| This is a discussion on Cold weather audio noise within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; With the harsh (-30C) winter weather, upon start up I get a earsplitting static noise through the audio speakers even ... |
Friends: 0 | With the harsh (-30C) winter weather, upon start up I get a earsplitting static noise through the audio speakers even though the audio is off. After several minutes of warm up it seems to go away. It is inconsistent but alarming when it happens as it seems to choose full volume as a default. Has anyone else experienced anything similar to this? |
Friends: 60 | Hi, welcome to PriusChat! I haven't experienced the problem you have, but I did have some weird clicks and pops from my lower front speakers. I think I tracked the problem down to a plug/socket in the driver's door. There is a multi-wire plug that goes into a socket mounted in the door about half way between where the control switches are located and where the release latch is, all under the plastic trim panels. Since it's new, take it back to the dealer and let them fix it, but this may be a clue as to where to look. What model audio system do you have? More details get better answers.
__________________ Bill Bill.Merchant@PortlandHSD.info 2007 NL 5 Silver Wraith • 2005 BC 6 Silver Cloud Portland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com > < Follow me on |
| Senior Member Join Date: Aug 2006 Location: Winnipeg, Manitoba, Canada
My Car: 2006 Prius Model: Package: B Thanks: 0
Friends: 0 | <div class='quotetop'>QUOTE(seduced by a prius @ Feb 5 2007, 08:16 PM) [snapback]385836[/snapback]</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(Bill Merchant @ Feb 6 2007, 02:12 AM) [snapback]385935[/snapback]</div> Quote:
Friends: 26 | sounds about right. glad ya got a quick solution. |
| Senior Member Join Date: Mar 2005
Friends: 0 | When it's *really* cold, I get some electronic sounds coming through my radio on my Classic Prius for the first few seconds after starting, and then it goes away.. My guess is that the noise suppression filters in the radio are probably slightly temperature senstive and when cold, they allow a bit of the engine/electronic noise to come through.. I actually noticed this on my old Corolla as well- when it was really cold, you'd hear some buzzes and clicks on the radio for a few minutes and then it would go away.. The cars have never shown any signs of malfunction so I've always just ignored the noises.. |
| Grinding noise in cold weather | marksniles | Gen II Prius Technical Discussion | 4 | 01-24-2008 12:09 AM |
| Cold weather cut out | kkayser | Gen II Prius Technical Discussion | 7 | 03-07-2007 10:00 PM |
| Cold Weather and CVT | Dcnight | Gen II Prius Main Forum | 23 | 01-22-2005 10:12 AM |
| Cold weather and the SOC | jfschultz | Gen II Prius Main Forum | 1 | 12-21-2004 09:37 PM |
| Cold weather audio noise | seduced by a prius | Gen II Prius Main Forum | 0 | 12-31-1969 07:00 PM |
< Follow me on
