| This is a discussion on anyone using Magnetic Oil pan plugs? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Anybody else using magnetic oil plugs on the oil pan?.. and if so, what are your findings when you change ... |
Friends: 4 | Anybody else using magnetic oil plugs on the oil pan?.. and if so, what are your findings when you change your oil? After I had already ordered mine.. I read some folks out here say its bunk and no need, but I have about 20K on both of my Prius's now and everytime I change the oil, there is a fine grey material on the magnet that only comes off with rubbing with my finger.. sometimes there is heavier matter around the edges I get with a rag... possibly just accumilations rather then bigger particles. It has the color of "gun grey" and is so fine, its almost like paint........ I figure if they are doing anything at all, its worth it.
__________________ Alan ________________________ 2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby" And my "other" cars...... 2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale" 2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip" 2006 Mods so far: 1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched! |
Friends: 14 | I have a magnet stuck to the bottom of the engine oil sump, and pull it off for oil draining. Thus unknown if it is actually collecting anything, but the UOA analyses have been clean. Also two stuck to the outside of the oil filter. Those are from a computer hard drive, which I 'disassembled in anger'. Pretty darn strong magnets... |
Friends: 4 | <div class='quotetop'>QUOTE(tochatihu @ Feb 9 2007, 10:57 AM) [snapback]387515[/snapback]</div> Quote:
Wow.. excellent idea!... I really like the bottom of the oil filter idea!.. I'm sure it works!..... Humm.. how I have to steal a magnet!.... | |
| Senior Member Join Date: Jun 2005
Friends: 1 | Do yourself a favor and take your significant other to lunch with the money saved. Life is so much better, in my case, with a happy wife and your Prius will be iron filing free too. -Paul R. Haller- |
Friends: 14 | Fair enough Paul, but those magnetic signs are not very strong. The magnets in hard drives will pinch you pretty bad if you put a finger between them. |
Friends: 4 | <div class='quotetop'>QUOTE(tochatihu @ Feb 10 2007, 10:52 AM) [snapback]388041[/snapback]</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(windstrings @ Feb 10 2007, 12:20 PM) [snapback]388054[/snapback]</div> Quote:
| Junior Member Join Date: Oct 2008 Location: Canada
My Car: 2007 Prius Model: Package: N/A Thanks: 0
Friends: 1 | I have an electronic shop near me that is selling some really strong earth magnets. They are size of a dime and sell about $0.50 each Do you think if I put around 6 of them around the oil filter that should do the job? I use regular 5W-30 oil and change the oil every 8000km or 5000miles. |
| magnetic, oil, pan, plugs |
| PRIUS MAGNETIC OIL DRAIN PLUGS | FloridaWen | Gen II Prius Care, Maintenance and Troubleshooting | 16 | 01-09-2008 05:02 PM |
| Is Magnetic Grey the same as Magnetic Grey metallic | Ghostrider | Gen II Prius Main Forum | 6 | 08-21-2006 05:02 PM |
| Spark plugs | FishHawk | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 07-22-2006 08:55 AM |
| So, Where do those plugs go? | GAGendel | Gen II Prius Main Forum | 6 | 05-10-2005 10:26 PM |
| Iridium plugs | mikepaul | Gen II Prius Modifications | 9 | 05-27-2004 08:19 PM |
