This is a discussion on Where is the DVD for the Nav System within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; About two weeks ago, my nav system crashed (I input a destination at a stop light and hit the button ...
Old 10-03-2006, 11:12 PM   #1
karat
About two weeks ago, my nav system crashed (I input a destination at a stop light and hit the button an instant before accelerating), but it came back after I turned off the car and turned it back on again.
Tonight it went out again, but it failed to restart after being off for 3 hours. It says to check the DVD.
Where is the DVD? Is it in a format that can be read by my laptap? What else can I do to check things?
karat is offline
Old 10-03-2006, 11:55 PM   #2
brandon
brandon's Avatar
The DVD deck is located underneath the driver's seat. Don't know what it would do in a computer system; probably nothing. Have the dealer check it out if you want.
brandon is offline
Old 10-04-2006, 12:41 AM   #3
Bill Merchant
absit invidia
Bill Merchant's Avatar
Friends: 60
Talking
Hi karat, welcome to PriusChat. As brandon said, the Nav system is under the driver's seat. Slide the seat all the way forward and go in from the back seat. There's a cover to remove and a button to push to eject the DVD.
You can read some of the data files off the DVD, but they are mostly gibberish, being in a proprietary format for the Nav computer. This is a new car, right, so just have the dealer fix it.
Bill Merchant is offline
Old 10-04-2006, 02:31 AM   #4
orionll
orionll's Avatar
Yeah what the last 2 people said, under the driver seat. And I'm not sure how you can check it. You might want to take the DVD and or the car to the nearest TOYOTA dealer to ask for help.
orionll is offline
Old 10-04-2006, 12:13 PM   #5
karat
I just want to try the obvious stuff myself, like ejecting and reinserting the DVD.
Also, if my laptop can detect the files on the DVD, then that means the DVD isn't completely unreadable. I suppose only a portion might be unreadable, in which case, copying all the files would check for that. However, if the file system is in a proprietary format, then I might not be able to read the DVD at all. I just want to figure out if putting the DVD in my laptop will be able to determine if the DVD is readable.
karat is offline
Old 10-04-2006, 12:40 PM   #6
Tom_06
Tom_06's Avatar
<div class='quotetop'>QUOTE(Bill Merchant @ Oct 4 2006, 12:41 AM) [snapback]327714[/snapback]</div>
To add a little to Bill's info: on my 2006, after you take the cover off, you push the button and slide the button to the left. This opens the slot where the DVD will eject. The car has to be in ignition on or ready to then eject the DVD (hold the button down). When you reinsert the DVD, push it into the slot, then push the botton and move it to the right after the DVD disappears into the unit. Then put the outer cover back on.
- Tom
Tom_06 is offline
Old 10-04-2006, 05:32 PM   #7
Bill Merchant
absit invidia
Friends: 60
Talking
If the DVD worked once, i.e., you used the Nav system and saw a map, it is really doubtful there is anythig wrong with the DVD itself. It's in an enclosed, protected drive, so it can't get scratched, making data reads difficult. It's much more likely that a plug someplace is loose. Or that the MFD is in early failure. When you're down there playing with the eject button (sorry I forgot to mention that the car had to be powered) you might try wiggling and pushing on all the connectors you can find to make sure they are tight. Of course, the other end, on the backside of the MFD, could be the problem location too.
The data files on the DVD are readable as text files, just like you can "read" a jpeg image as a text file. The proprietary part is how GPS data is related to map images is related to POI, and so forth.
Take it to the dealer...
Bill
2007 NL 5 Silver Wraith 2005 BC 6 Silver Cloud
Portland Area HSD Meetup Group: PortlandHSD.info
Become carbon neutral: Carbonfund.org or TerraPass.com > < Follow me on
Old 10-04-2006, 05:40 PM   #8
Tom_06
Tom_06's Avatar
<div class='quotetop'>QUOTE(Bill Merchant @ Oct 4 2006, 05:32 PM) [snapback]328109[/snapback]</div>
<snip> ... Take it to the dealer...
Oops, I didn't read the original post. Bill's right. My 2006 did the same thing at 3 months old. In my case, I couldn't eject the DVD, the dealer couldn't eject the DVD, and they ended up replacing the whole NAV unit under the seat along with a new DVD. Took two weeks for them to get the parts - one week for the NAV and another week because they didn't order the DVD (duh! they aready knew they couldn't eject it).
Oddly enough, mine would die with the "can't read DVD" message only when the weather was warm to hot. This was in early spring. On a cold morning, the NAV would work until things warmed up. Still wouldn't eject the DVD though.
- Tom
Tom_06 is offline
Old 10-05-2006, 08:49 AM   #9
Inthewind
Inthewind's Avatar
My .02$: I'd take it to the dealer. Why mess with something that is still the responsibility of Toyota to keep working?
Inthewind is offline
Old 10-05-2006, 09:16 AM   #10
DanMan32
Well, the DVD is a user replaceable item, and it would be silly to have to bother the dealer if all the problem is is a dusty DVD. When I upgraded the DVD via the recall, I was able to work with the service rep to remove/install the DVDs myself, and physically exchange DVDs with him, rather than waste time logging a service call, wait for a tech to become available, have them swap out the DVD (and possibly waste time figuring it all out), then logging the car out and getting it back to me, which would have been a minimum of 1/2 hour. So I do understand an owner checking things out themselves first. But most likely it is a problem with the NAV ECU, which would be a situation to bring up with the dealer.
I doubt it would be the MFD, if no other systems are having problems.
DanMan32 is offline
Nav System Alnilam Gen II Prius Audio and Electronics 4 12-01-2006 02:34 PM
Nav system jeffrotay Gen II Prius Main Forum 2 07-06-2005 06:42 PM
a/c system nhalber Gen II Prius Fuel Economy 2 05-07-2005 01:31 PM
NAV system for $130 IF... DaveinOlyWA Gen II Prius Audio and Electronics 1 09-20-2004 09:50 PM
Am I in the system? Raenstoirm Gen II Prius Main Forum 10 04-14-2004 09:01 PM
