This is a discussion on Tail and license plate lights went out -- brake lights work within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; And why we STILL don't have LEDs in all the signal positions is beyond me. We wouldn't be having this ...
Old 05-27-2006, 07:00 PM   #11
darelldd
Prius is our Gas Guzzler
darelldd's Avatar
Friends: 13
And why we STILL don't have LEDs in all the signal positions is beyond me. We wouldn't be having this discussion. The car would cost about $20 more to build, but would be cheaper in the long-run as none of these bulbs would need to be replaced - and you can't put a price on the increased safety aspect.
darelldd is offline
Old 07-24-2008, 01:16 PM   #12
racingstripes
Default Re: Tail and license plate lights went out -- brake lights work
This just happened to me a few days ago. All three lights out. Open the hatch and shut it -- left tail light came on. Again -- the plate light came on. Again -- the right tail light came on.
Next time I checked, it happened again. I've not called the dealer yet but will advise.
I can't see how a bulb replacement could fix -- unless they're like 1960's Christmas lights where if one bulb goes out, the entire string goes black.
racingstripes is offline
Old 08-23-2008, 09:22 PM   #13
robstrash
This just happened to me too. Wife was in car and I opened hatch and upon close saw 1 light out. Then noticed 1 license plate light out. Later I was looking at the lights and slammed the door down hard and the light came back on. I took it out to look at it and could see that the bulb was dark on top (usually means light burnt out). Put bulb back and it didn't work. I replaced th bulb and it immediately went on.
Not sure why slamming it made it go on for a bit, but the bulb did appear to be bad and works fine after bulb replacement. The W5W bulb 2 pack was under $2 at WalMart.
robstrash is offline
Old 08-25-2008, 04:27 PM   #14
9G-man
Originally Posted by dialwmd View Post
<div class='quotetop'>QUOTE(GreenGene @ May 26 2006, 07:53 AM) [snapback]261255[/snapback]</div>
I have 70 K and love the car. My confidence is just shaken right now......
70 Thousand trouble free miles and a little quirk with the tailights shakes your confidence in your car !?!!!, . Please don't ever buy a domestic car.
9G-man is offline
Old 06-29-2009, 07:44 PM   #15
fiblet
I had both tail lights out at night. All I had to do was bang each tail light and they would light up. This is what American cars do, not a Toyota. Fortunately, this is the only problem I have had over the 130k miles on this Prius.
fiblet is offline
Old 12-25-2009, 04:01 PM   #16
fossilfuel
fossilfuel's Avatar
Sounds like I have a similar issue.
06 with 68k miles. Driver at night told me my tail/rear lights are not on but my headlights were. I pulled over and checked and he was correct. How do they ALL go out at the same time?
I have the platinum warranty, but assume this wont be covered. How much is this going to cost me or is it something I should do myself? I will call my toyota dealership tomorrow
any help please? thanks
fossilfuel is offline
Old 12-25-2009, 04:07 PM   #17
DonDNH
DonDNH's Avatar
I've had this happen to me a couple of times. In each case, the bulb holder is loose in its socket inside the hatch. All I have had to do is tighten the connection and the lights come back on.
It is annoying as I usually notice it when it's raining cats and dogs.
DonDNH is offline
Old 01-13-2010, 12:46 PM   #18
kroth1342
I have the same problem on my left tail light - going to check this fix before I bring the car to the dealer for an appt tomorrow.
The issue seems fairly common, at least from this thread.
kroth1342 is offline
brake, license, lights, plate, tail, work
Tail Lights On in the Morning Astro33 Gen II Prius Care, Maintenance and Troubleshooting 6 12-09-2006 11:28 AM
Why are my tail lights on? PA Gen II Prius Care, Maintenance and Troubleshooting 5 10-11-2006 07:36 PM
Head lights/ tail Lights don't work hikerdave Gen II Prius Main Forum 5 04-13-2006 08:34 AM
Anyone having problems with tail-lights? priusman88 Gen II Prius Care, Maintenance and Troubleshooting 1 11-08-2005 08:19 PM
Camry tail lights jfschultz Other Cars 3 04-25-2005 11:11 PM
Content Relevant URLs by vBSEO 3.5.0
