This is a discussion on Gas Gauge Not Working within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I left a message with my local Toyota service department...no response yet. Here is the deal... Tank was 6/10 full ...
Old 02-05-2007, 08:24 PM   #1
Rick Grahn
Rick Grahn's Avatar
Question
Tank was 6/10 full (according to the dash light bar). Stopped, filled up tank (about 4.5 gallons) , drove away. The dash display (light bar) did not change. The MFD did not compeletely reset (showed MPG on bottom left, showed NOTHING on bottom right - where miles normally displays). I hit the MFD reset button and then the miles began showing up on the bottom right. Thinking I must have really screwed up, I stopped again and filled up again...it took about .25 of a gallon. Restarted. The dash light bar/gas gauge did not change, still showing 6 blips.
Could I have a bad sensor in the tank? Is there some other reset I need to try?
I have an '05 with 62,000 miles. I did by the 100,000 mile extended warrantee...hopefully this is covered.
Rick
'05 Salsa Red, >125,000 miles and going strong
Rick Grahn is offline
Old 02-06-2007, 09:51 AM   #2
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
did the MFD reset to 0 miles when it started working again?
galaxee is offline
Old 02-06-2007, 10:37 AM   #3
klevitsky
I believe the right side of the "Consumption" display will show nothing until you go 1 mile, since it does not display fractions of a mile (like the ODO does). The fact that the MFD "Miles" reset shows that the car knew that you put gas in. Let us know if the blips display changes.
klevitsky is offline
Old 02-08-2007, 06:08 AM   #4
Rick Grahn
Rick Grahn's Avatar
The MFD did not reset to zero. It had nothing (not even a zero) in that location). Since this started showing up, I have filled the tank 4 times (every time I come home...just in case). The MFD does not reset, the dash is still stuck on 6 bars/blips. I have an appointment tomorrow morning for the car. My guess: bad sensor in the tank.
Other thoughts.
Old 02-08-2007, 11:08 AM   #5
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
strange that the first time you put over 3 in there it didn't reset. did this perchance happen on a non-level surface?
anything less than 3 won't get you any credit with the car though. provided we've got time to discuss (i'll admit this is not the case of late) i'll talk to DH about that tonight.
galaxee is offline
Old 02-09-2007, 06:31 AM   #6
Rick Grahn
Rick Grahn's Avatar
<div class='quotetop'>QUOTE(galaxee @ Feb 8 2007, 11:08 AM) [snapback]386958[/snapback]</div>
Regarding the non-level surface, if you are referring to when I filled it up (even the first time), I was at gas station...the ground was by observation level.
Interesting though...yesterday things started working fine again. I thought maybe it was the bitter cold affecting it but the outside temperature was -2F when it began working again.
Could something have been caught/covering the sensor? Would extreme cold cause the bladder to constrict in such a way to impede the function of the sensor? Is the sensor in the tank electronic or are their physical motion properties to it (ie. float balls, etc.)?
Sorry for so many questions.
FYI, after it started working I added a fuel cleaner to a tank full (those little red bottles at the gas station you can add to a tank to "clean the fuel system and remove water from the tank." I sure hope that does not damage anything.
Thanks for replying. This is so odd I think people believe I am crazy.
Old 02-09-2007, 09:48 AM   #7
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
well the first thing a tech would have done is recal the inclination meter, which can get screwed up by filling on a non-level surface. the sensor is a magnetic float. if something caught it, you've got bigger problems than a nonfunctional gauge!
since it works now, just keep an eye on it.
galaxee is offline
Old 02-09-2007, 06:37 PM   #8
Rick Grahn
Rick Grahn's Avatar
<div class='quotetop'>QUOTE(galaxee @ Feb 9 2007, 09:48 AM) [snapback]387419[/snapback]</div>
Will do!
Old 02-09-2007, 11:14 PM   #9
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
and just a note, don't add any more of that tank cleaner to your gas. it's probably fine after the one but with regular use who knows what'll mess up that bladder. it is touchy, as we all know well.
galaxee is offline
Old 02-10-2007, 11:18 AM   #10
Rick Grahn
Rick Grahn's Avatar
<div class='quotetop'>QUOTE(galaxee @ Feb 9 2007, 11:14 PM) [snapback]387858[/snapback]</div>
Thank you. I appreciate the expert advice and will follow your recommendation(s).
Don't know what I did - SKS not working sumit Gen II Prius Main Forum 3 10-05-2007 02:57 PM
Homelink not working gottagetone Gen II Prius Technical Discussion 10 05-28-2007 11:18 PM
Is VSC working? Presto Gen II Prius Main Forum 23 02-07-2007 11:48 PM
Screen Not Working PetersPrius Gen II Prius Main Forum 12 10-13-2006 12:46 PM
New NAV Kit not working Ryomatic Gen II Prius Modifications 1 05-30-2006 03:05 AM
