This is a discussion on Battery display within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I came down a long hill today and the battery went to full charge, and then it turned from blue ...
Battery display
Old 08-20-2006, 06:25 PM   #1
sluggo42
sluggo42's Avatar
I came down a long hill today and the battery went to full charge, and then it turned from blue to green, is that normal?
sluggo42 is offline
Old 08-20-2006, 06:38 PM   #2
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
yep the top 2 bars turn the display green, from 3-6 they're blue and the bottom 2 are pink.
no need to worry.
galaxee is offline
Old 08-21-2006, 01:16 AM   #3
Bill Merchant
absit invidia
Bill Merchant's Avatar
Friends: 60
Talking
Perfectly normal like Galaxee said. Another thing you may have noticed with your all-green battery was the ICE running or starting and stopping frequently (on-off-on-off). That's normal too. When the battery gets a little over-charged, from going down a hill like you did, it may burn the excess by spinning the ICE without gas or spark.
Cool car, isn't it?
Bill Merchant is offline
Old 08-21-2006, 01:24 AM   #4
dragonfly
dragonfly's Avatar
Why would it spin the ICE when going down hill?
dragonfly is offline
Old 08-21-2006, 02:36 AM   #5
Bill Merchant
absit invidia
Friends: 60
Talking
<div class='quotetop'>QUOTE(Dragonfly @ Aug 20 2006, 10:24 PM) [snapback]306575[/snapback]</div>
Why would it spin the ICE when going down hill?[/b]
To get rid of the excess charge! Read carefully!
Spinning the ICE without gas or spark uses energy from the HV Battery. This lowers the charge of the HV battery to an optimal level. When you go down a long hill and your battery indicator shows all green, additional energy can not be stored safely (for the battery life), so excess energy generated through regenerative braking is sent to the ICE and wasted compressing air. If it's a really long hill, like coming down a mountain, at some point regenerative braking will stop and the brakes will act like any car's friction brakes. This is where B mode can help save your brakes some.
Hope this helps.
Bill
2007 NL 5 Silver Wraith 2005 BC 6 Silver Cloud
Portland Area HSD Meetup Group: PortlandHSD.info
Become carbon neutral: Carbonfund.org or TerraPass.com > < Follow me on
Old 08-21-2006, 03:34 AM   #6
hobbit
hobbit's Avatar
If they ever turn black, start worrying.
_H*
hobbit is offline
Old 08-21-2006, 03:43 AM   #7
Bill Merchant
absit invidia
Friends: 60
Talking
<div class='quotetop'>QUOTE(hobbit @ Aug 21 2006, 12:34 AM) [snapback]306603[/snapback]</div>
_H*[/b]
unc. ant.
Battery display does not turn green Hoser Gen II Prius Technical Discussion 7 09-27-2007 11:20 PM
Green Battery Display? Nicole Gen II Prius Technical Discussion 32 07-14-2007 08:26 PM
battery display how on your display duanerw Gen II Prius Main Forum 8 11-07-2005 03:01 PM
Battery Status Display; Never full? Here's why. RobertO Gen II Prius Main Forum 20 08-15-2005 09:06 AM
Color of bars in battery capacity display Tom Z. Gen II Prius Main Forum 12 07-17-2004 11:29 AM
