This is a discussion on Engine oil analyses within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; [attachmentid=3978]I am starting a new topic on this to post all the data I have harvested thus far on Prius ...
Engine oil analyses
Old 06-27-2006, 05:31 PM   #1
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
[attachmentid=3978]I am starting a new topic on this to post all the data I have harvested thus far on Prius engine oil analyses. If anyone wants to add more data from their car that would be great.
The data are sorted from left to right by decreasing copper content. This is the only 'wear metal' that varies much in Prius. Silicon does also, but that story is a bit more complicated.
Anyone who has seen used oil analyses numbers before might be surprised at how low these numbers are. It appears that the Prius engine is quite nicely engineered , and lives an easy life.
EDIT: I have revised the spreadsheet correcting the ScottY column
DAS
tochatihu is offline
Old 06-27-2006, 05:44 PM   #2
ScottY
ScottY's Avatar
Hey, you forgot mine~
http://priuschat.com/index.php?showtopic=17223&hl=
EDIT: I think you mixed up between ScottY (me) and Scott Chase in your excel file.
ScottY is offline
Old 06-29-2006, 03:09 PM   #3
theorist
theorist's Avatar
<div class='quotetop'>QUOTE(tochatihu @ Jun 27 2006, 05:31 PM) [snapback]277570[/snapback]</div>
Very nice! Thank you for compiling this and everyone for sharing their oil analyses.
When you update this it might be nice if you coul add a separate field (a row) for the oil brand/model and another one for the weight so that we can sort and compare by oil.
Again, Thank You.
theorist is offline
Old 01-09-2007, 02:50 PM   #4
dcoyne78
[attachmentid=6201]Hi,
I have added a few analyses and changed the way the spreadsheet is sorted, I also made some corrections to Jayman's analyses and added the lab and date where I can find them. I have also added a second sheet with PPM/1000 oil miles along with averages and standard deviation. This is only interesting for wear metals and contaminants but I included the data for additives as well. I did not include in the averages analyses for new engines (less than 5001 miles) and for analyses less than 5000 oil miles (because my analysis at 2.5K only had 1 ppm FE which I didn't really trust). Spreadsheet attached, let me know if my "corrections" are in fact incorrect, thanks.
Dennis
83.7 mpg 629 mi best tank
51.4 MPG avg last 12 Tanks 4426 mi
53.8 MPG avg last 24 Tanks 9606 mi
57.8 MPG avg last 48 Tanks 21911 mi
MPG data
dcoyne78 is offline
Engine OFF andyprius Gen II Prius Main Forum 9 05-30-2008 06:34 PM
Used Oil Analysis (UOA) or Analyses and Extended Oil Change Interval dcoyne78 Gen II Prius Care, Maintenance and Troubleshooting 42 07-18-2007 08:16 AM
Engine On 'n Off Stev0 Gen II Prius Main Forum 11 06-09-2007 08:17 AM
Prius engine oil analyses tochatihu Gen II Prius Main Forum 3 11-30-2005 11:59 PM
What engine oil to use? webguy Gen II Prius Care, Maintenance and Troubleshooting 14 10-12-2005 07:46 PM
