This is a discussion on Removing wax off black plastic within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I got some wax on the black plastic bit at the base of the windshield and the SKS lock button. ...
Old 01-14-2006, 09:29 PM   #1
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
I got some wax on the black plastic bit at the base of the windshield and the SKS lock button. How do I remove it? It's to the point where it looks like I had white paint splashed onto the black plastic.
Tideland Prius is offline
Old 01-15-2006, 02:05 PM   #2
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
Well I've done the same thing but it never turned white as yours did. Different kind of wax maybe? I have read here that some kinds of dish soap, Dawn is one I think, will remove wax. If that doesn't work you might try something which would be a solvent like WD-40, then wash the WD-40 off with soap and water. Did you read the wax container and see if they offer any suggestions? you might even see if the wax company has a web site and email them for advice.
tumbleweed is offline
Old 01-15-2006, 02:52 PM   #3
SW03ES
SW03ES's Avatar
Peanut butter.
I kid you not, its like the only thing that works.
SW03ES is offline
Old 01-15-2006, 08:13 PM   #4
roach52osu
roach52osu's Avatar
Originally posted by SW03ES@Jan 15 2006, 03:52 PM
Peanut butter.
[snapback]190688[/snapback]
I have used dawn dishwashing liquid in the past but works best when you get it off right away... The penut butter thing I have never heard but interesting and probably worth a try, I hate wax on plastic.
roach52osu is offline
Old 01-15-2006, 08:19 PM   #5
Tideland Prius
Friends: 23
I was using Mothers Paste Carnuaba wax. I usually use Turtle Liquid wax but decided to try paste wax since people say it lasts longer Turtle wax...
Anyway, yeah it's as if I used a paint brush and painted that black plastic piece with white paint. Fingernail will not scrap anything off.
I'll try the peanut butter method since I have some at home.
Old 01-15-2006, 09:48 PM   #6
Kiloran
Mineral spirits or turpentine will dissolve wax almost immediately, also kerosene.
Prelude Cleaner is about $6.
Kiloran is offline
Old 01-16-2006, 10:43 AM   #7
Tempus
Peanut Butter does fine. (Creamy not Chunky :P )
It also removes chewing gum from hair. It's truely a miracle cleaner.
Tempus is offline
Old 01-16-2006, 10:47 AM   #8
Kiloran
[snapback]191120[/snapback]
Wouldn't peanut oil work just as well with less of its own cleanup necessitated or is the peanut paste needed as an abrasive?
Kiloran is offline
Old 01-16-2006, 12:03 PM   #9
Tom_06
Tom_06's Avatar
Any auto store with a decent selection of car care products should have something for removing excess dried on wax from trim parts. From Griot's Garage (on-line), you can get a product called "Dried On Wax Remover" and someone else makes one called "Black Again". I've have used both and they work fine.
- Tom
Tom_06 is offline
Old 01-16-2006, 05:53 PM   #10
Tideland Prius
Friends: 23
Originally posted by SW03ES@Jan 15 2006, 11:52 AM
Peanut butter.
You're a genius! I tried peanut butter (yeah yeah, it's creamy Tempus lol) and voila! the white mark disappeared.
Thanks!
Edit: Works on road tar on the paint too!
Does removing stock plastic wheel rings reduce MPG efficiency? quixotequest Gen II Prius Fuel Economy 9 08-05-2007 06:11 PM
Removing plastic wheel covers splashback Gen II Prius Main Forum 26 07-15-2007 06:49 PM
Black Plastic and Wax snowdog650 Gen II Prius Main Forum 12 03-30-2007 05:50 PM
Removing the back plastic cover from the inside hatch door?? Rick M Gen II Prius Main Forum 5 11-15-2006 08:55 PM
Removing Plastic AMP Cover (easy Question) VisualMonster Gen II Prius Audio and Electronics 2 07-17-2005 04:44 PM
