| This is a discussion on Headlights losing their beam within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My 2005 Prius is running great, but recently, at night, the beam of light from the headlights has grown shorter. ... |
| Junior Member Join Date: Jul 2006
Friends: 0 | My 2005 Prius is running great, but recently, at night, the beam of light from the headlights has grown shorter. I can drive with the high beams on, and those look like the low beams used to. Once I parked it, got back in, and the lights came on full force. Then the next day they were short again. I'm getting ready to take it in for service, and wondered if anyone had an inkling what it could be, so I can point the dealer to the right solution. It's making it really hard to drive at night. Thanks, Bonnie |
Friends: 26 | do you have the HID lights or regular halogens? |
| P719 of ??? Join Date: Nov 2006 Location: South Jersey
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 0
Friends: 2 | <div class='quotetop'>QUOTE(galaxee @ Apr 24 2007, 01:18 PM) [snapback]429133[/snapback]</div> Quote:
Friends: 26 | you're right, jim, but it sounds quite a bit like the HID leveler problem. if we can rule that out we're looking more at the housing, which contains the refractor. |
Friends: 0 | My stupid boyfriend says the headlights are HID. I found a post about the auto-leveling headlights feature, but can't find it now. The car is at the dealer today, and they don't seem to know anything about it, and we wanted to fax it to them. Thanks! Bonnie |
Friends: 37 | there are issues with the rear HID headlight level sensor (it's attached to the axle at the driver's side rear) where it becomes corroded and doesn't function properly. If under warranty or extended warranty it should be replaced free (after deductible). If not it's pretty pricy...$325 or so. Or you can remove it and clean the contacts, seal the unit with silicon and it should work ok for you. Here's an informative post with attached files from the repair manual that explains things and how they should be tested if you need to fax it to them. But if you need to fax it to them you probably need to find a different service dept. http://www.priusonline.com/viewtopic.php?t...p;highlight=hid
| Losing tire pressure ?? | wtfjr | Gen II Prius Main Forum | 16 | 02-23-2008 12:32 PM |
| Losing diversity = losing life | Mirza | Environmental Discussion | 5 | 02-21-2007 03:19 PM |
| High beam / Low beam switch | qbee42 | Gen II Prius Main Forum | 11 | 04-09-2006 08:22 PM |
| We are LOSING our MOON!!! | Mystery Squid | Fred's House of Pancakes | 19 | 01-05-2006 02:35 PM |
| Losing power from MG2??? | snarf44 | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 08-11-2005 08:06 PM |
