This is a discussion on Door Panel Plastic Peeling within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2005 Prius with about 20k miles. Like other posts, my panel creeks when I rest my arm ...
Old 05-10-2006, 11:03 PM   #1
rsgoehri
I have a 2005 Prius with about 20k miles. Like other posts, my panel creeks when I rest my arm on it. However, within the last two weeks it has now started to peel. There is a thin plastic cover over a plastic substrate that has separated and peeled off. Has anyone else had this problem? Is it under warranty?
rsgoehri is offline
Old 05-10-2006, 11:41 PM   #2
seasalsa
seasalsa's Avatar
<div class='quotetop'>QUOTE(Scott G @ May 10 2006, 08:03 PM) [snapback]253289[/snapback]</div>
This has been reported several times and is covered under the warranty. Some have reported that they used sun tan lotion and drove with the window down and their arm on the panel.
seasalsa is offline
Old 05-11-2006, 12:36 AM   #3
mkaliski
<div class='quotetop'>QUOTE(Scott G @ May 10 2006, 11:03 PM) [snapback]253289[/snapback]</div>
I had the drivers door panel replaced on my 05 Prius under warranty due to the same peeling problem. It was a 10 minute replacement, but the cost of the panel out of warranty was around $525.00 I hope this is a permanent fix.
mkaliski is offline
Old 05-11-2006, 12:24 PM   #4
Miss_Taz
Miss_Taz's Avatar
I also had my driver's door on my 2005 do this. They replaced it under warranty.
In the 2006, they have replaced the coverings on the doors with a more textured, durable material. (Whew!)
Miss_Taz is offline
Plastic Door Panel Scuffs Easily k2rm Gen II Prius Main Forum 16 06-28-2006 12:27 AM
Driver door interior material peeling away? Miss_Taz Gen II Prius Care, Maintenance and Troubleshooting 6 11-10-2005 08:59 AM
Interior door panel paint peeling off nc_driver Gen II Prius Care, Maintenance and Troubleshooting 10 11-02-2005 12:00 AM
Peeling of plastic film of inside door mlott Gen II Prius Main Forum 4 07-19-2005 02:56 PM
