| This is a discussion on How do I replace the headlight assembly? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; So I'm driving down the highway to the hospital to meet my wife who just went into labor and WHAM ... |
| | LinkBack (11) | Thread Tools |
#1 |
Friends: 0 | So I'm driving down the highway to the hospital to meet my wife who just went into labor and WHAM - something hits the front end of my car (drivers side) and bounces off the headlight. Later on (and one baby boy later) I look at the light and see that it is deeply scratched and the interior plastic is broken along with a burnt out turn signal. I purchased a used headlight assembly (ebay) but how in the heck do I get the old one off? I took out the two 10mm screws holding it on but it won't budge....anyone have any experience with this? |
Friends: 0 | <div class='quotetop'>QUOTE(rocketman7 @ Oct 25 2006, 11:02 PM) [snapback]338388[/snapback]</div> Quote:
| Senior Member Join Date: Jan 2006 Location: Washington State
Friends: 0 | <div class='quotetop'>QUOTE(rocketman7 @ Oct 25 2006, 06:02 PM) [snapback]338388[/snapback]</div> Quote:
Do you have a self leveling system in your headlights? If so, this adds to the complication of R&R becaused that must be reset and readjusted. Remember when you reconnect the battery you will need to perform an Initiaization. You will also need to restore any electronic instructions you have given to the car such as "beep" removals as they will return to the their default settings. Are you sure that the headlight you purchased matches the one on the other side of your car? I am referring to the light it makes not the fit to the car even though they both matter. By the way Congratulations on the new baby boy!!!!!
__________________ White 2006 Package 8, clear bra, block heater, ScanGuage, Highlander side mouldings | |
Friends: 0 | I take back what I said about this should be a simple repair. Remind me to be really careful with my headlights. I replaced one on my Tundra, it seemed to almost snap in. Well, actually that procedure doesn't sound that bad, but definitely more like "free afternoon" than "spare 20 minutes." Do you have to go back to the dealer for the HID levellling setup, or can that be done by a DIYer without special tools? I'm interested becuase I seem to need a windshield or headlight lens at least every other year on one of our cars. |
| | #5 | |||
Friends: 0 | <div class='quotetop'>QUOTE(Beryl Octet @ Oct 26 2006, 06:56 AM) [snapback]338546[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(Allannde @ Oct 26 2006, 10:05 AM) [snapback]338659[/snapback]</div> Quote:
Thanks - the boy is doing great! <div class='quotetop'>QUOTE(Beryl Octet @ Oct 26 2006, 10:20 AM) [snapback]338676[/snapback]</div> Quote:
Friends: 26 | you have to take the fender liner out. then there is a screw near the edge of the bumper in the fender, that holds the bumper cover to the fender. take that screw out. then you can pop the bumper cover out away from the fender, and there will be a 3rd 10mm bolt there. take that out too. next step, unplug all wire from it and CAREFULLY slide it out. don't force it, but it won't just slide off like nothing. you're supposed to remove the whole bumper cover but that's a huge affair and you can get away with this. i think you should be able to get the rest from there. congrats on the new son! let us know how the replacement goes.
__________________ black 2005 prius, a few mods that make me happy g: class of '09 in intense science DH: class of '09 in medical equipment hoping to discover the 'reward' part of the sacrifice-reward cycle soon! |
Friends: 0 | I believe it's possible to get at the third headlight-assembly bolt by simply loosening enough of the fender-liner and the big plastic front schnoz piece to pull them slightly aside. We did this at the last tech-training thing; it was actually fairly fast. But you do have to get behind there just enough to unbolt it. . Experienced auto techs are good at finding all kinds of shortcuts for only partially loosening things that are in the way and shifting them aside, but at the occasional expense of bending them in funny ways. My own LHS fender-liner got a little mangled a month or so ago when one of the trainees *really* wanted to have a look at the thermos bottle and he was somewhat ham-handed... it's only plastic, but some guys aren't quite as careful as they should be. . _H* |
Friends: 0 | Well, I finally got around to replacing the headlight assembly (long work days and nights caused the delay). As previously suggested, partially removing the bumper did the trick. It was a little bit of a pain to switch the bulb, but after fumbling with that for a while it's switched out too. After putting it all back together, it looks great. The only question now is what's the best way to adjust the beam. There is a 'thumb' screw but other than pointing the car at a wall I don't know of any other way. Thanks again to those who helped, Sam |
| tail light assembly | ariggan | Gen II Prius Main Forum | 1 | 09-18-2007 11:04 AM |
| HID Head Light Assembly $225 | brighamwj | Private Sales | 0 | 08-23-2007 03:12 PM |
| Dome light assembly removal | eldaveed | Gen II Prius Main Forum | 5 | 05-01-2007 02:18 AM |
| Replacing Rear Lamp Assembly - dangerous? | bryantpe | Gen II Prius Main Forum | 4 | 04-05-2007 04:12 PM |
| Assembly line pics | dstrout | Gen II Prius Main Forum | 7 | 07-19-2005 12:38 AM |
