This is a discussion on 28,000 Mile Oil Change... within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; For whatever reason (I'm assuming gasket got stuck within the burrs, even though I did make sure to oil the ...
Old 01-30-2006, 11:47 PM   #1
Mystery Squid
For whatever reason (I'm assuming gasket got stuck within the burrs, even though I did make sure to oil the gasket prior to installing the filter, and made sure to not over-tighten), I had a rather difficult time getting the oil filter off. Check out the surface where the oil filter mates onto, is this normal (note the burrs on the outside edges)? Seems like whatever metal that unit is made out of, is very susceptible to winter road salt?
[attachmentid=2067]
[attachmentid=2068]
Air filter at 28,000 miles:
Top:
[attachmentid=2069]
Bottom:
[attachmentid=2070]
I have to say, not too shabby at all for 28K miles...
Mystery Squid is offline
Old 01-30-2006, 11:57 PM   #2
Frank Hudon
quick question what brand of oil filter were you using?
Frank Hudon is offline
Old 01-31-2006, 12:05 AM   #3
Mystery Squid
[snapback]201039[/snapback]
K&N
Thing is, it was like that when I got it, even before the K&N was installed.
Also, incidentally, although I didn't scientifically prove it, I swear, the oil color after 5K, was spectacularly clean with the K&N... BARELY any shades of brown... It's simply the fact I noticed it, as I've done my own oil changes (when I'm not feeling lazy anyway ) maybe several hundred times over a bunch of different vehicles over the years.
Oh yeah, I'm also using Mobil 1 5/30 fully synthetic, and another K&N...
Old 01-31-2006, 12:25 AM   #4
Frank Hudon
is that really pitting on the mounting flange? or is it just discolouration? from the pix it looks pitted. Most I have ever seen are smooth. Even in fish. The most corrosive environment for any piece of equipement.
Old 01-31-2006, 12:33 AM   #5
Mystery Squid
[snapback]201056[/snapback]
It is definitely NOT discoloration.
It strikes me as weird because I've NEVER seen such a thing, and I've owned and done oil changes on many different cars and motorcycles...
I'm thinking someone put in a real crappy filter (for I did buy it used with 12K on the clock), or maybe a filter with a flimsy rubber seal that was tightened too much and the metal lip came into contact with the flange and corroded a bit?
Old 01-31-2006, 12:58 AM   #6
Frank Hudon
the oem Denso//Toyota filter has an O-ring and the can tightens to the flange. I wonder, like you, if someone contaminated the gasket on one and that's the cause of the corrosion. Like I said hundreds of forklifts use in fish processing plants and I haven't seen that yet. Seen holes corroded in the oil tanks but that's only 1/4" thick. Holes corroded in the backing plates on the brakes 1/8" but not the block where the oil filter attaches. Seen the water pump fall off because the nuts holding it on corroded off, and the pressure in the system forced the water pump off the block. Minor stuff like that.
Old 01-31-2006, 01:03 AM   #7
Sufferin' Prius Envy
Platinum Member
Squid,
You been drinkin' and oil (pronounced eurl) changin' again?
Themz some blurry oil pictures. :P
Old 01-31-2006, 09:11 AM   #8
Friends: 37
If you're a K&N fan you can us a K&N air filter on the '04+ Prius too. I just installed mine a few days ago.
See: http://www.vfaq.net/mods/AirFilter.html
efusco is online now
Old 01-31-2006, 10:07 AM   #9
Mystery Squid
[snapback]201149[/snapback]
Oh crap, thanks! I was just thinking about it last night, and looked upon it with hesistation as certain vehicles handle K&N's better than others. Maybe at the next oil change, as I didn't think the current air filter needed replacing... In this case though, I see the K&N as an investment against having to buy more than one air filter, not for any performance gains (had enough of that sort of thing over the years... ).
Old 01-31-2006, 10:08 AM   #10
Mystery Squid
Originally posted by Sufferin' Prius Envy@Jan 31 2006, 02:03 AM
Squid,
[snapback]201070[/snapback]
hahaha, new digicam I got, so I was real paranoid about getting it dirty. Kind of quickly got under there, and quickly pulled it out (er, that didn't come out right... )....
Going from a 45 mile commute to a mere 5 mile commute pricoaster Gen II Prius Fuel Economy 22 07-09-2007 04:18 PM
Road Trip Planned / 5000 mile Oil change recomendation will be passed adamwmcanally Gen II Prius Main Forum 17 06-15-2007 11:41 AM
700 Mile Tank Roton Gen II Prius Fuel Economy 4 07-18-2006 05:52 PM
To make them change or not to change (the oil?) micheal Gen II Prius Care, Maintenance and Troubleshooting 4 08-07-2005 01:21 AM
1000 Mile Oil Change berryman Gen II Prius Care, Maintenance and Troubleshooting 19 01-13-2005 06:32 PM
