This is a discussion on Goodyear Integrity Mileage within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; With winter coming...Pennsylvania...I replaced mine at 23.5k with tread at 3/32"...
View Poll Results: Goodyear Integrity Mileage
5000-9999 miles 8 4.06%
10,000-14,999 miles 6 3.05%
15,000-19,999 miles 6 3.05%
20,000-24,999 miles 27 13.71%
25,000-29,999 miles 26 13.20%
30,000-34,999 miles 42 21.32%
35,000-39,999 miles 20 10.15%
40,000+ miles 62 31.47%
Voters: 197. You may not vote on this poll
LinkBack (1) Thread Tools
Old 12-21-2008, 03:25 PM   #71
lenjack
Default Re: Goodyear Integrity Mileage
lenjack is offline
Old 12-23-2008, 10:01 AM   #72
fgoodyear
07 Prius, package 6. Goodyear Integrity's are junk. Edges worn before 20k totally gone by 30k. Toyota replaced them @ 30k for free but wouldn't admit any problem. I went with the Yokohama tire. I have 13k on them and no visible wear at all. I did all the right things, rotation every 5k, pressure of 44 on all tires. I checked online after Toyota offered either Integritys or Yokohamas and the rating on the Yokohama was 100% better than the Integrity in all catagories. As you can see my last name is Goodyear, but........... I wouldn't recommend these Goodyear tires
fgoodyear is offline
Old 03-21-2009, 04:41 PM   #73
Dirtnapper
Dirtnapper's Avatar
I am having the same issues with the bicycle tires (Integrity) that came with our 07 Prius. About 32K the front were showing edge wear; need to replace them soon, like maybe next week. I inflate to 38 and 36 respecfully and rotate at every oil change. What crappy tires, I really thought they would do better than that.
Dirtnapper is offline
Old 03-21-2009, 06:52 PM   #74
sdtundra
sdtundra's Avatar
I'm getting uneven wear on the fronts approaching 20k miles. Will be having the alignment done at the same time as the oil change, which will hopefully aleviate the wearing. They've been rotated every 5k and inflated to 42/40
sdtundra is offline
Old 03-22-2009, 02:03 PM   #75
fgoodyear
Mine started wearing on the edges @ 15K, badly worn on edges by 25K, replaced free by Toyota @ 30K. Tires were rotated religiously every 5K. Ran 42-44psi on all tires. As far as I am concerned, The Goodyear Integrities are junk. Had a choice of tires @ replacement. Either the Goodyears again or Yokohama Avid's. Took the Yokohama's. They now have 16K and show almost NO wear. and no fuel mileage difference.
Old 03-22-2009, 04:03 PM   #76
sandman
sandman's Avatar
Mine are at 35,000 miles and look great. I have rotated them every 10,000 and ran 50psi front, 48psi rear.I hope they can make it until December(they should be around 50,000) then I can get a new set just in time for winter. Another note they done great in the snow, I have been real pleased with them so far..
sandman is offline
Old 03-22-2009, 06:44 PM   #77
bwcgrx
Hey fgoodyear what model of the Yokohama Avid's do you have?
I'm considering the TRZs in the Yokos. I've gotten almost 41,000 miles on my stock GY Integrities but they need to be replaced soon. I'm down to the last 2/32 on three of the tires but my dealer won't budge on replacing them on the Extended Mile Warranty because that fourth tire still has 3/32 on it. If I could get that last 32nd off the other tire I could get them replaced free + Alignment charge. My dealer only offers 3 tires for the warranty replacement, the Integrity, Michelin Primacy (At nearly $190 per tire -$80 per tire integrity warranty value $110 per tire No Way), or some low end tire which seems to have no brand name.
I think I'll just bite the bullet and buy the Yokohama TRZs online myself, I also like the Pirelli Cinturato P5 but can find little in the way of reviews or info on this tire.
bwcgrx is offline
Old 07-02-2009, 11:35 AM   #78
Sol Himmelstein
Same here. Mine are at 47,000 and are in good condition. I should have a little over 50K by the time I need to replace them in November. I also recommend rotating the tires at oil changes, but if 10K works, go with it. My Prius is a 2008 and I have some winter weather to contend with here in Virginia. I am 42 front and 40 rear. and have avg. 53 mpg.
Sol Himmelstein is offline
Old 07-11-2009, 12:25 AM   #79
ggcc
Originally Posted by Tideland Prius View Post
Well I just changed out my Integritys at 68,000km/42,500miles.
Never thought I'd reach the last poll option in my poll lol but I made it past 40,000 miles somehow. The edges were bald as heck and the middle probably has 3/32nds since the wear bars are quite close to the tip of the tread blocks.
I have exactly the same like your (edges were bad and middle about 3/32" left). I searched for the picture the wear pattern this indicated that I have low pressure. I always rotate tires front to rear every 5K (3 months) and check tire pressure 37/35. I really think the tire gauge is incorrect display (digital) because I can see by my eyes it looks low pressure. I will find another tire pressure gauge to compare.
BTW. the original tires set is at 62K miles, and 52-56MPG
I am looking for a new set of tires soon.
Ok, I just replaced my OEM Goodyear stock Integrity tires (they last 62K miles) with Michelin x Radial. The new Michelin tires much quiet and good handling. I hope they will not decrease in MPG.
Thanks,
ggcc
2007 Prius:
Oil Filter: 90915-YZZF2
Michelin X Radial (rated at 80,000 miles) replaced @ 62K Miles (07-13-2009)
CVT 4 quarts drain and fill at 62K miles (07-17-2009)
Error Code: P2401 replace Cannister Pump at 68K
2006 Prius (Daughter's car toyotaownersonline.com sn 1234abcd):
CVT WS 4 quarts drain and fill at 126.5 K miles (08-25-2009)
2007 Sienna Transmission fluid Drain & Fill 4.5 Quarts Replaced at 22K miles (07-17-2009)
ggcc is offline
Old 07-13-2009, 02:54 PM   #80
PasPrius
PasPrius's Avatar
Model: V
Package: Navigation
I recently changed out the Goodyear Integrities with just under 25,000 miles for Goodyear Assurance Fuel Max tires. The Integrities were badly worn on the edges all around and almost down to the wear marks.
Got a nail through one of the new Fuel Max Tires and took it back to Discount Tires for repairs. I mentioned to the manager that the Fuel Max tires rolled better and got better gas mileage and that I hoped they would last longer. He said that they change out a lot of Integrities because of the edge wear problem. I asked if this was due to the slightly heavier left front weight distribution on the Prius and he said, no, they saw it on all makes and models regardless of rotation or care. The rubber on the edges of the Integrities just is not up to the task in his opinion.
I run 42/40PSI.
PasPrius
If we do not invent the future,
others will do it for us. B5
PasPrius is offline
goodyear, integrity, mileage
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/24877-goodyear-integrity-mileage.html
toyota_prius: Goodyear Tires Kaput at 40K Miles?! This thread Refback 02-02-2008 10:43 PM
FS: One Goodyear Integrity Tyre Tideland Prius Private Sales 3 12-03-2007 12:56 AM
Wanted: One Goodyear Integrity (185/65 15) uclabruins Local Prius Club Main Forum 2 10-29-2007 03:14 PM
Goodyear Integrity Tires Marvinh Gen II Prius Main Forum 7 10-28-2007 03:37 PM
OEM Goodyear Integrity set of 4 tires for sale rufaro Private Sales 0 01-31-2007 11:10 AM
Goodyear Integrity OEM tires. wb9tyj Gen II Prius Care, Maintenance and Troubleshooting 10 11-21-2004 01:13 PM
