| This is a discussion on Can anyone identify this part on my Prius? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Just noticed this today looking at my new 2007 Prius. It's dead center if you're looking at the car head-on. ... |
Friends: 0 | Just noticed this today looking at my new 2007 Prius. It's dead center if you're looking at the car head-on. It caught my attention because it's the lowest part of the car. In other words, if anything were to scrape against the underbody, it'd be the first to get hit. I'm not sure what it is or if it's supposed to be that low. It's also off at a slight angle (although I can't tell if that's by design or not). I did get some mild bodywork done the first month I had the car (needed my bumpers redone), but I don't think they banged it. Any ideas what this thing is? And if it's supposed to be that low? |
| Senior Member Join Date: Mar 2004 Location: USA
Friends: 0 | That would be a motor mount. Leave it connected. Nate |
Friends: 0 | <div class='quotetop'>QUOTE(naterprius @ May 2 2007, 07:17 PM) [snapback]434329[/snapback]</div> Quote:
| Senior Member Join Date: Feb 2006
Friends: 0 | Just from the pictures it appears that the 2007 does not have the "lip" that makes adding a nose mask so difficult. |
My Car: 2006 Prius Model: Package: #6 Thanks: 18
Friends: 12 | Quote:
Hey wait! The wheels and tires are lower! | |
Friends: 4 | <div class='quotetop'>QUOTE(darelldd @ May 2 2007, 10:24 PM) [snapback]434486[/snapback]</div> Quote:
Friends: 0 | The service manual refers to that as an "engine moving control rod". It's a link that prevents the engine from twisting too far in its mounts from the countertorque of the wheels; the rubber bushings still allow it a little motion regardless for vibration damping. . If you put the car in Park but without the emergency brake applied and open the hood, then push and pull the car back and forth to rock it against the parking pawl, you can see the whole engine and transaxle move forward and back a little at each extreme. The link restricts that motion. . _H* |
| smug doug Join Date: Mar 2007 Location: Chicago
Friends: 1 | <div class='quotetop'>QUOTE(darelldd @ May 2 2007, 10:24 PM) [snapback]434486[/snapback]</div> Quote:
:P | |
Friends: 0 | <div class='quotetop'>QUOTE(darelldd @ May 2 2007, 11:24 PM) [snapback]434486[/snapback]</div> Quote:
| Identify this Modification | mdrudeen | Gen II Prius Main Forum | 25 | 09-21-2007 09:59 PM |
| If you're not part of the solution, then you're a part of the problem! | Mirza | Environmental Discussion | 29 | 02-20-2007 01:02 AM |
| anything to identify a touring edition? | YoDaddyAlex | Gen II Prius Main Forum | 11 | 01-19-2007 03:12 PM |
| identify part | bugmenot | Gen II Prius Main Forum | 43 | 01-07-2007 06:26 PM |
