| This is a discussion on Oil chg interval occurs during trip. within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, I've had my 06 Prius since January. It currently has a little over 3,000 miles. We are going on ... |
Friends: 0 | Hi, I've had my 06 Prius since January. It currently has a little over 3,000 miles. We are going on a cross country trip next week to Washington and will probably put on 3,000 or more miles. Should I get the oil change done before we leave or would it be ok to wait until we get back. I would like to have it done at our local dealer and not on the road or in Washington? Steve in Mi. |
| Progressive Member Join Date: May 2004 Location: Southern California
My Car: 2005 Prius Model: Package: #6 Thanks: 3
Friends: 0 | How much do you value keeping your warranty? |
| Senior Member Join Date: Dec 2004 Location: New Mexico
My Car: 2010 Prius Model: Package: N/A Thanks: 0
Friends: 0 | I wouldn't worry about your warranty. They can only void your warranty if failing to change the oil caused a problem. Going 1000 miles past the recommended mileage probably wouldn't hurt anything. If it were me, and because it's a new engine, I would probably go ahead and change the oil beforehand. |
Friends: 0 | <div class='quotetop'>QUOTE(nmrickie @ Apr 24 2006, 01:58 PM) [snapback]244352[/snapback]</div> Quote:
Thanks for the responses. Steve | |
| Platinum Member Join Date: Mar 2006 Location: Minnesota
My Car: 2006 Prius Model: Package: #7 Thanks: 35
Friends: 3 | i had the impression that changing the oil is pretty much the same as in every other car, so should it really matter if it's changed at a dealer or not? (so long as you keep receipts as proof for warrenty stuff) If it's ok to change it someplace other than a dealer, i'd just do a google maps search for jiffy lube's or something similar in the area you'll bne traveling and spend 20 minutes having it done when you get there... |
Friends: 0 | <div class='quotetop'>QUOTE(eagle33199 @ Apr 25 2006, 10:02 PM) [snapback]245353[/snapback]</div> Quote:
I would strongly recommend not going to any of those quick-change oil places. I always heard the stories, but now I'm a believer. Please allow me to elaborate - an oil change establishment on Thousand Oaks Blvd. Thousand Oaks, placed some DOT 5 brake fluid in my Honda Odyssey and caused a failure of the master brake cylinder (it's supposed to take DOT 3). The other incident occured on my other car - they (same quicky-lube) put the plastic road shield on with zip ties instead of putting the original screws back in and it flew off on the freeway and pretty much destroyed the plastic shield. After these two experiences and a few other relatively minor incidents, I no longer feel confident in thier level of training to do even simple things like changing oil and checking brake fluid. I used to be a mechanic and even owned my own business, so I understand how these things should be performed. I either take the car to the dealer or if I could find a good independant mechanic, I would take it to them. I think at least the independants and dealers have a vested interested in keeping you as a customer.
__________________ Bill - Seaside Pearl '06 Pkg #8, LEV Stickers. | |
| Oil Change Interval | nitewolfgtr | Gen II Prius Technical Discussion | 14 | 10-12-2009 05:00 AM |
| Timing Chain Replacement Interval | JeffG | Gen II Prius Technical Discussion | 49 | 11-18-2008 08:25 AM |
| Oil change interval with synthetic oil | DougSlug | Gen II Prius Care, Maintenance and Troubleshooting | 15 | 06-26-2008 08:18 PM |
| Oil Change Interval | john1701a | Gen II Prius Care, Maintenance and Troubleshooting | 22 | 10-28-2006 11:40 AM |
| Changing my own oil & interval service | harpsax | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 01-20-2006 02:18 PM |
