This is a discussion on Editing phone book within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Does anyone know if there is a way to edit a phone number in the phone book? Thanks....
Editing phone book
Old 01-19-2007, 10:38 AM   #1
jkash
jkash's Avatar
Thanks.
jkash is offline
Old 01-19-2007, 11:26 AM   #2
Renocat
Renocat's Avatar
<div class='quotetop'>QUOTE(jkash @ Jan 19 2007, 10:38 AM) [snapback]377700[/snapback]</div>
Thanks.
I just edited my daughter's phone number because she got a new cell phone. I just pulled up the entry for her and cleared the phone number that was in there and put the new one in.
Renocat is offline
Old 01-19-2007, 04:53 PM   #3
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(jkash @ Jan 19 2007, 07:38 AM) [snapback]377700[/snapback]</div>
Does anyone know if there is a way to edit a phone number in the phone book?[/b]
There does not appear to be a way to do it on the 04 and 05 models. The only option I can access in the "Edit" mode is to erase a contact.
My phone allows me to upload either the entire phone book or one contact at a time. If you can do that, just delete an entry and replace it with a new one.
IsrAmeriPrius is offline
Old 01-19-2007, 04:57 PM   #4
jkash
jkash's Avatar
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 19 2007, 01:53 PM) [snapback]377966[/snapback]</div>
Thanks for that. I will try it after work today.
jkash is offline
Old 01-19-2007, 06:34 PM   #5
jrfaris
jrfaris's Avatar
jkash, if you do this, be sure you add to the phonebook rather than overwrite. As I recall, overwriting will erase the entire phonebook and leave you with just the entry you upload.
jrfaris is offline
Old 01-19-2007, 07:15 PM   #6
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
<div class='quotetop'>QUOTE(jrfaris @ Jan 19 2007, 03:34 PM) [snapback]378020[/snapback]</div>
Unless you're sending the entire phonebook again, which overwrites the whole thing.
aaf709 is offline
Old 01-19-2007, 08:24 PM   #7
jkash
jkash's Avatar
Next question, how do you find the "Edit" mode to erase the contact? I looked but can't find it.
Thanks.
jkash is offline
Old 01-19-2007, 10:03 PM   #8
IsrAmeriPrius
Progressive Member
<div class='quotetop'>QUOTE(jkash @ Jan 19 2007, 05:24 PM) [snapback]378067[/snapback]</div>
Thanks.
I wonder how I found it in the first place. It took me a while to figure it out again when I just went down to the garage to look it up.
Go to the main phone screen. Select "Settings." In the first settings screen, you will see "Phone Book" with a "Delete" button to its right. Press the "Delete" button and the phone book will appear with "Delete All" button at the top. Instead of touching that button, select an entry to delete.
Old 01-21-2007, 12:44 AM   #9
jkash
jkash's Avatar
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 19 2007, 07:03 PM) [snapback]378108[/snapback]</div>
Thanks for all the help. I was able to get a new phone number in the car, but chickened out on the "Delete All" button. It took me months to get the phone book and the car to sink, and I didn't want to lose the address book. I read more about my phone on Toyota's site and it appears it doesn't always work with the Pruis. Sending a contact from the phone doesn't usually work because the phone can't find the bluetooth device. Finally today, when I sent it, it picked up the handsfree so I could send the new contact. Next time I need to get a phone I think I find out which ones positively work with the car.
Jeff
Mr. Kash's Prius Page
jkash is offline
Old 01-21-2007, 12:59 PM   #10
IsrAmeriPrius
Progressive Member
<div class='quotetop'>QUOTE(jkash @ Jan 20 2007, 09:44 PM) [snapback]378563[/snapback]</div>
You were not supposed to hit the "Delete All" button. When you get to the point that you can see that button, the complete phone book will display. Just select the contact that you want to delete, do NOT touch the "Delete All" button.
How to transfer phone book from phone/pc to prius? rotearc Gen II Prius Audio and Electronics 9 02-04-2009 07:21 PM
How can I transfer my entire phone's phone book in one shot? Trojan Gen II Prius Care, Maintenance and Troubleshooting 11 03-20-2008 03:54 PM
How To Download Phone Book From Cell Phone? abcohen Gen II Prius Audio and Electronics 3 05-03-2007 09:38 PM
Can I menually enter phone numbers into the phone book ? lgeisz Gen II Prius Main Forum 2 05-01-2005 12:14 AM
How to transfer phone book from phone/pc to prius? E. Lau Gen II Prius Main Forum 0 12-31-1969 07:00 PM
