This is a discussion on is this normal? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I've had my 07 Prius for about a month. Within the last week ( and the onset of cold weather ...
is this normal?
Old 01-24-2007, 03:28 AM   #1
dzucc
dzucc's Avatar
I've had my 07 Prius for about a month. Within the last week ( and the onset of cold weather 20F. ) when I start out with the car not warmed up, when I accelerate moderately strong it sounds like a coventional car with a slipping clutch. Is this normal?
dzucc is offline
Old 01-24-2007, 05:39 AM   #2
Vincent
Don't Wait Until Tomorrow
Vincent's Avatar
Model: V
Package: Navigation
<div class='quotetop'>QUOTE(G-IVSP Pilot @ Jan 24 2007, 03:28 AM) [snapback]379949[/snapback]</div>
I've had my 07 Prius for about a month. Within the last week ( and the onset of cold weather 20F. ) when I start out with the car not warmed up, when I accelerate moderately strong it sounds like a coventional car with a slipping clutch. Is this normal? [/b]
What's the State of Charge (SOC) of your main battery? If it's low, you're accelerating with the cold engine only and that will make a loud slipping sound.
Vincent is offline
Old 01-24-2007, 07:43 AM   #3
Friends: 37
What do you mean...what sound do you hear? If high RPM it may just be related to the cold battery not being able to deliver as much energy as you're used to on warm mornings.
In any case, the ICE has a rev limiter and although it may sound fast/loud/scary it's not doing any harm. Just keep on driving.
efusco is online now
Old 01-24-2007, 09:36 AM   #4
As Evan suggests, it's probably just the engine taching up. It's a bit disconcerting on the Prius, since the engine speed has no direct correlation with car speed; that's where the "slipping clutch" sound comes from. The control unit on the Prius runs the engine at that best speed for the power it needs.
Old 01-24-2007, 11:26 AM   #5
JayGoldstein
<div class='quotetop'>QUOTE(qbee42 @ Jan 24 2007, 08:36 AM) [snapback]380008[/snapback]</div>
As Evan suggests, it's probably just the engine taching up. It's a bit disconcerting on the Prius, since the engine speed has no direct correlation with car speed; that's where the "slipping clutch" sound comes from. The control unit on the Prius runs the engine at that best speed for the power it needs. Tom[/b]
What Tom and Evan said.
This is my first winter with the Prius, so I'm still discovering how it behaves in cold temperatures. Last week, I took it on the highway when the temperature was -29C (-20F) [the wind chill was something like -38C (-36F)]. I could tell that the engine was running at much higher rpm than normal - it felt like driving a car with a manual transmission on the highway in 4th gear rather than 5th. This was confirmed by the MFD. At 105 km/h (65 mph) it showed around 8.2 l/100 km. In less extreme cold, I usually get around 6 l/100 km at the same (or even higher) speed.
Jay Goldstein
2006 Prius (Seaside Pearl)
Accessories: hood deflector, all-season mats, cargo mat, Prius Hoods centre console armrest cover
JayGoldstein is offline
Old 01-24-2007, 11:46 AM   #6
Ken Cooper
<div class='quotetop'>QUOTE(G-IVSP Pilot @ Jan 24 2007, 01:28 AM) [snapback]379949[/snapback]</div>
Yes. I experience this on cold mornings where I live, especially when going up a slight incline. And the slipping clutch sound is due to the continuous variable transmission and the manner in which it works with the engine (and generators/motor) Although the Prius CVT is very different from CVTs in other cars, all cars with CVT, including ours, will, under certain conditions, give you that slipping clutch sound.
Ken Cooper is offline
Old 01-24-2007, 09:58 PM   #7
JimN
P719 of ???
JimN's Avatar
Blocking your grill will help solve your winter problems. Look for the thread and choose the materials and installation style you like best. Probably the best return on investment of any mod. Also pump your tires to 42/40.
JimN is offline
Old 01-24-2007, 11:59 PM   #8
dzucc
dzucc's Avatar
<div class='quotetop'>QUOTE(Vincent @ Jan 24 2007, 04:39 AM) [snapback]379956[/snapback]</div>
SOC is 3-4 bars. But this mostly happens when the car has sat for an hour or so. It's finally cold here in Chicago!
<div class='quotetop'>QUOTE(G-IVSP Pilot @ Jan 24 2007, 10:54 PM) [snapback]380468[/snapback]</div>
To everyone who has answered my thread...Thanks!! I don't feel so alone in the Prius world anymore.
David
<div class='quotetop'>QUOTE(efusco @ Jan 24 2007, 06:43 AM) [snapback]379974[/snapback]</div>
Thanks Evan. I'll just keep on driving.
David
dzucc is offline
Old 01-25-2007, 01:40 AM   #9
dzucc
dzucc's Avatar
<div class='quotetop'>QUOTE(JimN @ Jan 24 2007, 08:58 PM) [snapback]380426[/snapback]</div>
Jim,
I checked out that thread and I will be going to home depot tomorrow.
David
dzucc is offline
Is 39.1 MPG Normal? Cultureshift Gen II Prius Fuel Economy 37 01-11-2009 12:36 PM
Is this normal? joecomposer Gen II Prius Care, Maintenance and Troubleshooting 5 07-08-2007 03:50 PM
is this normal? brokenheart Gen II Prius Main Forum 8 01-02-2007 11:36 AM
Is this normal momfortheenvironment Gen II Prius Main Forum 5 07-23-2006 01:40 PM
$3 per gallon going to be normal, and soon JackDodge Gen II Prius Main Forum 1 04-01-2006 11:32 AM
