This is a discussion on temperature voice command don't work within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; HI! I just noticed something in my Prius 2005. When I say "warmer", it gets my command and says "raising ...
Old 10-13-2005, 12:29 AM   #1
aanimate
HI!
I just noticed something in my Prius 2005. When I say "warmer", it gets my command and says "raising temerature" but the temerature numbers on display don't change.
Anybody have the same problem?
Thank you.
aanimate is offline
Old 10-13-2005, 12:44 AM   #2
Wayne
Wayne's Avatar
I'm surprised you get a response of "raising temerature", as "warmer" is not a voice command on my American Prius.
Try using "Raise Temperature".
Wayne is offline
Old 10-13-2005, 01:21 AM   #3
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
It seems to work for me to say something like "Temperature 75 degrees."
aaf709 is offline
Old 10-13-2005, 01:25 AM   #4
Wayne
Wayne's Avatar
[snapback]140380[/snapback]
Yes, that's legitimate too. You should also be able to shortcut that by simply saying "75 degrees".
Wayne is offline
Old 10-13-2005, 02:16 AM   #5
aanimate
[snapback]140366[/snapback]
"Raise Temperature" is recognized also but it doesn't change numbers. Only when I say a specific number then it changes.
So when you say" Raise temperature" does your prius changes temerature numbers on display or only increasing the fan speed?
aanimate is offline
Old 10-13-2005, 02:28 AM   #6
Wayne
Wayne's Avatar
[snapback]140388[/snapback]
I've tested this before, but just confirmed it again -- it raises the temperature in 2 degree increments.
Wayne is offline
Old 10-13-2005, 05:42 AM   #7
mmccking
I concur with Wayne
mmccking is offline
Old 10-13-2005, 02:20 PM   #8
aanimate
Originally posted by mmccking@Oct 13 2005, 04:42 AM
I concur with Wayne
[snapback]140404[/snapback]
I guess something is wrong with my car command.
THank you!
aanimate is offline
Old 10-15-2005, 08:55 AM   #9
djasonw
I can't remember the last time I used the voice commands. They're just a novelty. I press the up temp button and in two seconds, the cabin warms up. Why bother pressing voice command, saying your command and waiting for a response? Only reason would be to impress your friends/relatives. Sometimes I use the SAT commands instead of cycling through them.
djasonw is online now
Old 10-15-2005, 09:00 AM   #10
legendsguy
legendsguy's Avatar
Is this voice command only available on Prius with certain level of options. I haven't seen anything like this on ours. I often say "I love you" but the car never answers back!
legendsguy is offline
Voice Command List Tideland Prius Knowledge Base Articles Discussion 6 09-14-2007 05:40 PM
Voice command prompt janrn Gen II Prius Audio and Electronics 9 04-15-2006 08:40 PM
Use voice command button for EV mod? Marlin Gen II Prius Main Forum 2 02-23-2006 06:45 PM
2006 voice command "AM" does not work. kinged Gen II Prius Care, Maintenance and Troubleshooting 6 01-24-2006 12:59 PM
Voice command list grefos Gen II Prius Audio and Electronics 3 05-12-2004 10:10 PM
