This is a discussion on Accelerator Problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just decided to post this on here to get an advice on how to handle this situation. I just ...
Accelerator Problem
Old 09-29-2006, 05:34 AM   #1
XJASPX
I just decided to post this on here to get an advice on how to handle this situation. I just want to start off by saying that the Prius I own is AWESOME and its the best car I ever owned... however, in the past three days, the accelertor got stuck not once, but twice. First time it got stuck was when the light turn green, I steped on the accelerator and the car took off and I had to manuver the car through traffic while trying to get the car to stop which I did by hitting the breaks and reaching down and used one of my hand to pull up the accelerator. I thought that was a fluke and thought that it could just be the Toyota Prius All Weather floor mat so I removed it... tonight, it happened again, but as I was getting onto highway 5.. the floormat was removed and there was nothing obstructing the accelerator and the same thing happened, knowing how to resolve the issue, I just gently step on the breaks to slow down the car than quckly put my feet under the accelerator to get it unstuck and than the car started to act normally again... As soon as I got to where I was going, I took a look around the floor of the driver side to see what could of cause it to get stuck and it was clean. I am clueless as to what could of happen, the car does have alittle over 30,000 miles on it. I'm going to try and get it into the shop ASAP, however, like always, its about a week wait before I can actually get it into the shop because the dealership here MUST go by appointments and no walk up. Anyways, has any one encounter similar situations and how was it handled? Should I submit it as a potential safety hazzard to the address in my manual? Any advice would be awesome! Thanks!
XJASPX is offline
Old 09-29-2006, 08:46 AM   #2
SomervillePrius
Wow that sounds pretty serious. If it happens again just hit the gear shift level into "N"eutral. The engine will probably rush but at least you will be safe (the engine will not be harmed). That way it should be easier to slow down.
Oh! and take it to the dealer right away!
SomervillePrius is offline
Old 09-29-2006, 09:21 AM   #3
eagle33199
Platinum Member
Definately take it to the shop... with only 30k, you're still under warrenty, so it really should be covered for you.
eagle33199 is offline
Old 09-29-2006, 09:36 AM   #4
Ari
Ari's Avatar
If the problem is that severe, maybe you should take it to your dealer now - regardless of their 'policy'. (If I have a broken leg, do I wait a week to have it looked at?) Or.... find a better dealer!
Ari is offline
Old 09-29-2006, 10:48 AM   #5
seasalsa
seasalsa's Avatar
There is more than one Toyota dealer in Sacramento. Try another, your warranty is good anywhere.
Don't wait! This sounds like a sasfety issue.
seasalsa is offline
Old 09-29-2006, 11:01 AM   #6
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
wow. Sorry your first post had to be an issue. Welcome to Priuschat btw!
Definitely take it in if it's sticking. I was going to suggest the floormats but you've already got it covered.
Tideland Prius is offline
Old 09-29-2006, 09:01 PM   #7
XJASPX
<div class='quotetop'>QUOTE(Tideland Prius @ Sep 29 2006, 10:01 AM) [snapback]325573[/snapback]</div>
THANKS!
just as an update, I called every Toyota dealership today in Sacramento area from Elk Grove to Folsom to Roseville and only MAITA Toyota said its ok to take it in today. The service advisor said he is clueless as to what could of cause it though admit that the first generation model had similar problems but the car should of came to a slow stop instead of accelerating. Now of course, I did get the whole "we can't fix it unless we can recreate the problem" speech but I think they can recreate it since the first and second incident happened within 3 days of each other with only about 75 to 100 miles of driving between the 2 incident. Anyways, thanks for the feedback and I'll post updates here for anyone else that is having similar problem or experience this type of problem in the future.
XJASPX is offline
Old 09-30-2006, 09:33 AM   #8
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
The only Prius accelerator problem similar to what you describe has happened when the carpet mat got loose and interfered with "pedal action'. Unlikely that this is your situation but maybe give it a check.
There are springs in the mechanical part of the pedal and if they were broken (boy does that sound unlikely), it might not 'return' with your foot lifted.
tochatihu is offline
Old 09-30-2006, 10:54 AM   #9
Frank Hudon
<div class='quotetop'>QUOTE(tochatihu @ Sep 30 2006, 06:33 AM) [snapback]325991[/snapback]</div>
Did you move?
Frank Hudon is offline
Old 09-30-2006, 03:46 PM   #10
XJASPX
Just a update... The dealership called today and they said that its the floormat's fault and that they "reset" the floormats and that should fix it.... they can not find anything wrong with the accelorator itself... I guess the 2nd time it happened WITHOUT the floormat was just my imagination as I was going down a busy freeway. I guess I can have them recheck it if it happens again when the car is going back to the shop to have the dashboard replaced (the dashboard is warped on the passenger side, I told them to check the glove compartment since that could be causing it but I just think they didnt read the repair order since their not replacing the glove compartment).
XJASPX is offline
Accelerator Pedal Fedback? 7lions Gen II Prius Technical Discussion 11 10-20-2006 06:41 PM
Stuck Accelerator Oregon-Mica Gen II Prius Main Forum 11 04-07-2006 02:25 AM
Google releases Web Accelerator TonyPSchaefer Fred's House of Pancakes 3 05-08-2005 12:44 PM
Anyone else had the accelerator pedal 'stick'? mikepaul Gen II Prius Main Forum 4 03-25-2005 11:58 AM
Accelerator pedal problem 2001 prius av_in_bc Gen II Prius Main Forum 3 12-20-2004 02:37 PM
