This is a discussion on front defrost within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally posted by Mojo40 @Dec 18 2005, 03:15 AM I'm not sure if this helps MPG much, but I noted ...
front defrost
Old 12-18-2005, 02:24 AM   #11
DanMan32
Originally posted by Mojo40@Dec 18 2005, 03:15 AM
I'm not sure if this helps MPG much, but I noted the engine runs a lot more if climate control (and especially defrost) is on.  Truth be told, I'm just an engineer looking for any excuse to screw with all the fun controls and hack my Prius.
[snapback]175173[/snapback]
You observe correctly. The system will be less tolerant of the coolant temp dropping if you demand cabin heat, and therefore will run ICE more frequently to maintain coolant temp for the benefit of your comfort.
At least for your temperature comfort. Not so comfortable if you are more focused on MPG than cabin temperature.
DanMan32 is offline
Old 12-18-2005, 02:28 AM   #12
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
i think afternoonnap was the first to hit it on the head. you have to have the fan on in order for the defroster to do its job.
i say, the less they do to the car the better. DH has taken it apart enough for me. of course, i do trust the work he does but i prefer it to be left well enough alone.
galaxee is offline
Old 12-18-2005, 02:37 AM   #13
Mojo40
[snapback]175178[/snapback]
Actually DanMan, I have forgotten to turn on Climate Control. About 10-15 minutes into the commute, I start to notice. I'm originally from northern Michigan and used to drive a 73 VW beetle, so perhaps I am used to not getting heat.
Mojo40 is offline
Old 10-16-2009, 07:59 PM   #14
adllewellyn
adllewellyn's Avatar
Default Re: front defrost
I can't seem to get my front defrost to work at all (light comes on and all, it's just not effective) - will try the whole set-to-auto thing. I live in Texas (where it is still hot and muggy in October) and wonder if that's part of my problem... thanks.
adllewellyn is offline
defrost, front
Why did Toyota decide not to defrost the whole rear window? NoMoShocks Gen II Prius Main Forum 7 10-29-2007 10:57 PM
Grill blocking and window defrost tballx Gen II Prius Modifications 2 10-22-2007 10:59 AM
ACC never turns on lower vent/front defrost mode automatically lorkp Gen II Prius Main Forum 8 01-22-2007 09:00 PM
Defrost and Climate Control tripp Gen II Prius Main Forum 11 12-01-2005 08:11 PM
Defrost and gas milage? hdrygas Gen II Prius Fuel Economy 18 01-16-2005 08:01 AM
