This is a discussion on 2002 Stalling within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have had a stalling issue off and on for quite some time now. Every once and a while when ...
2002 Stalling
Old 01-14-2007, 11:42 PM   #1
marussell
Every once and a while when I startup in the morning I hear the engine spinning up for about 5-10 secs then it stalls out and I get the triangle of death. I remove the key and try again and it usually starts right up.
The code is always "Engine did not start". Any ideas?
marussell is offline
Old 01-17-2007, 04:23 AM   #2
jayman
The car must have stored diagnostic codes if the Triangle of Doom was on. What codes did you retrieve??
jayman is offline
Old 01-17-2007, 09:23 AM   #3
marussell
Happened again last morning. It's about 10-19 degs here but that should not cause this and it has done it when it's hot out also.
Anyone have any ideas?
Old 01-19-2007, 08:15 AM   #4
marussell
Code was "Engine did not start"
Old 01-19-2007, 09:27 AM   #5
dmckinstry
<div class='quotetop'>QUOTE(marussell @ Jan 19 2007, 05:15 AM) [snapback]377651[/snapback]</div>
Yep. Really helpful diagnostic. Isn't it? As if you didn't know that it didn't start.
Dave M.
dmckinstry is offline
Old 01-20-2007, 11:16 AM   #6
marussell
I had the same thought.
Old 01-24-2007, 06:33 PM   #7
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
There is a technical service bulletin for 2001-2003 Prius that seems related. TSB EG011-03. If your 02 Prius has less than 80k miles, the ECM will be replaced for free. If the problem is more severe it may require fuel ank assembly and /or fuel pump relay replacement. Those are only waranteed for 36k miles.
Plase let us know if this info helps resolve he problem, and any other details. Good Luck.
DAS
tochatihu is offline
Old 01-28-2007, 06:19 PM   #8
Jerdiest
<div class='quotetop'>QUOTE(marussell @ Jan 14 2007, 11:42 PM) [snapback]375717[/snapback]</div>
I also own a 2002, with about 60k miles. I have had several check engine light issues (some with the red triangle of death), but they had always resolved themselves before I could get to the dealer. no pattern with weather conditions or driving patterns and when the check engine lights came on. However. on Jan 1 this year, I started my car- check engine lights came on, including the red triangle of death. I drove, it seemed ok, then the accelerator seemed to stop working (floored it, still didn't get above 15 mph). then the car stalled. competely. I was able to get to the side of the road,restarted the car- it seemed fine now, except all the check engine lights were still on. then after after being parked for a few hours, drove for about 10 min, all the check engine lighs went off. took the car to the dealership 3 days later, computer code was "P3139"-general error, not very helpful. they did a 60k maintenence and didn't find anything else- some carbon buildup, and a bit out of alignment but that's it. anyone else with similar experiences? anyoneknow how carbon buildup would have caused my car to stall? any bets as to if/when my car will stall again?
I'm scared to drive my prius now!
Jerdiest is offline
Old 01-29-2007, 09:25 PM   #9
marussell
It's happened about 3 more times since my last post.
I now have about 83k on the car, can I still bring it in under warranty? It's in New York, don't we go by Cali emmisions warranty?
I purchased it about 1.5 yrs ago with 19k, I put a lot of miles on her!
Old 02-03-2007, 11:15 AM   #10
mjleamy
My 2003 is doing exactly this almost every morning (it is cold here, usually 35 degF or less). It starts great, runs 5-10 seconds or so, stalls. The triangle comes on. I have to wait a few seconds before I can restart it. Will Toyota replace the 2003 ecu for free? My car has 70k on it.
mjleamy is offline
Prius stalling Debora Gen II Prius Technical Discussion 22 08-13-2009 06:13 PM
2002 Prius engine stalling shortly after gas filled Cartrouble Gen II Prius Main Forum 4 06-16-2009 07:30 PM
Stalling engine on the 2002 Cartrouble Gen II Prius Main Forum 2 01-02-2007 11:27 AM
Stalling Sensation skg Gen II Prius Main Forum 13 09-22-2006 05:06 PM
recall for stalling minou9602 Knowledge Base Articles Discussion 7 03-19-2006 08:11 PM
