This is a discussion on confirmed overfill damage within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; galaxee you must be a mechanic or something like it. I'm impressed!...
LinkBack (48) Thread Tools
Old 07-20-2008, 01:28 AM   #41
kazots
LifesaBeach
kazots's Avatar
Default Re: confirmed overfill damage
kazots is offline
Old 07-20-2008, 02:11 AM   #42
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
husband is a former prius tech.
galaxee is offline
Old 10-29-2008, 09:59 AM   #43
jbumps wvu mntrs
PC Superfan
My Car: 2010 Prius On Order
After reading all five pages here I'm still left with one question. galaxee hinted at an answer on the first page but here goes anyway. Is an overfill from say a small lawn mower type gas can likely to cause damage along the lines of what is being discussed here? From what I've read here it's apparent that a high rate of flow/high pressure fill could cause this type of damage, but I'm still wondering about the gravity type fill. Inquiring minds have to know.
jbumps wvu mntrs is offline
Old 10-29-2008, 03:00 PM   #44
bazineta
bazineta's Avatar
I'm traveling in Oregon while reading this, and in Oregon, there is, by law, no self-serve gas; you legally aren't allowed to pump your own.
It would appear that the gas jockeys are instructed by management to eke the last drop possible out of a fillup, as despite numerous instructions to the contrary, they always top off the tank.
So, I'm wondering just how hard this type of damage is to accomplish, since it seems as if this state would be a hotbed of the problem if just overfilling would cause the problem.
bazineta is offline
Old 10-29-2008, 04:21 PM   #45
prius12306
Sally in Driftwood Pearl
prius12306's Avatar
NJ has the same law. I don't think you'll have an issue if they only top it off, what I've had happen though is that the pump stops prematurely and you really end up with less than a full tank. They have attempted to top off only to have it stop again. Even in NY where I pump my own, I find that I have to keep trying to get it to accept anywhere near the right amount of gas. So, I don't think you'll run into an issue.
prius12306 is offline
Old 10-30-2008, 01:51 PM   #46
PaulHS
Prius named PHriuS
PaulHS's Avatar
Toyota recommends NOT pumping low and slow. Apparently the protective valves in the fuel system cannot detect small pressure changes which can then allow overfilling. While I'm no expert, I believe that gravity fill may not be much different than pumping low and slow.
You may find the following document helpful.
PaulHS is offline
Old 11-03-2008, 07:04 PM   #47
Aaron
Aaron's Avatar
Package: #5 Touring
I've had two over-fills in my 2008 since I bought it in March. Both due to bad pumps at the station that didn't work properly (gas stations admitted it).
Question:
Can the charcoal canister be damaged without getting an error code on my ScangaugeII? No codes so far. I sure hope I didn't do any damage after gas was spilling out on the ground.
Aaron is offline
Old 11-14-2008, 12:49 AM   #48
Tata_pilote
The dealer just told my wife that she perhaps has a broken fuel filler neck on her '05 Prius, and they want about $800 to fix it. The service guy said she could drive it that way. Does that sound right, or are we looking at possible cannister flooding, pollution equipment getting flooded, etc? The mileage is normal, between 48 and 52 mpg, depending on cold and rainy conditions. I'm tending towards just leaving it as is and driving it.
Tata_pilote is offline
Old 11-14-2008, 07:56 PM   #49
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
catching up-
aaron: you will get a code if there was any damage. sounds like there is no need to worry about those incidents.
tata: perhaps? um. can they be sure before they replace it? what led to that diagnosis (or lack thereof) in the first place?
galaxee is offline
Old 11-14-2008, 11:06 PM   #50
Tata_pilote
Galaxee, I forgot to say the car was damaged once in that quarter where the filler is, a non-Toyota place fixed it (Russians here in Seattle area), so perhaps it didn't get fixed if indeed the filler neck was broken. Haven't had any strange codes or gas smells or funny performance.
confirmed, damage, overfill
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/29844-confirmed-overfill-damage.html
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 09-27-2008 09:53 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 07-24-2008 01:29 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 07-21-2008 04:51 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 06-26-2008 12:05 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 06-25-2008 03:40 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 05-22-2008 08:56 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 05-13-2008 01:55 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 05-12-2008 04:47 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 05-09-2008 08:16 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 05-02-2008 03:01 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-30-2008 10:54 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-27-2008 03:01 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-26-2008 07:34 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-23-2008 09:39 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-21-2008 11:13 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-21-2008 03:09 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-20-2008 10:19 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-19-2008 12:00 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-11-2008 01:20 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-10-2008 07:44 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-08-2008 02:40 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-07-2008 10:43 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-07-2008 02:40 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-07-2008 11:16 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 04-03-2008 09:46 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-30-2008 07:34 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-30-2008 04:55 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-28-2008 04:01 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-27-2008 09:54 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-27-2008 01:05 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-26-2008 11:59 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-23-2008 11:43 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-22-2008 04:34 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-21-2008 09:26 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-15-2008 11:21 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-09-2008 01:22 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-03-2008 11:44 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 03-01-2008 10:05 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-29-2008 05:57 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-26-2008 06:48 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-11-2008 06:12 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-10-2008 12:49 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-09-2008 11:28 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-09-2008 11:53 AM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-08-2008 01:17 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-08-2008 12:42 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-07-2008 03:22 PM
PriusOnline.com • View topic - Topping off the fuel tank This thread Refback 02-07-2008 07:53 AM
New Prius confirmed in allocation... but which year? pkowalski Gen II Prius Main Forum 0 08-02-2007 12:27 PM
Confirmed: Plug-in Prius jayselle Gen II Prius Main Forum 14 07-26-2007 04:00 PM
Confirmed: $500 Costco disc. on '06 in N Ca Jack 06 Gen II Prius Main Forum 17 11-27-2005 03:57 PM
Confirmed my Order Wynder Gen II Prius Main Forum 9 11-22-2005 11:05 AM
2006 Toyota Prius Changes - semi-confirmed Danny Prius and Hybrid News 27 08-13-2005 02:06 AM
