This is a discussion on Body Side Moulding within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(ajs @ Jul 18 2006, 10:47 AM) [snapback]288125[/snapback]</div> I am considering putting on door edge protectors as well as ...
Body Side Moulding
Old 07-18-2006, 11:01 AM   #31
sl7vk
sl7vk's Avatar
I am considering putting on door edge protectors as well as the side body moulding. Should I assume that I would not put the moulding on as close to the edge as you did, if I actually put on the edge protectors? Thanks for your response. Great job, BTW.
I would simply put your door edge protectors on first, and see how much room you have after that for the molding. you can always tape the molding in the desired position, and then try to open and close the door to see if you have enough room.
sl7vk is offline
Old 07-18-2006, 11:11 AM   #32
santoro1
<div class='quotetop'>QUOTE(sl7vk @ Jul 18 2006, 11:01 AM) [snapback]288136[/snapback]</div>
Thanks for your advise. I'm considering putting on silver metallic pinstriping.. Ordered it from a friend in body shop industry. We will take a look at it to see if it looks good, or too busy...
santoro1 is offline
Old 07-18-2006, 11:29 AM   #33
sl7vk
sl7vk's Avatar
<div class='quotetop'>QUOTE(ajs @ Jul 18 2006, 11:11 AM) [snapback]288145[/snapback]</div>
I like the idea. I think the molding is a good start to give your vehicle some nice sight lines. My next move is getting a clearbra on the front of this thing.
sl7vk is offline
Old 07-18-2006, 03:21 PM   #34
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
That would make sense, but I can't answer with certainty. I'm not familiar with how the door edge protectors mount.
Jim
JimboK is offline
Old 07-27-2006, 10:23 AM   #35
santoro1
<div class='quotetop'>QUOTE(JimboK @ Jul 11 2006, 06:37 PM) [snapback]284651[/snapback]</div>
Got mine from metrotpn.com as well.
If I can jump in here....
I put mine on myself. I'm not very mechanically inclined, and approached the project with some trepidation. But I was too much of a tightwad to pay someone else (and I had an alimony and child support payment due!), so I tackled it myself. I am totally pleased with the results. I'd share pics, but they wouldn't show you anything different than the fine examples posted by others.
Here's how: I can't remember where I read this to give credit where it's due, but on one of the forums someone suggested blue painter's tape as a guide and small plain magnets. The painter's tape peels off more easily than masking or other tape, and doesn't mar the finish. Using the vertical measurements recommended by the instructions included with the mouldings, I applied the tape down the side of the car on both doors, planning to mount the mouldings at the top edge of the tape. I eyeballed the tape on a horizontal plane from behind the car to make sure it was straight, adjusting as needed to get it so. For one door at a time, I stuck four square-shaped magnets to the door, on the tape (hence, the reason for placing the tape below the intended mounting location -- the tape keeps the magnets from scratching), spaced equally and with the top edges even with the top edge of the tape. I prepped the door surface with the chemical in the dispensers included with the mouldings, per the instructions. I set the moulding piece on the top edge of the magnets (they hold it in line) and double-checked the alignment. With one hand and the magnets together holding the moulding in position, I carefully began removing the backing to the adhesive strip and pressing the strip against the car, until the entire moulding piece was attached. One small mistake: For the first one I pulled the adhesive backing at a right angle to the moulding, and it tore off. Part of the moulding was already stuck to the car and it was awkward trying to get behind it to grab the edge of the backing to start pulling it off again. I learned after that to pull as close to horizontal as possible.
Good luck! And be careful. You may have only one chance to get it right.
Jim
Also got mine from metrotpn.com
Jim, great advise...I am going to describe in detail what I did which is very close to what you did with a few extra twists that seemed to make it even easier..Perhaps others can look at both techniques and at least have some options as to how to do it. I also installed chrome door edge guards (I liked the contrast between the magnetic gray paint and chrome), so I had to give the moulding a little bit more room to be able to open the door without hitting the edge. Here goes...First, the instructions have you putting the masking tape (I prefer painters tape either blue or purple, just like Jim) above the area to be used. I agree with Jim, it should be put BELOW the application area. The painters tape and rectangular magnets work beautifully...I used 4 of them...First measure 12 1/2 inches from the bottom of the back section of the rear door upward and put a small piece of painters tape, then measure 11 3/4 from the bottom of the front part of the front door and put another small piece of painters tape.Next use the top edges of those pieces of tape as your line (once double checking the measurements of course). Put painters tape across both doors to get an nice straight, but slightly descending incline (back to front) across both doors..just as Jim suggested eyeball the line front to back and back to front to be sure it looks good to your eye. It is very easy to make corrections if off a little....Next place the magnets on both ends of each door on the painters tape precisely even with the top edge of the tape. Place the moulding (with backing still on at this point) on the magnets and use small pieces of painters tape to hold them up on the magnets. Then, re eyeball the moulding to be sure you like the look.. Next, cut the tape in between the two doors so you can open the rear door. With my chrome door edge protectors I needed 1/2" space to be able to open the rear door without hitting the front door...giving me approx 1/4" gap to play with which I thought was enough. If you don't have the door edge protectors you will be able to have 1/4" space instead of 1/2". (Just be sure you can open the door without it hitting the other door) ..With the door edge protectors you won't get the same precise look as on Jim's pictures, but it still is very satisfactory.. Feel free to enjoy customizing YOUR car the way you like it...Then place the mouldings upside down on a towel on the garage floor. Take the alcohol swab and gently wipe the area to be used and then wipe the excess alcohol with a soft white towel. You are now ready to finish the job......I found that my mouldings had two different pieces of tape backing.. Here is where I did it a little bit differently. Instead of trying to take the tape off while pressing the moulding onto the car, I took the tape off of the moulding and I laid it back down finish side down on a towel on the garage floor right beneath my work area. Next I snapped one of the little glue bottles and applied the glue to the whole length OF ONE DOOR in the area the moulding would be placed. It took two long strokes to cover the area that the moulding would be set on..(REMEMBER ONE GLUE BOTTLE IS FOR TWO MOULDINGS...I REPEAT, DO ONE MOULDING AT A TIME) Next I took the moulding and gentle laid it on the magnetics at an angle facing away from the car as it rested on the magnets (you need to have good strong magnets so they don't fall down). At this juncture the moulding adhesive is NOT touching the car yet. It took a second or two to make sure it was lined up perfectly and then I pressed it onto the vehicle, using the magnets as my guide.(this is why I will say again, you need strong magnets so they don't move). I wiped the moulding down with the soft white cloth while pressing as per instructions, and then QUICKLY applied the glue to the second door and did the same thing again...After I admired my work for a few minutes I repeated the same process on the other side of the car.. This worked perfectly and took approximately 75 minutes given that I had a number of interruptions from my children...Feel free to choose which technique you use...The magnets really worked well. To my eye it looks professionally installed. I am in the middle of more mods...Once I get them done I'll get some pictures for you...Hope this helps. Dr. Al PS.. This is just another indicator of why this forum is SO great....Had I not seen Jim's post I would have never thought I could do this job by myself... The only thing I would have liked is instead of 2 tubes of adhesive the company would send 4. As Jim said, the glue drives VERY quickly. Perhaps when you order you can request two extra tubes...Even if you had to pay an extra $5 it would be worth it....Thanks Jim...your efforts are appreciated.
2006 Magnetic gray package 4, BT Stiffening Plate, Carbox II cargo liner, carbox II passenger liners over factory mats, Body side moulding, black door edge protectors, clear corner bumper protectors, rear bumper protector, side window deflectors, custom silver metallic pinstripe, MFD hood, MFD clear protector, mud guards, cargo net, Belkin cell phone holder, leather center console cover, leather arm rest covers, window tinting, Zaino car detailing, Wet Okole seat covers with custom logo.
santoro1 is offline
Old 07-30-2006, 04:03 PM   #36
EricGo
Three cats, one Prius, and assorted humans
EricGo's Avatar
Mouldings placed today, bought from metro.
It is straightforward -- Paying for a detail shop to put them on is overkill. I did make two small mistakes though, for the obsessive:
1. The tape on the back of the moulding is actually in two pieces; a small extension covering the arrow-head is separate, and should be partially peeled back before sticking the moulding on starting from the other side. The first part I put on has that piece of tape remaining. Luckily I started on a back door, where wind will not try to whip it up. Best to peel back a cm or so of tape on the back of the moulding before putting the glue on the car; it can be un-nerving trying to start the peel if you do have long fingernails, knowing that the glue dries quickly.
2. The only place to be extra-careful in placement is where the two mouldings on one side of the car come close to each other. I was off by about 0.5 mm on one side, and I can see it if I look closely.
BTW, the masking tape approach works fine. I first took a small 1 inch length of tape, and placed it's upper edge at the instructed height at each end of the car. So long as the tape measure is held reasonably straight vertically up, the line on tape measure provides a nice horizonal line to place the 1 inch tape by. Then with my son's help, we pulled a piece of tape taut, and stuck the lower border flush with upper border of the 1 inch piece.
R2-E2: 2004 Prius, 37K miles, lifetime MPG 57.1 as of 8/2006.
Rolling 12 month average: 61.05
EricGo is offline
Old 07-31-2006, 10:22 AM   #37
onerpm
My Car: Other Hybrid
I think I'd read on this forum way back when that you can skip the Pro-Bond on a brand-new car. I did just that when I put these on my 2005; just removed the tape and stuck them on. 20k miles later, they're solid as rocks.
rpm
onerpm is offline
Old 08-08-2006, 10:24 PM   #38
mtsarpilot
<div class='quotetop'>QUOTE(sl7vk @ Jul 18 2006, 09:29 AM) [snapback]288154[/snapback]</div>
Add another happy customer to the list. Project was quick and easy. Just follow the directions and it goes well. I highly recommend the clear bra. I have this on my other cars and it has been well worth it. The full set of locations includes the top of the rear bumper where you're likely to ding it up as stuff goes in and out of the back of the car. Nice protection there.
On the molding installations, I had my wife hold the pointy end of each molding in place as I applied it starting from the blunt end that is at the seam of the doors. I did the way the instructions state to peel back the tape covering a little at a time. With her holding the pointy end in the proper location, the molding sat on the door just right. As I peeled the backing tape off, I lightly stuck the molding on and kept peeling till I got to the end. Slick and easy.
Joel
Seaside '06 Package #6
Leather added
Full Clear Bra package
Mud Flaps, Side moldings, and Coastal receiver hitch
Purple Wire switch and Sirius Here2Anywhere Receiver installed behind smoked window door
mtsarpilot is offline
Old 09-07-2006, 10:11 AM   #39
santoro1
<div class='quotetop'>QUOTE(JimboK @ Jul 18 2006, 03:21 PM) [snapback]288267[/snapback]</div>
Jim
Jim, thanks again for your advise on the body side moulding..As you can see by my post I tweaked your directions just a bit..Bottom line, one month later...they look excellent. Eventually I will be getting some pictures on the forum..Just waiting for my wet okole's to come in..Then my mods will be done and I'll take some photos...
santoro1 is offline
Old 09-07-2006, 11:23 AM   #40
JimboK
JimboK's Avatar
Friends: 6
Glad to hear it! And thanks for the update.
Jim
JimboK is offline
Body Side Moldings for 07 Peabody214 Gen II Prius Modifications 13 01-08-2008 06:58 PM
Body side moulding chimohio Gen II Prius Modifications 18 11-02-2006 05:06 PM
Side body moulding santoro1 Gen II Prius Modifications 4 07-17-2006 05:04 PM
Side moulding installation costs thaight Gen II Prius Main Forum 9 03-09-2006 09:53 PM
Prius 2G Body Side Moulding rknight408 Gen II Prius Modifications 14 05-18-2005 05:21 AM
