| This is a discussion on Day Mode touch button GONE! within the Gen II Prius Audio and Electronics forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ok, I don't know if she had the headlights on...I suspect not since is was daylight when she troubleshot it ... |
| | #11 |
| Junior Member Join Date: Jan 2007 Location: DFW, Texas
My Car: 2007 Prius Model: N/A Package: #5 Touring Thanks: 0
Friends: 0 | Ok, I don't know if she had the headlights on...I suspect not since is was daylight when she troubleshot it for me. I will check...thanks, Mel |
| | #12 |
| Junior Member Join Date: Jun 2009 Location: San Diego
My Car: 2008 Prius Model: N/A Package: #8 Thanks: 0
Friends: 0 | Here's one thing you can check. When I had originally picked up my Prius from the dealer, they had taken part of the dash apart to program the alarm or something. On re-assembly, they forgot to plug the harness into the dimmer switch which caused it to go into permanent day mode. It sounds like what you are experiencing. Joe |
| | #13 |
Friends: 0 | guess I could check that but they only removed and replaced the rear bumper and pad...if they had the dash apart, they were trespassing! |
| | #14 |
Friends: 0 | You were absolutely correct. I turned on the headlights with the dimmer control out of the detent and there was the button. Can't believe you take you car in for service and they play with everything! Thought I had a full understanding of the car and its operation. Learned one today! Thank you so much. Mel |
| | #15 |
| Junior Member Join Date: Mar 2007 Location: Beverly Hills, CA
My Car: 2007 Prius Model: Package: #6 Touring Thanks: 1
Friends: 0 | Txav8r - the exact same thing happened to me last night, so I did a search and found this thread. I'll try the same things you did and see if I can fix it. And I just had service 2 days ago, so I assumed they did something to my car. Very annoying! |
| button, day, mode, touch |
| Which wire is for the mode button on the steering wheel??? | whiterice42019 | Gen II Prius Modifications | 5 | 09-25-2008 11:03 PM |
| 06-07 EV Mode Button Connector Pins? | ericprius | Gen II Prius Modifications | 2 | 01-26-2008 11:47 PM |
| EV mode without the button? | psikot | Gen II Prius Main Forum | 3 | 10-17-2007 09:12 AM |
| Mode Button | bredekamp | Gen II Prius Main Forum | 6 | 05-01-2007 06:29 PM |
| EV mode without the button? | psikot | Gen II Prius Fuel Economy | 0 | 12-31-1969 07:00 PM |
