This is a discussion on Melting Brake Light Fins within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I took a close look at my '04 today and noticed that the black "fins" at the top of the ...
Old 10-19-2005, 10:41 PM   #1
BMcGraw
I took a close look at my '04 today and noticed that the black "fins" at the top of the right-rear tail-light assembly were deformed. An apparent result of over heating brake light lamps. I read about this in this very forum about a few months ago but hoped it wouldn't happen to mine. I've only got about 15K miles on it so I'm requesting that others take a close look. If you find a similar problem please respond to this thread. A recall may be "in order". (see photo)
It isn't that obvious so take a good look.
The left one is beginning to warp also but not as badly.
Toyota Corp. is on the alert.
'04 6S9 BC; 18x7" Centerline Vantage silver powdercoat wheels; steering wheel, seat, dash covers; front end mask; mudflaps; side moulding; wood dash trim; fumoto oil valve; halogen 100W fog-DRL conversion; Hella style dual LOUD horns; Italian 139db @ 4ft air horn; window tint; brake light pulser; billet stiffening plate; BLUE undercar neon & in-car LED's total replacement & CCFL lighting; Brian's AeroDam; JVC giga-mp3 DVD player; rear view camera...
BMcGraw is offline
Old 10-19-2005, 10:44 PM   #2
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 26
It's not the brake lights that overheat the plastic. I mean, they're LEDs. It's more of the high heat absorbed from the sun.
Tideland Prius is offline
Old 10-19-2005, 10:53 PM   #3
Bill Merchant
absit invidia
Bill Merchant's Avatar
Friends: 62
Talking
[snapback]143087[/snapback]
Which may be one reason the '06 tail lights are chromed...
Bill Merchant is offline
Old 10-19-2005, 10:54 PM   #4
Frank Hudon
take it to the dealer and tell them to replace it. This is the only way that Toyota will recognise that there is a problem with the tail light design. This has been reported lots of times, mainly from the southern states where the tail light hot soaks from sunlight and the plastic melts. If it partially obscures the brake led's it's time for a new one, as that constitutes a safty hazard.
Frank Hudon is offline
Old 10-19-2005, 10:57 PM   #5
Friends: 41
Definately. This is much more common on cars in hotter/sunnier climates and on cars that are routinely parked outside during the day. My 2 year old Prius shows no sign of warpage but has only spend the day sitting in the hot sun a handful of times over that 2 year period.
Seems to be a combination of the heat absorbing properties of the black fins, maybe some heat intensification by the curved clear lamp (like using a magnifying glass to fry a bug), and probably a little greenhouse effect as well.
Also, you might be wise to wait about 3-4 months to complain, or at least to have the repair done...you may be able to get the new chromed fins instead of more of the same black. It is, of course, possible that Toyota has changed the material used in the early '04 Prii to one that is more heat tolerant. Anyone with an '05 seen this problem?
Evan E. Fusco, MD
efusco is offline
Old 10-20-2005, 09:15 AM   #6
Tempus
Mine started melting a long time ago, but I waited until the Parts Department told me there was a re-designed part available, and I had them replaced about a week ago. The black plastic portion on the new ones does look different. It's unlikely they'll give you an 06 set because I'm sure they made a production change sometime during the 04/05 run and have a black part that doesn't melt.
Another thing to be sure to check on 04s is sagging headliners. Again, it's most apparent in warm climates, and, on mine presumably because it's black.
It seems the glue used to secure it gives way when heated enough.
They changed the 05s by putting two little buttons in the headliner, but they also apparently changed the 04 replacements, it seems by speccing a different glue. I posit they were using some new Low VOC glue originally
Some people seem to get 05 style replacements, I got a 04 style, but I verified that they used the re-designed part number, so we'll see.
Be sure to check the headliner before 3/36 because it's only covered under the basic warrantee. Even if you have the extended warrantee, the headliner is considered 'trim' and is not included.
Tempus is offline
Old 10-20-2005, 09:46 AM   #7
rflagg
[snapback]143225[/snapback]
The lights should be covered under the extended warranty, though, right?
-m.
rflagg is offline
Old 10-20-2005, 10:51 AM   #8
mikepaul
mikepaul's Avatar
Where was this thread last week when my car was still under warranty?
I'm not even going to go look now...
mikepaul is offline
Old 10-20-2005, 11:00 AM   #9
Jonnycat26
What do you mean by sagging? Is it supposed to conform to the shape of the car, or is it supposed to 'hang' down in the center of the car? Mine might have always sagged in that case.
Jonnycat26 is offline
Old 10-20-2005, 12:03 PM   #10
Tideland Prius
Friends: 26
i.e. the headliner doesn't follow the curve of the ceiling. When you push on it, it moves upwards.
ABS and Brake Light comes on forte88 Gen II Prius Care, Maintenance and Troubleshooting 2 10-16-2007 02:27 PM
Custom tail light fins Arroyo Gen II Prius Modifications 24 07-06-2007 08:47 PM
Short in taillights/brake light causing ABS light? c4 Gen II Prius Care, Maintenance and Troubleshooting 0 11-24-2005 12:04 AM
Just got the brake light recall done... Kev1000000 Gen II Prius Main Forum 32 03-18-2005 05:21 PM
Brake light melting efred500 Gen II Prius Care, Maintenance and Troubleshooting 34 01-24-2005 10:01 AM
