| This is a discussion on 99.9 liters per 100km anyone? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello all, I thought I saw someone post something similar to this at one time (but the numbers were maybe ... |
Friends: 0 | Hello all, I thought I saw someone post something similar to this at one time (but the numbers were maybe reversed for 99.9 mpg) but not this one yet. I've had this show up on the display a number of times just before the engine shuts off. I've had the car for a week now (new 2006 model) and this behaviour has been pretty consistent in the first 10 - 15 minutes of driving. And perhaps related is that when I am at a standstill with the ICE off I have displays of using the ICE (with a range of liters per KM) showing up as well. I'm sorry if this has been previously answered, but I could not find either of these despite looking. Thanks for any help on this, James |
| MPG Centurion Join Date: Sep 2005 Location: Houston, Texas
My Car: 2007 Prius Model: Package: #3 Thanks: 12
Friends: 20 | Not sure quite what your asking, but I'll give it a shot. Given: For non Metric models (ie only US I think), the display is in Miles-per-gallon (MPG). For the rest of the world the display is in L/100km. The two ratios are inverses of each other. High MPG = Low L/100km and Low MPG = High L/100km. This is because one is distance/fuel and the other is fuel/distance. So in the Prius, when either distance or fuel go to zero, wierd things happen. Fuel goes to zero when the gas-engine cuts off and you run off batteres. This gives you 99.9 MPG and (probably) 0L/100km. Distance goes to zero when the car gas-engine is running but the car is stopped. This would usually yield 0 MPG and (probably) 99.9L/100km. The final possibility is if both fuel and distance go to zero. This would be when your stopped but the gas-engine has cut out. In the US this displays 0 MPG. The rest of the world could conceivably show either 0L/100km or 99.9L/100km. 0/0 is basically undefined, or arguably zero. I think it technically depends on the whether the top zero or bottom zero converge on zero faster to truly determine if the ratio converges to zero or infinity (undefined). But none of this really matters since the ECU is discrete and will just have to decide what to do with 0/0. something like: if (fuel==0 && speed==0) { show99_9(locale); } But only Toyota really knows what they coded. Either answer is ok. Basically if the gas-engine isn't running or your stopped, fuel efficentcy isn't really an instantaneous value that can be calculated. |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | <div class='quotetop'>QUOTE(Great White North @ Feb 19 2007, 10:20 PM) [snapback]393147[/snapback]</div> Quote:
yeah it's typical to see the first 5 min bar shoot up to the max on the Consumption Screen. If the engine is warm, it'll be between 5 and 7.5L/100km. It should go down as the minutes pass unless you go uphill or are stuck in traffic for the following 5-10 mins (so total of 15 mins on the screen). Also, if you're stopped, then of course it'll show 99.9L/100km because it's idling. Then it'll shut off and read 0.0L/100km.
__________________ 2005 Tideland Pearl Premium Package 25/10/04 VVT-i Emblem, Sport Pedals, All-Weather Mats, Cargo Mat, EV Mod, JDM Prius Footwell Lighting, DICE iPod Kit ![]() 2008 Deep Black smart fortwo passion coupé - sold (6.1L/100km) 2010 Blue Ribbon Metallic Technology Package 29/08/09 All-Weather Mats, Homemade Console Pads, LED lighting *I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota.* | |
Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Feb 20 2007, 12:45 AM) [snapback]393179[/snapback]</div> Quote:
Dave M. | |
Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Feb 20 2007, 03:45 AM) [snapback]393179[/snapback]</div> Quote:
Saying all that, though, I'd just be happy to know that I'm not the only one experiencing these things, but don't really trust the dealer to tell me (after reading many posts about less than satisfactory encounters with dealers on this site). James | |
| Junior Member Join Date: Feb 2007
Friends: 0 | that's a typical result of a question that started out with improperly thought through units. if "consumption" is meant, the number in question will always be an amount over a distance. Or does anyone consume miles? :-) so quite naturally, 0 mpg makes no sense, whereas 0 l/100km does. |
Friends: 0 | <div class='quotetop'>QUOTE(Balt @ Feb 21 2007, 04:31 AM) [snapback]393846[/snapback]</div> Quote:
Dave M. | |
Friends: 23 | <div class='quotetop'>QUOTE(Great White North @ Feb 20 2007, 10:34 PM) [snapback]393788[/snapback]</div> Quote:
If the engine is running and there's no arrows, that's fine. Sometimes it'll run but won't charge the battery HOWEVER, if it's NOT running and there are arrows from the engine to the wheels, then I'd be worried. Again, give it 2 seconds for it to update. If there are arrows from the battery to the wheels even though you're stopped, that just means you're not pressing the brake pedal hard enough. I hope that helps. | |
Friends: 0 | <div class='quotetop'>QUOTE(Tideland Prius @ Feb 21 2007, 06:09 PM) [snapback]394219[/snapback]</div> Quote:
You've been a great help Tideland, thanks for everything so far. And thanks to all others for their input as well, it's all been very useful so far. Cheers, James | |
Friends: 23 | <div class='quotetop'>QUOTE(Great White North @ Feb 21 2007, 05:58 PM) [snapback]394305[/snapback]</div> Quote:
| Converting MPG into liters per 100 km | ckbarnard | Gen II Prius Fuel Economy | 31 | 07-13-2008 01:30 AM |
| Why mpg instead of gallons per mile or L/100km? | theorist | Gen II Prius Fuel Economy | 13 | 06-02-2006 04:44 PM |
| Volkswagen One-Liter per 100KM Car | GeeWiz | Prius and Hybrid News | 9 | 04-15-2005 01:49 PM |
| Converting MPG into liters per 100 km | ckbarnard | Gen II Prius Main Forum | 0 | 12-31-1969 07:00 PM |
