This is a discussion on Rear rattle FIXED within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; It took 35,000 miles and almost 2 years but I did it. Killed the bastard before it killed me. The ...
Rear rattle FIXED
Old 02-07-2007, 08:13 PM   #1
dgw
Post
It took 35,000 miles and almost 2 years but I did it. Killed the bastard before it killed me. The rattle in the back is history and I couldn't be happier if I had found a cure for cancer (well I did, in a way).
The short story is that it wasn't any of the usual suspects mentioned in this forum. Nope, not the heat shield, nor the trim around the rear windows, or the underfloor tray nor the floor above it, or the seats not latched, or the spare tire tools, or the prop-rod, or any of multitude of wiring harnesses under the trim, or the trimclips that broke off inside the hatch frame then fell to the bottom of the hatch, or the rear wiper motor or mount.
It was the hard rubber blocks that are mounted on either side of the hatch. Over time, the one mounted on the hatch contacts the one mounted in the rain channel when the car is driven on a less than perfect surface.
Here are the pictures. [attachmentid=6490][attachmentid=6491]
So I covered them first with bicycle helmet foam pads, which worked great but looked bodgey, then tried weatherproof foam strip, which looked better but didn't last very long. The good thing about the weather strip, though, was it showed the exact contact points (see 3rd photo), so my next step will be to get some adhesive backed felt on those areas.
[attachmentid=6494]
Next, on to the doors and maybe if I get brave and stupid, the dash.
Rear rattle FIXED-block_in_place.jpg   Rear rattle FIXED-2_blocks.jpg   Rear rattle FIXED-block_with_tape.jpg
dgw is offline
Old 02-09-2007, 03:23 PM   #2
molgrips
It is such sweet relief when you fix a rattle! The totally persistent one for me was the side of the dash (the bit that fits into the door) touching the end of the metal bar that supports the whole lot. Dismantling the dash wasn't too hard tbh.
Just the other day I also tracked down that rattle's louder successor - it was the rear seatbelt wobbling around and making its ball bearing rattle.
It's like having a new car!
molgrips is offline
Old 02-16-2007, 04:27 PM   #3
mini2prius
Thank you! Thank you! Thank you! It would appear I have (had!) the same problem, but was never able to isolate it.
1 down, 99 to go!
mini2prius is offline
Window Rattle - Fixed jcohan Gen II Prius Care, Maintenance and Troubleshooting 7 05-17-2009 02:50 AM
Bent rear axle... can't be fixed, only replaced. newkbomb Gen II Prius Technical Discussion 20 02-16-2007 10:39 PM
Fixed a rattle efusco Gen II Prius Care, Maintenance and Troubleshooting 3 11-16-2005 06:16 PM
Rear Rattle heimdm Gen II Prius Main Forum 6 10-21-2005 08:02 AM
Fixed a Dash Rattle efusco Gen II Prius Main Forum 17 12-19-2004 02:18 PM
