| This is a discussion on differential oil within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ok, the manual says to inspect the oil but how do you check the differential oil?... |
differential oil
Friends: 0 | Ok, the manual says to inspect the oil but how do you check the differential oil? |
Friends: 0 | Surely someone has checked or inspected the differential oil as it states in the maintenance schedule. From what I've read in the manual, it states to inspect the differential oil every 30,000 miles but I don't see any form of dipstick for it. |
Friends: 0 | You have to remove a filler plug on the front of the transaxle and check that the fluid level is up to just under the level of that hole. May be slightly messy. Removing some of the plastic under- cover first is probably advisable. . _H* |
Friends: 0 | Toyota recommends a visual inspection for leaks. No leaks oil level=Ok |
Friends: 0 | <div class='quotetop'>QUOTE(Frank Hudon @ Apr 24 2006, 09:01 PM) [snapback]244603[/snapback]</div> Quote:
Any ideas what it could be? I would appreciate any insight others may have. 06 package 7 puchased April 26 2006 | |
Friends: 0 | the *rear*? There aren't any fluid reservoirs back there except the gas tank, as far as I know. Make sure it isn't brake fluid... . _H* |
Friends: 0 | <div class='quotetop'>QUOTE(grimbasement @ May 29 2006, 06:59 PM) [snapback]262560[/snapback]</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(hdrygas @ May 29 2006, 11:10 PM) [snapback]262595[/snapback]</div> Quote:
I didn't think there were any reserviors in the rear of the car but that's where the spotting was. I thought brake fluid at first but It's been years since I've done any real work on my cars and unless my memory is bad, brake fluid is clear not chocolate colored, correct? At the very least I'm a little worried because a 1 month old car shouldn't be leaking anything. | |
Friends: 14 | <div class='quotetop'>QUOTE(grimbasement @ May 30 2006, 07:58 AM) [snapback]262710[/snapback]</div> Quote:
| Brand New with Leaking Differential - NOT TRUE! | PriusOwner004 | Gen II Prius Main Forum | 30 | 09-12-2007 06:52 PM |
| transmission/differential fluid | westex39 | Gen II Prius Technical Discussion | 11 | 05-24-2007 09:33 AM |
