| This is a discussion on Oil analysis report 2004 88K miles within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Here is my latest oil anylsis report.. this is my third one.. using mobile 1 oil So far.. wear is ... |
| Senior Member Join Date: Mar 2004 Location: NJ
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 3
Friends: 0 | Here is my latest oil anylsis report.. this is my third one.. using mobile 1 oil So far.. wear is just about nothing.. hope it continues |
Friends: 1 | Wow... looks great. I might extend my drain interval to 10k too. 5k is a waste for Mobil 1. Did u do the TBN test? |
Friends: 0 | <div class='quotetop'>QUOTE(ScottY @ Jan 18 2007, 12:26 PM) [snapback]377241[/snapback]</div> Quote:
Yes.. The TBN was 3.8.. oil should be good for another 3K.. Enjoy!! | |
Friends: 0 | Thanks for posting this. Could you fill me in on what year your prius is and which Mobil 1 oil you used for each of the 3 analyses on your Blackstone report? I know the Prius calls for 5W30, but some people use 0W30, 5W20, or 0W20, also there is the EP variety in the 5W30. Thanks, nice report! |
Friends: 0 | <div class='quotetop'>QUOTE(maineprius947 @ Jan 18 2007, 02:34 PM) [snapback]377374[/snapback]</div> Quote:
The last oil was 5W30 regular mobile one.. (Thery where out of the EP) I have a 2004 prius.. I will be trying either royal purple or red line oils for the next test.. just to see if there are any differences.. Scott | |
Friends: 0 | Thanks Scott. I guess I should have looked at your signature for the year of your Prius. Any guess as to what the difference between the first two analyses was as far as driving contitions etc, and do you remember the TBN for these first two analyses (I think the first is in the database already, but either you didn't post the second or I missed it.) Also how many months was on the oil for each of these and was there any makeup oil or filter change during the oci? Was anything added to the oil, did you change the oil or just sample at around 8K? With your permission I will add these to the oil analysis spreadsheet. Thanks Dennis
__________________ ![]() 83.7 mpg 629 mi best tank 51.4 MPG avg last 12 Tanks 4426 mi 53.8 MPG avg last 24 Tanks 9606 mi 57.8 MPG avg last 48 Tanks 21911 mi MPG data |
Friends: 0 | <div class='quotetop'>QUOTE(maineprius947 @ Jan 19 2007, 07:56 AM) [snapback]377648[/snapback]</div> Quote:
Lets see if I can answer all the questions. My driving conditions are the same for all the tests. I do mostly highway. about 90 to 95% The TB on the first I think was 2.8 and the second was 3.0. Both the first and the second.. I changed the oil at the time of the analysis. This last one.. I had used regular mobil one.. so I wanted to see how it was holding up... so I took it at 8K miles to see. I changed the oil yesterday.. at 10K miles.. I usually go about 3 months (which is about 10K for me) between changes. No makeup oil or filter change was done at anytime between oil changes. Nothing was added to the oil. again.. I just sampled at 8K miles and changed it at 10K Any other questions please let me know.. Nex sample should be around 110K miles... Scott
__________________ Scott 2010 Blue Ribbon Metallic #V Advanced Tech Package | |
Friends: 0 | Thanks Scott. The reason I asked about driving conditions was the change in Fe over your analyses. They are all excellent but some are better than others and I was wondering if one had more short trips or something. I would think with the kind of miles you rack up (40K per year) that you could extend your intervals to 15 or maybe 20K, especially with the EP and if you used a premium filter like Mobil 1 or the EAO from amsoil, also you could change the filter only at 7K or 10K. I think you might find that most of the wear metals accumulate over the early part of the oci, although in my case I got very low wear over the first 2400 miles and greater wear over the next 2500, but this may have simply been lab error. Keep your eye out for my UOAs as I plan to run my oil out to 15K and I don't put so many miles on my car (about 20K per year) which would be harder on the oil. Dennis |
| 10,000 miles report | Prius Jim of Oregon | Gen II Prius Fuel Economy | 2 | 07-02-2007 01:49 AM |
| Oil Analysis Report | Tadashi | Gen II Prius Care, Maintenance and Troubleshooting | 18 | 06-07-2007 09:25 AM |
| 12002 miles on Mobil 1 0w20, used oil analysis | dcoyne78 | Gen II Prius Technical Discussion | 14 | 05-24-2007 10:03 AM |
| My Used Oil Analysis Report | ScottY | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 03-17-2006 12:24 PM |
| Oil Analysis report. 2004 prius 47K miles | p626808 | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 01-20-2006 02:19 PM |
