oil level question
Old 01-27-2006, 07:11 PM   #1
Captainbaba
Bob Allen's Avatar
I recently had my Prius in for the 20k oil change. I requested that the techs not overfill the reservoir and only use 3.9qts of the four quarts of synthetic oil I supplied.
Dutifully, they did just that and there was a bottle with the remaining unused oil.
I checked my oil level today and noticed that the level was just over the top marker.
The engine was cold, however, and the manual says to check the level with the engine at running temperature.
I've heard caveats about overfilling and damaging the hybrid system, etc., but I can't figure out how there could be too much oil unless the dealer didn't completely drain the tank prior to refilling.
You techies out there have any feedback? There must be some leeway built into the system here....and why would the oil reservoir only hold 3.9qts rather than four? If the system was based on liters, i.e., four liters of oil, then we would have something like 4.3 quarts to fill it up.
Thanks,
p.s. planning a drive to Portland tomorrow and thought I'd check my oil again when the engine is warm but the oil has had a chance to drain back into the reservoir.
:P Angel Flight Pilot
Bob Allen is offline
Old 01-27-2006, 07:25 PM   #2
Location: Michigan - land of everlasting snowflake icon!
[snapback]199032[/snapback]
That's still too much, IMHO.
Keep in mind that the safe fill is anywhere BETWEEN the marks on the dipstick.
A new car that's not burning oil doesn't need to be filled all the way to the top and no car should be risked all the way down to the bottom mark.
3.5 quarts is perfect.
priusham is offline
Old 01-27-2006, 09:13 PM   #3
priusham is right,Bob. 3.5 qts is just right. That is what I put in them here at work. My opinion of the difference is that the 3.9 must be a dry fill,such as if the engine was dis-assembled and no residue was left anywhere in the engine. Since the vehicle is in the shop (warm) getting an oil change here,I put 3.5 qts in,start it up (may have to touch gas pedal to make the ICE come on ) for a minute or so to circulate the oil,then power down and leave sit for about 5 minutes. The level is usually at or just below the Full mark.
As for the hybrid or ICE being damaged from the slight overfill,that is false. If the oil is over filled by a lot or has the wrong viscosity (or any number of other causes),this may cause the ICE to be delayed in starting when told too. This would turn on the Check Engine Light and the Engine Did Not Start code would be stored. This is stored even if the ICE does start. The ECU wants to see the ICE start within about 5-7 secs. If it does start but takes,lets say 10 secs,then the Check Engine Light will come on and a trouble code will be set.
Rick Angles
Toyota Master Diagnostic Technician
Toyota Hybrid Technician
Germain Toyota
Columbus, Ohio
rick57 is offline
Old 01-28-2006, 10:41 AM   #4
shortbus driver
richard schumacher's Avatar
Oil sticks to the inside of the engine. You'll die of old age waiting for all of it to drain out.
Adding 3.0 quarts works very well. It leaves the level just about halfway, and there's no partial bottle of oil left over to fool with. (Golly, almost as if the designers planned it that way...)
richard schumacher is online now
Old 01-28-2006, 12:25 PM   #5
Friends: 16
I'm with Richard: 3 U.S. quarts works perfectly, very slightly over halfway between the Add and Full dots. If you use 3 litres, around 2/3 up past the Add dot.
After a lot of piddling around, I found it takes 3.35 litres at an oil change to put the level right on the Full dot.
I don't think 1-3 mm past the Full dot will harm anything.
jayman is offline
Old 01-28-2006, 10:44 PM   #6
[snapback]199097[/snapback]
Thank you for explaining how that works. I knew that it could set an error code but not why. I got a pump at CRAP that fits down the dip stick tube and you can pump out the extra. It was under $20.
hdrygas is offline
Old 02-01-2006, 12:13 AM   #7
[snapback]199692[/snapback]
[/quote]
How about replacing the oil drain plug with a Fumoto valve. Then all you would have to do is open the valve for a couple of seconds. You could even have it drain into a measuring cup if you wanted to be exact.
Kathleen
Kathleen2 is offline
Old 02-01-2006, 12:21 AM   #8
Kathleen
[snapback]201678[/snapback]
[/quote]
Yes but that requires getting under the car. You can do the pump thing from above. No crawling, no dirty floors, no dripping water, open the hood, put the tube down and pump.
hdrygas is offline
Old 02-03-2006, 06:11 PM   #9
Hi All,
just got my 2005 Prius's oil changed at Toyota dealer and despite requesting "please don't overfill it" the warm oil level reads a half-inch above the full mark.
My question is: is this too full to ignore?
jrprius2 is offline
Old 02-03-2006, 06:45 PM   #10
Ravenpaw of ThunderClan
aaf709's Avatar
Originally posted by jrprius2@Feb 3 2006, 03:11 PM
Hi All,
[snapback]203395[/snapback]
Yes. It's a good idea to remove it. I went to an auto store and got a cheap siphon for about $2. The siphon itself wasn't so hot, but the tube was exactly the right size.
The last time I got the oil changed I gave them 3 quarts and told them I'd add the rest. Good thing, the manager was surprised I wanted to put in so little because the Prius took 5 quarts. He did ask another mechanic right away and found out he was wrong.
aaf709 is offline
level, oil, question
Octane Level's Prakash Gen II Prius Main Forum 31 03-25-2006 06:01 PM
Nav map generalization level brasche Gen II Prius Main Forum 1 03-03-2006 04:22 PM
2K2 Prius Battery level question kirbinster Gen II Prius Main Forum 3 07-11-2005 10:38 PM
Rising Oil Level ryogajyc Gen II Prius Care, Maintenance and Troubleshooting 8 10-02-2004 11:47 AM
Why should the oil level never be above the fill line Dion Gen II Prius Care, Maintenance and Troubleshooting 4 03-16-2004 08:06 AM
