This is a discussion on Need help identifying noise behind dash within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello, I have a 2006 with about 7800 miles. There is a noise that I can't seem to identify that ...
Old 05-19-2006, 09:31 PM   #1
Truffles
Package: #8
Hello,
I have a 2006 with about 7800 miles. There is a noise that I can't seem to identify that seems more pronounced over the last few days.
It's coming from behind my dash, right on the other side of my speedometer. It sounds like a pump of some sort is activating. It can happen every couple of minutes and it lasts around 5 seconds. It seems to be more common at slower speeds, but this could be just due to less road noise.
The only way I can describe it is it sounds like a whirling or winding noise of some sort.
Thank you
Truffles is offline
Old 05-19-2006, 11:22 PM   #2
Frank Hudon
the brake pump, hydraulic pressure pump, is on the RH side of the car in a line from the driver seat to the right of the speedo cluster. To find out if it is what is causing the noise stop the car and put it in Park and then step on the brake pedal hard 4 times, is that the noise?
Frank Hudon is offline
Old 05-20-2006, 05:26 PM   #3
Truffles
Package: #8
that's it.. thank you. It seems to be cycling on more than before. I'll do some addtional research on the forum.
Truffles is offline
Old 05-20-2006, 05:32 PM   #4
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
if it's running that often you need to have it checked out. the system is losing pressure way too quickly if it's running every couple minutes. unless you're talking about heavy stop and go traffic with lots and lots of braking.
galaxee is offline
Old 05-21-2006, 10:59 PM   #5
edselpdx
edselpdx's Avatar
<div class='quotetop'>QUOTE(galaxee @ May 20 2006, 02:32 PM) [snapback]258577[/snapback]</div>
Mine has always seemed to run alot. (2005). Almost every time I come to a stop I hear it, and i do mostly city driving with frequent lights. I actually wouldn't worry much unless it seems to interfere with driving or performance.
sj
edselpdx is offline
Old 05-21-2006, 11:29 PM   #6
hobbit
hobbit's Avatar
It's okay if it's running fairly frequently when you're *using*
the brakes, but not when you're not. Try sitting in one place for
a while, in Park. If the accumulator keeps leaking down and causing
the pump to run with no brake usage, then have it checked out.
The increase in noise over time may simply be the pump "wearing in".
New accumulator pumps seem to be a bit quieter than ones that have
been on the road for a while, but this doesn't mean the seasoned ones
are shot yet.
_H*
hobbit is offline
Old 05-22-2006, 09:30 AM   #7
Friends: 41
Yup, I'm with Hobbit and others. If you're hearing it that frequently I'd beconcerned about the accumulator running too often. There was a report on PriusOnline a year or so ago where someone had that problem.
efusco is online now
Old 05-23-2006, 07:14 PM   #8
Truffles
Package: #8
Thank you all..
I'll have it looked at soon. If anything exciting is found, I'll let you know.
Truffles is offline
Noise in Dash...Arrghh!! texassalsa04 Gen II Prius Care, Maintenance and Troubleshooting 68 09-26-2008 07:02 AM
2005 gurgling noise under dash??? ggarman Gen II Prius Main Forum 11 05-31-2008 01:04 PM
2007' Prius clicking noise in front end/dash? voi9 Gen II Prius Technical Discussion 14 11-22-2007 12:27 PM
Unknown noise from dash, somewhere behind steering area chrism07924 Gen II Prius Care, Maintenance and Troubleshooting 3 05-13-2005 01:13 PM
Passenger Side Dash Noise slumbum Gen II Prius Care, Maintenance and Troubleshooting 1 10-04-2004 09:08 AM
