This is a discussion on Unacceptable Service at Sierra Toyota, Antelope Valley, CA within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 1. The service manager told my wife they were going to drain and replace the 'transmission fluid' in our 2005 ...
Old 08-01-2005, 05:41 PM   #1
K6YXH
Default Unacceptable Service at Sierra Toyota, Antelope Valley, CA
1. The service manager told my wife they were going to drain and replace the 'transmission fluid' in our 2005 Prius at 14,000 miles; she told them it didn't have a 'transmission' but rather a power splitting device - he insisted that it did have a transmission, and that she just wasn't feeling it shift. Fortunately, he read the service manual before changing the fluid, which is due to be changed at 100,000 miles!!!
2. We were charged for "battery pads" - what battery pads?! I've removed and replaced the battery terminals on the 12V battery, and there were no battery pads. The battery is in a compartment that doesn't get dirty. I think we were charged for components and labor that they did not perform.
3. They charged us for oil and gasoline additives, about $5 for each. We had the oil changed 3 weeks earlier, and instructed the dealer not to perform an oil change. The oil level was precisely at the same level after their service. I think we were charged for an unnecessary oil additive, and I doubt that they actually added anything - the oil level was right on the mark, no change. Even adding a pint of additive would have caused a change.
4. I do not believe that they needed to add anything to the gasoline. Again, a $5 charge for something not required.
5. They rotated the tires and deflated the tires from the pressure I had; I don't mind them deflating the tires to a recommended level, but they had the rear tires 3 to 4 pounds higher than the front; the right side differed by 4 pounds, and the left by 3. I know the recommended difference is 2 pounds, and the front should be higher - either they don't know, or are just sloppy. I measured the pressure cold and I am meticulous about my tire pressure, noticing significant differences in mileage with pressure changes. I am apalled that something this simple has escaped the service techs.
6. They adjusted the emergency break so that it's much harder to push than it was when the car was new. Also, after driving around the block, not pushing at all on the breaks, the rear drums were hot to the touch - an indication to me that the pads are rubbing - that hurts mileage and can be dangerous.
I would bring the car back to have them ease up on the tightness of the rear breaks, but I have no confidence whatsoever in their service department. It's as if they had never heard of a Prius and had no idea how to service it.
K6YXH is offline
Old 08-01-2005, 05:57 PM   #2
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
What did you take the car in for if you just had it serviced three weeks earlier?
Sounds as if you may need to contact the State of California Department of Consumer Affairs Bureau of Automotive Repair.
IsrAmeriPrius is offline
Old 08-01-2005, 06:01 PM   #3
IsrAmeriPrius
Progressive Member
P.S. Here is their Consumer On-line Complaint Form.
Old 08-02-2005, 12:11 AM   #4
K6YXH
Default Re: Unacceptable Service at Sierra Toyota, Antelope Valley,
We had the oil changed 3 weeks earlier, and the garage didn't reset the "Maintenance Required" circuit - when I noticed that I was almost ready for the 15,000 mile service, I decided to have Toyota do the 15,000 mile service already, minus the oil change - just rotate the tires and inspect.
K6YXH is offline
Old 08-03-2005, 10:44 AM   #5
DanMan32
For most of its life under 100K, all the car needs is oil/filter, tire rotation every 5K, and air filters (ICE and cabin) at 30K. Rest is inspection. Personally, I would't touch the brakes unless one felt or heard a problem.
I would certainly complain to the service manager and the general manager, possibly also the owner. I certainly would never go there again. Except for not understanding the transmission, the rest of the work is not any different than any other car.
As for the transmission fluid, there is no replacement specification. It does say to inspect at 60K I believe. It is a long life ATF, and the PSD doesn't do much with the fluid other than lubricate and cool. It replaces much like a manual transmission. Drain plug on the bottom, fill plug on the side.
DanMan32 is offline
Old 08-04-2005, 01:32 AM   #6
K6YXH
I complained to Toyota, and they evidently called the dealer; I had a call this morning from the Customer Satisfaction person at the dealer, but couldn't take the call as I was in a meeting at work. I'll call them tomorrow and sort it out.
I really didn't want to resolve this by just going back to the service manager, or even the dealership manager or owner - I wanted Toyota to know they had a problem, so they could solve it at an appropriate level.
K6YXH is offline
Interest in a Sierra Trip? bbianchi Local Clubs, Events, and Road Trips 0 12-21-2005 01:32 AM
Valley area service? BatPrius AZ - Phoenix 14 07-28-2005 08:17 PM
GMC Sierra Hybrid Tideland Prius Other Cars 2 01-14-2005 11:23 PM
Sierra Club event Sev CA - San Diego 1 07-12-2004 04:22 PM
Super White BC available at Sierra toyota, SoCal....but Mau28 Dealers & Pricing 1 02-12-2004 01:00 AM
