This is a discussion on Pushing Prius not possible if auxilliary battery is dead within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Recent experience with a dead auxilliary battery exposed the potential problem if the car is parked on the driveway i.e ...
Old 06-07-2004, 10:48 AM   #1
maxvok
Default Pushing Prius not possible if auxilliary battery is dead
Recent experience with a dead auxilliary battery exposed the potential problem if the car is parked on the driveway i.e . is shut down with the P button which cannot be unlocked manually if there is no power. You can not push the PRIUS on the street nor jumpstart it with [or use] your second car behind it.(unless they face each other on the driveway/garage and you have long jump cables). But I usually park both cars facing the street.
maxvok is offline
Old 06-07-2004, 11:35 AM   #2
glscheil1
Default Jump starting
This happen to me account door sensor for dome lite was faulty. Tow truck driver used his jumper cables attached to the 12 volt terminals under the hood. Then we could "unpark" it and push it out of my basement garage.
glscheil1 is offline
Old 06-07-2004, 11:38 AM   #3
Raenstoirm
I was questioning that as well. In a "real" car the gear release is a little switch near the shaft. Being electronic, I dont know how that would work. Just dont park illegally so that you have to be towed, because they could do some serious damage to your car.
Raenstoirm is offline
Old 06-07-2004, 12:51 PM   #4
mdacmeis
If needed, the 12v aux. battery, the one you would need to jump, is located below the right rear hatch storage depression (similar to the left, but does not lift up. You need to figure it out, kind of tricky first, but it unclips with a little effort. You can thus "jump" the car from behind. Keep in mind you only need to establish about 12 volts on the battery to get the car powered up. A remote jump start battery back works great for this, but any 12v power source will do the job.
mdacmeis is offline
Old 06-07-2004, 12:55 PM   #5
Friends: 41
Good point mdac...in fact, you can probably carefully attache the jumper cables without need to remove the battery at all.
I'd like to repeat advice I've given in the past...it's worth buying one of the rechargable multi-use jumper starter/work light/air compressor/aux. power supply units to at least keep in your garage if not in the hatch of the Prius. I got mine at Sam's Club for just over $50, I've seen them other places for as little as $44 and up to around $90...if you really want to spend more.
Evan E. Fusco, MD
efusco is offline
Old 06-07-2004, 02:16 PM   #6
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
Keep in mind that the rear hatch is electronically released. Unless you crawl in and find the manual override under the floor, you won't be opening the rear hatch to access the battery. That's probably one of the several reasons that a jump point was provided under the hood - since the hood is accessible by opening the driver's door with the manual key and then popping open the hood via the manual release.
HTMLSpinnr is offline
Old 06-07-2004, 03:17 PM   #7
maxvok
I know from my latest experience how to start the car if the battery is dead but the point I was trying to make is that if you are in a hurry and cannot wait until the emergency service arrives, the most simple solution, using your second car, is not possible. :wink:
maxvok is offline
Old 06-08-2004, 11:45 AM   #8
rockluvr
Are you saying that if you unlock the driver's side door with your key and then press the unlock all doors button on the driver's side door, that it will not unlock the doors and hatch so that you can open it manually?
Sorry for my simplistic question - just not that car savvy.
rockluvr is offline
Old 06-08-2004, 11:50 AM   #9
HTMLSpinnr
HTMLSpinnr's Avatar
Friends: 18
The power locks depend on the 12V battery, so no, it would not unlock.
Also, the rear hatch release is entirely electronic. Lifting the handle is only activating a switch which triggers a solenoid at the base of the hatch floor (not in the door). This also depends on the 12V battery.
If the 12V battery is dead, you're left using the methods mentioned above.
I think the owner's manual mentions how to get it opened manually - probably in the "in case of emergency" section.
Old 06-08-2004, 01:00 PM   #10
aarons12
i second (third?) the portable battery jumper/air compressor/light units. i got mine at costco a couple of years ago and it has saved us a number of times. we have 5 total cars and over the course of the year i have probably used it at least 8 times (mostly on my classic avanti, which sits for long periods. though i finally got a computerized trickle charger that solved that issue)
aarons12 is offline
New 2007 Prius, dead battery alibaba Gen II Prius Main Forum 50 09-11-2009 04:45 PM
Inactive Prius = Dead Battery? NYCPRII Gen II Prius Main Forum 3 04-24-2006 03:37 PM
What would happen to Prius with dead battery pack? etyler88 Gen II Prius Main Forum 22 02-09-2006 02:57 PM
Auxilliary Battery/ Substitute andyprius Gen II Prius Care, Maintenance and Troubleshooting 30 03-22-2005 11:23 AM
Flat auxilliary battery after 800 miles maxvok Gen II Prius Care, Maintenance and Troubleshooting 15 06-10-2004 07:18 PM
