| This is a discussion on Fuel tank vapor canister tube location? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ok, I spent the last couple of boring conference call hours searching for details to this, and couldn't find it. ... |
Friends: 0 | Ok, I spent the last couple of boring conference call hours searching for details to this, and couldn't find it. I'm an engineer - I crave specifics, not nebulousities. I just filled the tank for the second time on our new Prius yesterday (wow, that's some fractured syntax...) It shut off at right around nine gallons, which I knew had to be short, based on miles on the tank versus displayed mpg. The nine gallons were on the slowest click of the nozzle. I figured I'd at least round it up to the next bit, got distracted, and it took another 1.85 gallons - total 10.92 gallons. Nothing burped, couldn't see gasoline in the neck, but it took a lot more than I expected it to. Where, exactly, in a 2006, is the vapor recovery canister tube that is alleged to be in peril of dumping fuel into the canister? Is it just below the nozzle hole (as I expect it should be)? Is there indeed no valve to keep liquid out of the canister? I know that in the dark ages, any recovery tubes were at the top edge of the filler neck, at about 10 o'clock (or 2 o'clock, depending on your perspective), so it was danged near impossible to get fuel into them because of the angles involved. Is this no longer the case? I'm hoping someone with a shop manual can maybe post a picture to satisfy my compulsive nature... Thanks for the help! By the bye, we're running a bit over 43mpg on the first two tanks, without really paying any attention to trying to conserve - one h*lluva lot better than the 17.6 in the Suburban!! Yay!
__________________ Silver Pine Mica #4 My other car is a Suburban - slurrrrrrp! Eschew misoneism. |
My Car: 2004 Prius Model: Package: #2 Thanks: 0
Friends: 0 | [attachmentid=4246]Here is a view of the fuel tank and filler assembly. |
Friends: 0 | <div class='quotetop'>QUOTE(seasalsa @ Jul 25 2006, 11:23 AM) [snapback]291998[/snapback]</div> Quote:
From this, it appears that you'd have to fill the neck to the nozzle port to even get to the tube at the 9-o'clock position - the tube at 12-o'clock looks pretty well inaccessible. That answers my question. Thanks again! | |
| Here we go again, Prius Video on You Tube being discussed on another forum | priusmaybe | Prius and Hybrid News | 6 | 11-14-2007 08:24 PM |
| Fuel Vapor Car | jdjeep98 | Other Cars | 15 | 02-28-2007 08:31 AM |
| Over 100 mpg While Running on Fuel Vapor | Tideland Prius | Other Cars | 0 | 03-01-2006 08:39 PM |
| question: location of tank for rear window washer fluid | RMunroe | Gen II Prius Main Forum | 1 | 06-02-2005 05:54 PM |
| Fickle Fuel Gauge or Shrinking Fuel Tank? | goldenpanda | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 04-05-2005 03:44 PM |
