| This is a discussion on Starting Problems within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2004 Prius and 3 times in the last 3 weeks, it would not start. All lof the ... |
Starting Problems
Friends: 0 | I have a 2004 Prius and 3 times in the last 3 weeks, it would not start. All lof the lights come on except the Ready light. After several trys, it will eventually start, but irritating. I took the car into the Toyota dealer and talked to a service "manager" who told me if he couldn't duplicate the problem he probably wouldn't be able to fix it, which was not what the service technician had told me on the phone earlier (unfortunately can't remember his name). I have not had the stalling problem that I have heard about, nor have I received a recall - and the service manager didn't mention it. Any suggestions. Thank you. |
Friends: 1 | Quote:
But I've read about people getting into Ig-On mode when trying to start. That caused by not pressing the brake pedal when pushing the power button. | |
Friends: 37 | Happens from time to time...usually due to inadvertently 'double tapping' the Power button. Read the following article for more info. http://priuschat.com/forums/kb.php?mode=article&k=12 Usually, though, the best solution is to 1)Take your foot off the brake, 2)Push the Park button, then 3)Press the Power button. You should power down then be able to reboot to READY. If that doesn't work, though, you should 1)Take your foot off the brake and then 2)Press and hold in the Power button for about 5-10 seconds which should force a reboot.
Friends: 0 | is your 2k4 one of the cars with the brake switch recall? if the brake light switch dosen't make contact the car will not go into Ready. If repeatable have some one watch the brake lights and see if they come on when the car refuses to start, if they come on it's some other problem but if they don't come on that would be the problem. Also it's just possible that the switch has move and just doesnt' quite make contact when you depress the brake pedal to start the car. This would just take and adjustment to repair.
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. |
If this is your problem, a replacement brake pedal switch will fix it (the middle pedal, not the parking brake). | |
Don't know if you're aware of this TSB or if your car falls within the range of those needing the switch replaced. You should be able to get the dealer to look it up though. | |
Friends: 37 | Quote:
Friends: 0 | Cars produced August 04 or later I don't think needed it. Mine doesn't and I bought mine August 04. I get that hang every now and again too, often in waves. Pressing and holding the power button doesn't work. I think that normally puts you into Ig-On, which is where you are already stuck at. |
| Starting Car | priusmaybe | Gen II Prius Main Forum | 9 | 05-12-2007 11:44 AM |
| Misc. Problems: Sat Radio, Smart Key entry, Starting noise | jsgreenfield | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 01-21-2007 01:04 AM |
| Starting new | Begreen | Gen II Prius Main Forum | 6 | 01-19-2006 03:07 PM |
| Car not starting. | cbadland | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 12-06-2005 08:09 PM |
| Starting the car | Poppajack747 | Gen II Prius Main Forum | 22 | 08-23-2004 03:41 PM |
