Help!! My Prius 2 won't start!!
| | #31 | |
| | #32 |
| Join Date: Jul 2004 Location: Michigan - land of everlasting snowflake icon!
Friends: 0 | When I jumped my Prius this week, I THOUGHT the fuse box was going to be difficult to open because the molding for the latches looks really complicated. Yet, all I did was squeeze the side of the cover and it lifted right off. I mean, I was actually suprized at how simple it was. I'm not sure what problems you others are having with it, but it surely was not at all 'difficult" to remove or replace. |
| | #33 | |
My Car: 2012 Prius Plug-in Model: Plug-in Base Package: Base Thanks: 651
Friends: 6 | Quote:
| | #34 |
| shortbus driver Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 583
Friends: 0 | It's true: Japanese are smarter than European Americans. |
| | #35 | |
Thanks in advance for your reply. | |
| | #36 | |
| Senior Member Join Date: Sep 2005 Location: Oxfordshire, UK
My Car: 2005 Prius Model: Package: T Spirit Thanks: 0
The latest instruction by KMO sounds like the right answer but I'll try it in the morning as it's now dark and 30F outside. | |
| | #37 |
| Junior Member Join Date: Jun 2009 Location: Philadelphia suburbs
My Car: 2006 Prius Model: N/A Package: Navigation Thanks: 0
Friends: 0 | I have had three occasions over two years when my Prius battery drained and I could not start my car. The first time, I was waiting in the parking lot for someone, listening to the radio, for about 30 minutes, with the car off otherwise. Apparently that was enough to drain the battery. A jump start worked right away. The second time, I sat in my car at a beautiful park in the spring to eat lunch. No radio, nothing on at all. However, I had just stopped and turned off everything, but I had not gotten out. An hour or so later, the car battery was dead. Another jump start worked well. The third time, the car was parked in my garage overnight. Everything was off - even every light. However, I had accidently left the smart key in the car. I have noticed that when the smart key is in the car, and the car is off, the security key light on the dash flashes. So I think the smartkey left in the car drains the battery even when everything else is off. Has anyone else observed this? I have never had the battery go dead when I stop the car and get out with the key. |
| | #38 |
Friends: 0 | That light also flashes when the key is not present, but after a battery has been drained thrice it will never be the same again. Always lock the car when you park it and you will avoid most of the common drain-the-battery scenarios. If you stop to listen to the radio or use other accessories leave the car ON ("Ready") and in Park. Check the 12V battery voltage at the jump points under the hood. With the car OFF it should measure 12.6 V to 12.8V. Less than 12.0V means it's near death. If you don't have a voltmeter use the selftest procedure given here: Checking 12v Battery Health - Hybrid Car Forums
__________________ "I like paying taxes. With them I buy civilization." - United States Supreme Court Associate Justice Oliver Wendell Holmes, Republican "A nation is not in danger of financial disaster merely because it owes itself money." - US industrialist Andrew W. Mellon, Republican |
| | #39 |
| Member Join Date: Dec 2006
My Car: 2007 Prius Model: Package: #2 Thanks: 9
Friends: 0 | Message deleted Last edited by Joannerice; 07-10-2009 at 07:56 PM. Reason: It was a stupid question |
| | #40 |
| Junior Member Join Date: Jan 2006
Friends: 0 | My '05 wouldn't start today. Recently had lots of cool, wet weather. However, it did give me some "warning." I finally started it after reading this forum for 10 minutes, and TURNED OFF BOTH (dim) DOME LAMPS AND THE HEADLIGHT SWITCH/TAIL LAMPS, switched off the SmartKey under the steering column, and closed the doors to lessen drain on the 12V battery. Waited a minute for it to recover. Powered right up. My cheapo Radio Shack tester showed the battery was OK after that, but I know better than to push my luck. Michigan winter's on its way. For the last month or so, when I would Power Off, about 50% of the time I got a single beep AFTER everything had shut off. The other half of the time it just shut off normally. The last time I shut it off, I sat listening to the radio for a while. I had the same results as some others here -- lots of screwy green blinking gages, exclamation point, flashing boxes, wouldn't turn off, Park lamp lit by itself, etc. Those are the kinds of things computers do if they don't have enough supply voltage; they just act totally screwy. The 12V battery supplies the computers/electronics, dome and door lamps, radio, heater fan, tail lamps, locks . . . Car is now 4+ years old, 75,000 miles. It got a stone-dead battery after a fender bender caused a short a year ago. That's really hard on any battery. So, after being run dead once, and being nearly 5 years old (which is about as long as ordinary 12V car batteries usually last), it's clear I need a new 12V battery. Unfortunately, I've learned that the dealer is the only place to get this peculiar little gem. ![]() However, in all fairness, I don't know of any other car that can have a dead battery, then start fine 10 minutes later. |
| help!!, prius, start!!, won't |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/13324-help-my-prius-2-won-t-start.html | ||||
| Checking 12v Battery Health - Hybrid Car Forums | This thread | Refback | 11-06-2011 03:38 AM | |
| Checking 12v Battery Health - Page 2 - Hybrid Car Forums | This thread | Refback | 10-09-2011 01:58 AM | |
| Checking 12v Battery Health - Hybrid Car Forums | This thread | Refback | 09-22-2010 11:48 AM | |
| Ran out of Gas, Now Prius won't start... | kraziewilly | Gen II Prius Care, Maintenance and Troubleshooting | 26 | 05-19-2012 08:11 PM |
| Jump start another car FROM a Prius? | davebrownbass | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 04-20-2011 12:21 AM |
| Cold weather related? Car won't start unless we try to start about 5-10 times | JasonInNJ | Gen II Prius Care, Maintenance and Troubleshooting | 20 | 01-25-2010 05:09 PM |
| Prius won't start | tommyrhoads | Gen II Prius Care, Maintenance and Troubleshooting | 22 | 12-03-2007 02:22 PM |
| Can't start 2G prius | wiluspyder | Gen II Prius Technical Discussion | 3 | 02-01-2007 07:31 PM |
