| This is a discussion on Time Change within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; How can I change the arrival time? When I've entered a destination I like to have the arrival time listed. ... |
Time Change
| Member Join Date: Sep 2006 Location: Maryland
Friends: 0 | How can I change the arrival time? When I've entered a destination I like to have the arrival time listed. Only daylights savings time has come and gone and it still has not updated. Is there a way I can do this? |
Friends: 23 | You mean the arrival time actually shows the true clock time that you will arrive? Is that new to the updated GPS? I must have missed that. I think mine just has a count-down in hours and minutes. Are you sure you are not mistaking the count-down for the arrival time? Can you take a picture? Something showing the regular clock, the travel-time and the arrival-time? I would just like to see that. |
| Senior Member Join Date: Oct 2005 Location: Germantown, MD
Friends: 1 | The GPS/Nav unit does both. Set one way, it shows time to arrival (ie, you'll arrive in 32 minutes (shown as 0:32)), and the other way it shows arrival time (ie, you'll arrive at 8:32pm). Touch the display there and it should toggle back and fourth. (*) However, the clock doesn't seem, to switch into/out of daylight savings time on it's own. Either it's not supposed to, or it's supposed to and doesn't work right. As a result, as the OP indicated, it's suddenly an hour off on all arrival times. There's a setting, buried within the menu's, to manually toggle DST on/off, and that's where you need to go to fix it. I last did it in the spring, so I don't remember the exact path - however I need to do it again, as of the fall time change it's an hour off again. (*) 2006 Package 7. -Ken
__________________ 2006 Black Package #7 Dark Grey Interior Headlight Flasher EV Mod |
| Date and time change not synced outside of Eastern Time? | aforkosh | PriusChat Website Questions | 7 | 11-04-2009 12:58 PM |
| Change Time in Nav System | njnick | Gen II Prius Audio and Electronics | 5 | 11-07-2007 07:32 PM |
| Anyone know how to change the time in the NAV system? | pbeaule | Gen II Prius Audio and Electronics | 10 | 11-06-2007 06:40 AM |
| Gasoline use up 2.8% since early time change | hb06 | Gen II Prius Fuel Economy | 6 | 04-08-2007 10:54 AM |
| TIME CHANGE??? | DaveinOlyWA | PriusChat Website Questions | 16 | 04-16-2004 01:15 AM |
