| This is a discussion on $900 single rear wheel bearing within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(galaxee @ Jul 31 2006, 05:47 PM) [snapback]295372[/snapback]</div> the left side shouldn't be affected... sounds like a ploy to ... |
| | #11 | |
| Senior Member Join Date: Nov 2004 Location: Northern CA
Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Jul 31 2006, 05:47 PM) [snapback]295372[/snapback]</div> Quote:
| | #12 |
| my other Mobile Suit is a ... Join Date: Feb 2005
Friends: 0 | Now, I just had my alignment done on a Hunter?: Front: -0.7 -0.8 before: Camber : -0.7 -1.4 before [range -1.3 0.2] 3.3 3.3 before: Caster : 3.2 3.2 before [range 2.4 3.9] 0.01 0.05 before: Toe : 0.00 0.02 before [range -0.10 0.10] 12.7 12.8 before: SAI : 12.8 13.6 before [range 11.8 13.3] 12.0 12.0 before : Included Angle : 12.1 12.1 before [range 10.5 13.5] 0.0 0.6 before : Cross Camber [range -0.8 0.8] 0.2 0.2 before : Cross Caster [range -0.8 0.8] -0.1 -0.7 before : Cross SAI [range -0.8 0.8] 0.01 0.07 before : Total Toe [range -0.20 0.20] Rear: -1.1 -1.1 before: Camber : -1.8 -1.8 before [range -2.0 -1.0] 0.35 0.35 before: Toe : 0.24 0.23 before [range 0.03 0.28] 0.7 0.6 before : Cross Camber [range -0.5 0.5] 0.58 0.58 before : Total Toe [range 0.05 0.55] 0.06 0.06 before : Thrust Angle So, Longo was telling me that the left toe being off is okay and won't cause tire wear, and I got that in writing. They also told me that because I'm at 55K miles I am beyond the 36K warranty, and Troy's extended warranty "supposedly" won't cover any repair work on axles and suspension, although the warranty link seems to actually specify otherwise. So, am I out of spec enough to bug Toyota and Longo to get my rear toe fixed with shim or new rear axle, or just leave it? Galaxee/DH? I appreciate any help on this. I don't mind my front toe so close to 0.0 instead of the 0.05 john1701 suggests, and it seems the guy who did the alignment left my steering pointing a couple degrees to the left when it was perfect after the steering recall. <_< |
| | #13 |
| Senior Member Join Date: Mar 2004 Location: USA
Friends: 0 | This price for this part new is $232.38, I just found it online for $185.90. http://www.trademotion.com/partlocator/ind...amp;catalogid=1 Nate |
| | #14 | |
| Senior Member Join Date: Jun 2005 Location: Bucks County, PA
Friends: 0 | <div class='quotetop'>QUOTE(200Volts @ Jul 31 2006, 06:56 PM) [snapback]295379[/snapback]</div> Quote:
| | #15 |
Friends: 0 | NuShrike, I had positive toe (OUT) that caused by failed rear wheel bearing. They way I'm reading your alignment you've put 55k miles with out of spec toe out. Mine failed shortly after this. If you hear a hum, then a wine from the back this is one of the bearings going bad. Jack up the rear of the Prius and spin the wheels, then if you hear any grinding noise, then you've got a bad bearing. It is very obvious if it's bad. |
| | #16 | |
| resident lab rat Join Date: Mar 2005 Location: south of lake Michigan
Friends: 26 | <div class='quotetop'>QUOTE(NuShrike @ Nov 10 2006, 02:53 PM) [snapback]347089[/snapback]</div> Quote:
| | #17 | |
Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Nov 10 2006, 06:24 PM) [snapback]347283[/snapback]</div> Quote:
Then, I'll probably just listen for bearing issues as 200volts suggested, and now think about tweaking the front toe in a bit, but then I'll just leave the rest alone... | |
| Front Wheel Bearing | Russell | Gen II Prius Technical Discussion | 17 | 02-27-2010 08:20 AM |
| Grinding noise 2005 Prius Sounds like Wheel Bearing | doa2mi | Gen II Prius Technical Discussion | 13 | 01-09-2010 10:45 AM |
| Wheel bearing needs replacing - how to avoid? | mikepaul | Gen II Prius Care, Maintenance and Troubleshooting | 22 | 12-16-2009 07:57 PM |
| Rear wheel alignment? | bwilson4web | Gen II Prius Care, Maintenance and Troubleshooting | 37 | 04-09-2009 11:45 PM |
| Rock in rear wheel | Syclone | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 09-23-2007 01:26 AM |
