| This is a discussion on Anyone know what a BG Kit is? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just got off the phone with the service person and scheduled my 5000 mile maintenance under my service plan. ... |
Friends: 0 | I just got off the phone with the service person and scheduled my 5000 mile maintenance under my service plan. So I asked whats included with this service..and faster than the disclaimer at the end of a car sales commercial I was told. Scribbled it all down .....here it is... oil change w/ filter lube doors (theres no grease on them now) lube suspension (really there are grease fittings? me thinks not ) check air filter check brakes check lights check fluids install BG kit road test I had to question whats the installation of the BG Kit? I was told its a fuel and oil additive. Does anyone know what exactly this is and its purpose? thanks.. Al
__________________ proud owner of "Misti" - '05 Millenium Silver (Coastal EV mod, front end protector, classic chrome splash guards, side window vents, priushoods leather glovebox & dash covers, GT Seat Covers, Heated Seat mod, HeatShield Front Sunshade, zinno wax!) |
| Senior Member Join Date: Jul 2005 Location: Boston
Friends: 2 | what kind of service plan do you have? |
List Price ~$28.00 Thes BG Kit inludes BG's 44K Fuel System Cleaner, Fuel System Dryer, as well as battery anti-corrosion pads. | |
thanks.. I found BG's website heres the stuff: http://www.bgprod.com/products/fuelair.html I guess since Toyota actually uses these products, they must work! - Al BTW I have the classic plan | |
Friends: 2 | so how exactly does this plan work? |
Friends: 0 | the plan works like this...every 5000 miles I get free service - but the plan expires in 1 year...( sneaky devils) I figger' I might only have 13-14 k in 1 year so I'll just get the 15,000 service then.What I have is called the "classic" plan.. they gave it to me as an incentive to buy so as I always say.... if its free its for me! I have 3 certificates, and I simply present one at each 5k service. the documentation sez this: every 5k miles factory trained techs will perform necessary preventative maintenance that will prolong the live of your new Prius. Your Toyota Auto Care benefits include: Oil and Filter changes lubrication of key chassis parts complete 19 point inspection which is this: fluids check and replenished: windshield wiper brake master cyminder p/s (if equipped) ...huh.. you can get manual steernig still? coolant (I assume ICE and ECU on pri) differential.. probably not on Pri clutch master cylender (manual tranny..not on pri I'm sure) transfer case (4wd only) tranny (definitely not on pri) visual inspection items: air filter axle boots drive boots pcv valce cooling system (for leaks) exhause/muffler hoses wipers shocks/suspension tire pressure (check and adjust) I'm sure they'll reduce my tp tire wear hope this explains it! - Al |
Friends: 2 | Quote:
| Senior Member Join Date: Aug 2005 Location: Marlborough, Mass
As seen in other posts, just bring the car in and tell them what you want done - don't tell them what "service" your bringing it in for (i.e. 15k mile service..etc). Only exceptions I'd make is when more than visual inspections are required, such as the 30k mile service. | |
| Senior Member Join Date: Feb 2004 Location: Washington DC
Friends: 0 | Apparently lots of Toyota Dealers add the BG "MOA" Oil Additive as part of their regular oil change. http://www.bgprod.com/products/engineoil.html One of the big things it claims is that it's a sludge preventative, and given the uproar caused by the sludging Toyota Engines, it may just be a CYA. I specify that they are NOT to use it on mine. I put in Mobil1 which is plenty sludge resistant for me, and the BG additive is straight 30 Weight, not Multi-Vis. I see no reason to compromise the viscosity of my oil for the possible benefit of the sludge prevention. Though, I must admit, of all the oil additives that one seems to have a good track record. |
Friends: 2 | Quote:
I think this is something completly different | |
