This is a discussion on Tire Sensor broken? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I had a front tire replaced yesterday by 'Big-O' tires. I made a point to tell them the tires had ...
Tire Sensor broken?
Old 02-06-2007, 12:10 PM   #1
peep
I had a front tire replaced yesterday by 'Big-O' tires. I made a point to tell them the tires had pressure sensors in them that are expensive to replace, so make not to forget them.
I picked the car up and the sensor light was on, I informed the technician and he said drive it around awhile and it will reset.
It never did reset, I'm concerned the sensor is broken or missing. Are the sensors in the rim or are they in the valve on the tire? Can they be accidentally discarded when the old tire is removed?
peep is offline
Old 02-06-2007, 12:20 PM   #2
SomervillePrius
There is a button under the steering wheel that is for resetting the sensor. I think you need to hit that one after each tire change (not sure). Try hitting it and see what happens
SomervillePrius is offline
Old 02-06-2007, 12:55 PM   #3
Tom_06
Tom_06's Avatar
<div class='quotetop'>QUOTE(peep @ Feb 6 2007, 12:10 PM) [snapback]386101[/snapback]</div>
Check the pressure in that tire. It is probably way low. They may have lowered the pressure in all your tires, so check them all. After you have the pressures correct, then press the button under the steering wheel and hold until the dash warning lamp blinks three times. This sets the "setpoint".
The warning should not come on until one or more tires is about 25% below the "setpoint". That is why I suspect that the replaced tire is way low. Theoretically, you shouldn't HAVE to reset the system on a tire change if you set the tire pressures back to where it was in the old tires. I'd do it anyways.
If the light is still on with the corrected tire pressure and reset, they broke your sensor.
- Tom
Tom_06 is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Gen II Prius Care, Maintenance and Troubleshooting 32 04-08-2009 11:57 PM
Link to Glass Breakage Sensor Installation PDF Broken ttivol PriusChat Shop Forum 0 07-03-2007 12:34 PM
question about the tire pressure sensor hybrid_batmobile Gen II Prius Main Forum 2 12-27-2006 04:01 PM
Tire pressure sensor mssmith95 Gen II Prius Main Forum 2 06-04-2006 02:09 PM
Tire Pressure Monitor, where is the sensor? DocVijay Gen II Prius Main Forum 28 12-19-2005 06:08 PM
