" subs but hey if they don't like the feeling of someone kicking you in the back everytime the bass hits then maybe my setup is overkill for them. lol
BTW, I added all my music back onto the flashdrive and I wish you could have listened to all of my reference music. It sounds so much better than the stuff we listened to. Plus I had the not-so-good- subwoofers in due to blowing up the really good 10" subs.
F8L is online now
Old 11-04-2009, 08:48 PM   #29
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
...BTW, I added all my music back onto the flashdrive and I wish you could have listened to all of my reference music. It sounds so much better than the stuff we listened to. Plus I had the not-so-good- subwoofers in due to blowing up the really good 10" subs.
Reference music, like the clip from Jurassic Park? That reminded me of the lyrics from 'Who Are You': "And the breeze blew back my hair." That's what the dinosaur belch felt like. And those weren't even the good subs?!
Old 11-04-2009, 08:50 PM   #30
don_chuwish
Originally Posted by nspeer View Post
I ended up getting one also and have been listening to it for only a few days. I was disappointed that it is just a hair to deep to fit in the spare tire compartment next to my Alpine 4 channel amp., even with the speaker grill removed. So, it now sits on the carpeted rear deck, which is no biggie.
Really? I have one too. I haven't installed it yet because I'm still working out the other details of my upgrade. But I did put it in the cargo box above the spare tire to see how it fit. With the grill off I found that the lid will just barely clear it. But I didn't want to leave it without the grill, so I'm actually building a replacement lid. Then I'll make an 8" hole just over the speaker, cover the hole with a flush grill and cover everything with carpet. This is as far as I've gotten:
Glad to see others have it and like the sound. I'm dying to try mine out!
- D
2007 Pkg #2
Tinted, custom wheels, PIAA fogs
Last edited by don_chuwish; 11-05-2009 at 02:28 PM. Reason: "dying to dry" ?! -> "dying to try" !!
don_chuwish is online now
audio, flatwedge™, lowprofile, ported, system
Audio System modifications thomcg Gen II Prius Modifications 3 11-04-2008 01:40 PM
Audio system completely DOWN!!!!! ningah Gen II Prius Audio and Electronics 9 10-31-2008 11:13 PM
tv and audio system cvorias Gen II Prius Main Forum 0 02-20-2006 10:33 PM
Audio system RichardBarth Gen II Prius Main Forum 7 10-16-2005 08:45 AM
New Audio System XravenX Gen II Prius Audio and Electronics 9 03-10-2005 12:59 PM
