| This is a discussion on 06 with 5k miles has an oil drip - anyone else seen this? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello, I was under my 2006 Prius this weekend doing its first oil change and I noticed a small oil ... |
Friends: 0 | Hello, I was under my 2006 Prius this weekend doing its first oil change and I noticed a small oil drip coming from the underside of the engine. The oil level before the change was fine, and the leak appears to be small, but at 5K on a "green" car, I would not expect any leakage at all. The drip appears to be coming from a gasket where the engine casing comes together. I know they say the engine takes some time to "seat" itself while the new componenets break in, so I'm really hoping this is the case here... perhaps it will go away. I have an appt at the dealership next week for them to take a look and see what they think. I was wondering if anyone else noticed this when they were under their Prius... I have never seen a drip of oil on the driveway, so I think it might very slowly weap out at highway speed and then blow back, but never weeps enough to cause a drop on the ground.... Its very easy to spot by looking under the car.. its the main part of the engine in the middle of the car... there is an orange gasket that looks like it was caulked on at the factory. I have a picture of it attached.... please let me know if anyone had a similar issue... I will report back when I talk to the dealer next week and let you know what they tell me. |
| Senior Member Join Date: Aug 2006 Location: San Diego, CA
My Car: 2006 Prius Model: Package: Base Thanks: 0
Friends: 0 | Thanks for posting a picture. How about if you collect some more information? If you can reach the oily area, wipe it clean with a paper towel and then track it from there (ie. drive it for a week and see what happens.) Has the level of the oil dropped when measuring with the dipstick? In the beginning of your post you call this a "drip", but then later you say you have never actually seen a drip on your driveway or on the engine. In the photo there is no drip either, although there's obviously a film of dirty oil over a large area. BTW, I've had oily spots like this on almost all cars that I've owned. Nothing on my 06 Prius yet, though. Let us know what you find out! |
Friends: 4 | <div class='quotetop'>QUOTE(MaineJenny @ Oct 16 2006, 10:22 AM) [snapback]333412[/snapback]</div> Quote:
| Senior Member Join Date: Aug 2006 Location: San Francisco, CA
My Car: 2006 Prius Model: Package: #9 Thanks: 0
Friends: 0 | <div class='quotetop'>QUOTE(MaineJenny @ Oct 16 2006, 10:22 AM) [snapback]333412[/snapback]</div> Quote: My '06 has 1500 miles on her and I haven't noticed this sort of leak. Have you added oil to the car? Perhaps a teensy bit spilled, then slowly found its way down to where it is now...? Either that, or I'd suspect something leaking higher up; but what that is I can only guess. I don't think you should have to wait for the gaskets to seat as you've suggested, though. I think that's only true for Fiats and older Harleys. |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 33
Friends: 0 | <div class='quotetop'>QUOTE(MaineJenny @ Oct 16 2006, 08:22 AM) [snapback]333412[/snapback]</div> Quote:
Friends: 0 | That just looks dirty, not "oil-y" to me, I'd suggest cleaning it with some 409 or whatever degreaser you like and see if it comes back. I tend to think that if you are not seeing oil drops on your driveway or garage, and the oil level is not dropping in 5K miles, then you have nothing to worry about. |
Friends: 0 | I was just rereading thru this and noticed you saw this after your first oil change. Could be from changing the oil filter, some splatter from not wiping off the pan, or some spillage from refilling the oil. Either way, the same suggestions apply (clean it off and see if it comes back, keep an eye on your oil level), and probably not a big deal. |
Friends: 0 | Doing your own oil changes??? I gotta ask. What on earth for?Paul |
Friends: 1 | <div class='quotetop'>QUOTE(Liberanos5 @ Oct 17 2006, 09:32 AM) [snapback]333882[/snapback]</div> Quote:
By doing your own oil change, you make sure that everything is done right. I personally enjoy taking care of my baby with my own hands and enjoy the entire process. | |
Friends: 0 | <div class='quotetop'>QUOTE(Liberanos5 @ Oct 17 2006, 06:32 AM) [snapback]333882[/snapback]</div> Quote:
__________________ Tom | |
| Toyota Fuel-Cell Logs 2300 Miles In Seven Days, Averages Well-Above 300 Miles Per Tank | Danny | Prius and Hybrid News | 21 | 11-29-2007 11:58 AM |
| Drip - Brown Fluid by Emergency Brake Pedal | Howard | Gen II Prius Technical Discussion | 2 | 11-05-2006 10:30 PM |
| Water Drip | mouztrpd | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 07-19-2005 07:33 PM |
| CPU updates @ 5,000 miles & 10,000 miles - Mileage chngd | Ken Cooper | Gen II Prius Fuel Economy | 2 | 09-09-2004 01:19 PM |
