| This is a discussion on Rear Window Defroster within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I bought a used 2004 Prius, and now that the weather's cold I noticed that the rear window (electric) defroster ... |
Friends: 0 | I bought a used 2004 Prius, and now that the weather's cold I noticed that the rear window (electric) defroster doesn't work. I checked all of the fuses in the under the hood fuse compartment -- all seem good. Could the defroster itself be open circuit? Only 20K miles. |
| Progressive Member Join Date: May 2004 Location: Southern California
My Car: 2005 Prius Model: Package: #6 Thanks: 3
Friends: 0 | At 20,000 miles, the car should still be under the original factory warranty. It could be any number of things that may be causing it, including a loose connection or damage to one of the painted heating elements on the glass. |
Friends: 0 | <div class='quotetop'>QUOTE(IsrAmeriPrius @ Dec 4 2006, 07:45 PM) [snapback]357690[/snapback]</div> Quote:
thanks for your reply to my post. I have access to some electrical measureing equipment. Do you know how I could get info. on where the connections are, and the spec. resistance of the defroster? | |
Friends: 0 | <div class='quotetop'>QUOTE(John Wagner @ Dec 4 2006, 04:41 PM) [snapback]357686[/snapback]</div> Quote:
Do the defrosters (defoggers) for your outside review mirrors work? I would suspect a loose connection before a broken defogger. Dave M. | |
Friends: 0 | <div class='quotetop'>QUOTE(dmckinstry @ Dec 4 2006, 07:54 PM) [snapback]357695[/snapback]</div> Quote:
DO'H. I didn't know I had side mirror defrosters! Are they turned on by pressing the same button on the touch screen as for the rear window defroster? I guess I'll have to start plowing through the oversized owner's manual! | |
Friends: 0 | <div class='quotetop'>QUOTE(John Wagner @ Dec 4 2006, 04:50 PM) [snapback]357691[/snapback]</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(John Wagner @ Dec 4 2006, 05:36 PM) [snapback]357709[/snapback]</div> Quote:
Good luck on finding the "break". IsAmeriPrius knew where the connectors are. I think the defogger itself would be okay as long as it doesn't have infinite resistance. I have the wiring diagram, but finding anything in it is daunting, and I haven't looked for this particular item yet. Dave M. | |
Friends: 0 | <div class='quotetop'>QUOTE(dmckinstry @ Dec 5 2006, 12:21 PM) [snapback]357995[/snapback]</div> Quote:
Thanks everyone for your help. I'll check it out. By the way, I noticed when checking the fuses that some of the labeling is quite cryptic, making it a little difficult to tell what fuse is for what. Is there documentation available to the end user which spells this out a little more clearly? | |
Friends: 0 | <div class='quotetop'>QUOTE(John Wagner @ Dec 5 2006, 09:47 AM) [snapback]358008[/snapback]</div> Quote:
Dave M. | |
| Rear Window | Mary Snyder | Gen II Prius Main Forum | 7 | 09-07-2006 02:28 PM |
| rear window defroster | darwin100 | Gen II Prius Main Forum | 4 | 11-25-2005 10:14 PM |
| rearview lens and window defroster | Bob Allen | Gen II Prius Modifications | 1 | 06-15-2005 07:40 AM |
| Hey, that's My Rear Window! | jimofdg | Other Cars | 0 | 09-17-2004 04:20 PM |
| Rear defroster trivia | jamarimutt | Gen II Prius Main Forum | 6 | 08-04-2004 09:00 PM |
