This is a discussion on Gas engine not cycling on properly within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; It also won't stay on when you let off the gas pedal while in park. It revs up but then ...
Old 05-12-2006, 05:43 PM   #1
Psi296
Unhappy
It also won't stay on when you let off the gas pedal while in park. It revs up but then shuts off quickly. THis cause my battery to run down to 2 bars and the gas engine still won't engage.
Has anyone heard about this?
Psi296 is offline
Old 05-12-2006, 05:49 PM   #2
Friends: 37
Sounds like it's working fine. It's not supposed to come on unless the battery charge drops very low (1-2 bars depending upon whether the heat/AC is on etc.) or you're actually driving.
This is a good thing, burning gas when you're not moving is wasteful.
efusco is online now
Old 05-12-2006, 09:01 PM   #3
Psi296
But when the ICE does engage, it immediately shuts back off without even attempting to charge the battery...basically if I don't press and hold the gas pedal, the gas engine will not engage.
That can't be right.
Psi296 is offline
Old 05-12-2006, 09:09 PM   #4
ghostofjk
Unrepentant Nattering Nabob of Negativism (V.P. Spiro T. Agnew)
No, with two bars showing on the HV battery, something's not right. How many miles have you driven it?
ghostofjk is offline
Old 05-12-2006, 09:51 PM   #5
Friends: 37
<div class='quotetop'>QUOTE(Psi296 @ May 12 2006, 08:01 PM) [snapback]254459[/snapback]</div>
That can't be right. [/b]
It is right. There is no reason it should/would "charge up" the HV battery. The ICE will run briefly to reestablish a reasonable SOC (1-2 bars) then shut off again in anticipation that you will start driving again soon. At that point it will engage its normal algorythms and get the SOC back up in the 4-6 bar range.
Don't get caught in the trap of thinking that the battery 'needs' to be at a certain SOC.
Your car is working fine. My suggestion to you is to avoid situations where you're just sitting with the car in READY mode and not moving or going anywhere.
<div class='quotetop'>QUOTE(ghostofjk @ May 12 2006, 08:09 PM) [snapback]254463[/snapback]</div>
Sorry, I think you're mistaken. If it only stayed at 2 bars even with normal driving I might agree, but he's talking about when the car is sitting going nowhere. The battery will, in those cases, drain down to 1-2 bars and go through the very brief ICE run, then shut down sequences until you get moving again and the SOC will not often go above 2 bars...I've rarely seen 3 in those occasions, but usually just 1-2.
Evan E. Fusco, MD
Old 05-12-2006, 09:52 PM   #6
darelldd
Prius is our Gas Guzzler
darelldd's Avatar
<div class='quotetop'>QUOTE(efusco @ May 12 2006, 06:51 PM) [snapback]254483[/snapback]</div>
Agreed! This is how it works by design, folks. Don't fight it. Be happy.
If you really WANT that ICE running all the time, you've purchased the wrong vehicle.
darelldd is offline
Old 05-12-2006, 10:04 PM   #7
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
Some others have reported similar experiences. Some while driving, others while parked. I usually shrug it off as the car being indecisive (not technical, but people can understand it).
It's as though the car says, "my battery is low so I'll run the ICE but I'm not moving, so I'll turn it off but it's a bit chilly so I better turn on to heat up but we're in park so I'll turn off but the battery's low so I'll turn on..."
After almost two years of driving my Prius, I am certain that there's nothing wrong with your car. I have more of an issue with your car having only two bars remaining. Just how often do you have that situation and what are you doing to get to that state?
Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness
Current Mileage
Chicago Prius Group Website
Chicago Hybrid Group on FaceBook
Find me on faceBook
TonyPSchaefer is offline
Old 05-12-2006, 10:50 PM   #8
Evan and Darell have it right. Your ICE is doing exactly what is supposed to do under those conditions. There is absolutely no reason it should charge the traction battery while you are just sitting there, unless the SOC gets very low.
Old 05-12-2006, 11:20 PM   #9
Psi296
Thanks for the responses guys.
In response to your questions, I have 4700 miles on the car. Even though traffic here in Baton Rouge is usually a nightmare...I have never experienced the battery getting that low...or just haven't noticed it if it has.
Today was unusual, it was very hot so the A/C was on full and I was stuck in standstill traffic due to an accident, so I was just sitting there and noticed that only 2 bars on the battery were left and the ICE was doing nothing and I guess I just panicked.
Anyway, I am bringing the car in to have the oil changed tomorrow and they said they would take a look and see if anything is amiss.
Thanks again for the information, this site has once again proven to be a lifesaver.
Psi296 is offline
Old 05-13-2006, 02:23 AM   #10
ghostofjk
I've had four Priuses and have driven a total of about 125K mi. in them. I've never seen a SOC under 3 bars, under any conditions. In fact, I think I remember Graham or someone saying the system would not allow the SOC to go below 3-4 bars, with the possible exception of limping toward a gas station having run out of gas. I suppose in an extreme case (AC on, gridlock) I can imagine it GOING down to 2 bars, but I can't imagine that not causing the ICE to cycle on. And I've been stuck in gridlock with the AC on several times.
Imagine the "Desiderata" here.
Pointy-headed ex-hippie elitist liberal
'04 silver, '06 red
Engine cycling rapidly/delayed rev Cessna157 Gen II Prius Technical Discussion 6 11-14-2007 09:15 AM
Gas engine cycling is rough Xabiche Gen II Prius Technical Discussion 5 08-17-2007 12:47 PM
How to properly fill gas tank? KS_prius Gen II Prius Main Forum 54 06-25-2006 11:56 AM
Prius Heat Working Properly? djasonw Gen II Prius Main Forum 17 12-14-2005 01:46 AM
HID headlights working properly? rlbk38 Gen II Prius Main Forum 7 07-31-2005 10:38 AM
