Prius battery life and replacement cost?
| | #61 |
| Battery Curmudgeon Join Date: Mar 2010 Location: Santa Fe, NM
My Car: 2005 Prius Model: N/A Package: #4 Thanks: 229
Friends: 10 | Scenario: car is at the body shop long enough that the 12V runs down. They jump it in order to deliver the car to you. Battery is still >90% discharged by the time you get it home. Then you go to start it two days later and it is dead. I'll give you a 5% chance that trickle charging restores it. Here's the problem. After 5 years on the original 12V, you are on borrowed time, and one little incident like what you describe is all that it takes to cause a fatality. Especially on the non SKS cars, the 12V is extremely fragile. I just lost one out of a 2007 on its last legs by having the car in Ig-On for just 30 seconds. Now it has a dead cell. The body shop may have been the catalyst, but most likely it was on its last legs.
__________________ 2005 Gen II Tideland Pearl Package #4 2004 Gen II Tideland Pearl Package #9 salvage rebuild project 2000 Red Honda Insight A/C 5 speed 2004 Toyota RAV4 L AWD 5 speed 2001 Toyota Sequoia SR5 4x4 2005 Toyota Sequoia Ltd/2006 SR5 4x4 restoration project |
| | #62 |
| Protecting Habitat & AG Lands Join Date: Aug 2006 Location: Sacramento, CA.
My Car: 2012 Prius Model: Three Package: Solar Roof Thanks: 1,478
Friends: 74 | I am in agreement with seilerts. |
| | #63 |
| Junior Member Join Date: Dec 2006
Friends: 0 | Seilerts, F8L, thanks for your replies. I will confirm after my visit to the dealer shortly. -Prs. |
| | #64 |
Friends: 74 | |
| | #65 |
Friends: 0 | good point. I will do that shortly. however, reading this thread, I did the vehicle signal check and got the following readings: IG OFF - 12.4V and with the headlight on, 12.1 V IG ON - 11.6 V and with the headlight on, 11.3V. somewhere I read that the nominal should be 13.9V with IG OFF. How do I know if the battery is good/ bad with this information? Also, the service check revealed some codes - are those the OBDII codes? or what the dealer will be finding out? |
| | #66 | ||
My Car: 2004 Prius Model: Package: Base Thanks: 14
Friends: 16 | Quote:
Your 12v battery is weak as it should hold its voltage better under load. Quote:
JeffD | ||
| | #67 |
| Junior Member Join Date: Apr 2012 Location: Alpharetta
My Car: 2006 Prius Model: II Package: #2 Thanks: 0
Friends: 0 | My 2006 just lasted 6yrs and I am in the process of replacing the battery now with a quote of $4000 at the dealer I am going to a refrub battery for 1250, installed cost averager $400 to 700 from the dealers. |
| | #68 |
Friends: 0 | What I really would like to know is the average time it takes to replace the battery? |
| | #69 |
| Senior Member Join Date: Sep 2009 Location: Australia
My Car: 2005 Prius Model: N/A Package: No Package Thanks: 94
Friends: 2 | How many miles have you put on it ralexj? |
| battery, cost, life, prius, replacement |
| 12 volt battery cost 275.00 2005 Prius W | k4141222 | Gen II Prius Main Forum | 19 | 02-04-2012 10:56 PM |
| HID replacement cost | TucsonPrius | Gen II Prius Main Forum | 26 | 04-26-2008 11:56 PM |
| Battery life on '03 Prius? | gene4655 | Gen II Prius Main Forum | 3 | 10-22-2007 04:31 PM |
| The cost of life | Stev0 | Fred's House of Pancakes | 2 | 11-29-2006 08:20 PM |
| 1998 Prius Battery Life | hannah | Gen II Prius Main Forum | 4 | 07-19-2004 08:56 PM |
