| This is a discussion on Help with my driver side outside mirror! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; This question relates to the driver side outer mirror. Recently I performed an audio upgrade, and when I removed the ... |
| Senior Member Join Date: Jan 2007 Location: White Mtns New Hampshire
Friends: 0 | This question relates to the driver side outer mirror. Recently I performed an audio upgrade, and when I removed the tweeter housing, the top metal clip remained in the square housing that it connects to. Well it eventually fell into that housing and the only way I could retrieve the clip, was to remove the driver side outer mirror. After doing so, I managed to retrieve the clip for the tweeter housing. Anyway, when I was tightening the nuts back up onto the bolts that protrude from the mirror, the top bolt broke off. I must have tightened too tight, but the bolt came right off with the nut still connected to it. To diagram the 3 bolts protruding from the mirror, it looks similar to a triangle like this: 0* 0 0 The top one with the astrisk is the bolt that broke off in the nut. I was able to retrieve the broken bolt and nut, and when i look into the top hole where the bolt came from there is still a piece of bolt in the screw hole. The mirror seems tight to the door, it has no movement really, but I am concerned. I don't like leaving it attached with only 2 bolts/nuts. Is there anyway that you know of that I can replace that bolt so that the upper portion of the mirror housing is really secure?
__________________ Mods thus far: Tinted Back and Rear Windows 35%. (guaranteed for life, professionally installed) BT Plate Venuture Shield Clear Bra (guranteed for life, professionally installed) Replaced OEM tires with Nokian WR's 44/42 inflation Replaced Mats with all weather Prius Mats VAIS TECH SLI Install for Ipod Harness Fix Engine Block Heater (done professionally by Wayne aka FireEngineer) Replaced stock speakers with Infinity Kappa 60.7cs front 62.7i rear; installed dynamat all doors My avg MPG = 54 2007 Silver Metallic aka "Silver Bullet" took delivery Dec 29, 2006 "NOBODY'S OFF THE HOOK" - Rufus Wainwright from the album "Release the Stars" ![]() |
| Senior Member Join Date: Jan 2005 Location: Durham, NH
Friends: 0 | Ouch! Have you found a solution yet? If not, here's a couple: 1) See if you can buy just that bolt from Toyota. 2) Email Steve at Autobeyours.com They specialize in Prius and he can sell you one cheap. He also sends stuff out very quickly. 3) Of the two remaingin bolts, unscrew the the bolt down low and closest to the rear of the car. Then, re-attach it to the top position. I would think that out of the three bolts, the most important bolt is the top one, then the one on the lower front (I'm thinking about pressure put on the mirror from wind... You can remove the bolts from the plastic as they take the same 10mm socket, albeit a deeper one. Best to use a socket as the bolt head doesn't look like it would take mush to strip it with an adjustable wrench or a 10mm wrench. I'm surprised that you broke the bolt. I would have thought the platic would have given way first.... The good news is that having taken the mirror off, you're well on your way to tackling the signal mirror mods! |
Friends: 0 | <div class='quotetop'>QUOTE(bobc @ May 1 2007, 06:12 PM) [snapback]433534[/snapback]</div> Quote:
Friends: 0 | Glad that I could help ( i was also feeling kinda guilty that I had told you how easy it was to tear the doors down and then stuff ended up breaking....)! Yes, the bolt does just screw into/out of the plastic piece. While it doesn't show up well in the above photo, the bolt doesn't have nice, flat edges for a wrench to get a positive grip on. I would think it would strip easy. While it doesn't have to be that tight, see if you can borrow a deep 10mm socket to put these on. Cheers, |
Friends: 0 | <div class='quotetop'>QUOTE(bobc @ May 2 2007, 12:05 PM) [snapback]433989[/snapback]</div> Quote:
Thanks for your tip about Steve. I called him today after his prompt responses to my emails and I spoke with him over the phone. He is going to get me some bolts and I asked if he could dig up some metal tweeter clips. Such a nice gentleman, as yourself. Thank you for your great advice! | |
Friends: 0 | <div class='quotetop'>QUOTE(priusFTW @ May 2 2007, 03:16 PM) [snapback]434153[/snapback]</div> Quote:
| Newbie with a broken driver-side mirror | unknownone | Gen II Prius Main Forum | 3 | 07-26-2007 05:16 PM |
| Driver side mirror...vandalised :( | AAWADKE | Gen II Prius Main Forum | 5 | 11-08-2006 01:04 AM |
| Is your mirror up-side-down? | brasche | Gen II Prius Main Forum | 11 | 03-16-2006 09:59 PM |
| Driver's side mirror whistle | r1perkins | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 03-09-2006 01:20 PM |
| passenger side headlight higher than driver side | alsgameroom | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 10-21-2005 08:09 PM |
