This is a discussion on motor oil on air filter gasket seal. Problems? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; While I was pouring motor oil into the Prius this weekend, I spilled a little on the top cover of ...
Old 01-15-2007, 05:47 PM   #1
hockeymulder
While I was pouring motor oil into the Prius this weekend, I spilled a little on the top cover of the air filter (I assume that plastic case with 4 or 5 cam buckles on the cover houses the air filter). I went to remove it in order to wipe it clean, and some oil got inside on the filter, mostly on the rubber gasket seal that surrounds it. Some also got on the inside top cover. I wiped it up as best I could, and used some rubbing alcohol to help clean it. I then let everything dry, but you could still see there was some oil left on there. Will this damage the engine in any way?
hockeymulder is offline
Old 01-15-2007, 07:55 PM   #2
jayman
Cross your fingers, no. Did any oil get into the throttle body itself?
jayman is offline
Old 01-15-2007, 08:00 PM   #3
hockeymulder
<div class='quotetop'>QUOTE(jayman @ Jan 15 2007, 07:55 PM) [snapback]376101[/snapback]</div>
My knowledge of engines is limited. I basically just do oil changes. I assume by throttle body, you mean the the "hole" that the air filter covers?
I don't think any oil got in there. If it did, would that just lead to some oil in the cylinders? Would that just lead to some smoky exhaust?
Thanks for all your help.
Old 01-15-2007, 08:33 PM   #4
jayman
<div class='quotetop'>QUOTE(hockeymulder @ Jan 15 2007, 08:00 PM) [snapback]376107[/snapback]</div>
I assume by throttle body, you mean the the "hole" that the air filter covers?[/b]
Yep, that's it
I don't think any oil got in there. If it did, would that just lead to some oil in the cylinders? Would that just lead to some smoky exhaust?[/b]
Actually, that can cause some issues with the Prius, not just smoky exhaust. Seems the way the PCV is designed, a certain amount gets drawn in anyway and can cause driveability issues. A lot of us are very careful to slowly add fresh oil when doing an oil change, and to never add past the Full dot.
Some of us even intentionally keep the oil level between the two dots to prevent problems. I tried to search for a link but the Search appears to be flaky again
jayman is offline
Old 01-15-2007, 08:47 PM   #5
hockeymulder
<div class='quotetop'>QUOTE(jayman @ Jan 15 2007, 08:33 PM) [snapback]376123[/snapback]</div>
Yep, that's it
I was very careful to only add 3.3 quarts. I'm about 1/8" to 3/16" below the full dot.
Looks like I should get out the Q-Tips and try to do a thorough cleaning tonight.
Oil Change Plug Gasket SureValla Gen II Prius Technical Discussion 13 11-17-2007 12:27 PM
missing drain plug gasket ACORNBLUES Gen II Prius Care, Maintenance and Troubleshooting 13 09-26-2007 06:09 PM
rear window seal townshop1 Gen II Prius Main Forum 2 05-30-2007 07:17 AM
Gasket for Oil drain plug dzitlow Gen II Prius Care, Maintenance and Troubleshooting 19 02-27-2005 01:49 PM
Oil Drain Plug Gasket berryman Gen II Prius Care, Maintenance and Troubleshooting 1 11-06-2004 06:26 PM
