This is a discussion on Pimp My Cat within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My cat, Jingles, has been getting fur on the front seat of my car (he rides with me wherever I ...
Pimp My Cat
Old 05-04-2007, 12:54 AM   #1
ESanders2
ESanders2's Avatar
My cat, Jingles, has been getting fur on the front seat of my car (he rides with me wherever I go). I'm wondering if I can throw some sort of covering or, maybe, a hair repelling material on the front seat. I know there are a lot of cat fans on PriusChat and was hoping you all would have some advice. Maybe I should have gone with a more pimped out Prius with leather and then I wouldn't have this problem with the hair. Jingles seems to be shedding a lot more now that he hit the 40 lbs. marker last month.
Everything in My Life I Owe to My Cat "Jingles"
ESanders2 is offline
Old 05-04-2007, 09:54 AM   #2
daniel
Cat Lovers Against the Bomb
daniel's Avatar
Cat hair forms a covering over upholstery, protecting the fabric from wear and tear. It's also an insulating layer, which is warm in winter and cool in summer.
Regular brushing of the cat will slightly reduce the amount of random shedding, but it's still a good idea to apply the cat hair you obtain in this manner to upholstery, as a natural proctecant, and to carpets, in increase the R factor of the floor of your home.
daniel is offline
Old 05-04-2007, 10:25 AM   #3
Ichabod
Artist In Residence
Ichabod's Avatar
Friends: 7
Very funny Daniel. It does seem like the only approach to dealing with cat hair is to rationalize it and somehow accept it though. My solution to the problem though is to be allergic to cats. That way I keep all cats away from my upholstry!
SandMan, your avatar is the best thing I've seen on PriusChat today! 40 lbs.??!? Cats can weigh that much?
Ichabod is offline
Old 05-04-2007, 10:56 AM   #4
Chuck.
Honda Enzyte Driver
Chuck.'s Avatar
My Car: Other Hybrid
40 pounds for a housecat is not good! I just lost a cat that weight 30 - probably from fatty liver disease. What I should have done was to gradually get her weight down.
About cats and cars - mine were fine until they were older than a few months. After that they became terrified - seeing reckless drivers does not help. I was a softie, but they go in the carrier, because it's not safe having a cat either under the pedals or between me and the steering wheel.
Chuck. is offline
Old 05-04-2007, 10:58 AM   #5
dmckinstry
<div class='quotetop'>QUOTE(Ichabod @ May 4 2007, 07:25 AM) [snapback]435402[/snapback]</div>
I don't "own" a (actually own is the wrong word, since cats own you) a cat that heavy, but I'm sure I've seen them that heavy. No offense SandMan, but I'll bet if you were to shave him, he'd almost look like a bulldog.
Dave M.
dmckinstry is offline
Old 05-04-2007, 11:42 AM   #6
mini2prius
<div class='quotetop'>QUOTE(dmckinstry @ May 4 2007, 10:58 AM) [snapback]435426[/snapback]</div>
Dave M.
Dogs have "owners." Cats have "staff."
mini2prius is offline
Old 05-04-2007, 12:15 PM   #7
MarinJohn
MarinJohn's Avatar
Friends: 7
I see an easy solution for the OP problem. Just make the lower glove box into a Komfy kitty bed. On the occasions when you have passengers, simply close the glove box (leave cat at home for that trip) and contain the hairball.
MarinJohn is offline
Old 05-04-2007, 05:22 PM   #8
Charles Suitt
Charles Suitt's Avatar
A 40# cat would not fit in the lower glove compartment... That would be a VERY VERY tight squeeze.
Charles Suitt is offline
Old 05-04-2007, 05:46 PM   #9
faith2walk
Lovin' my little BlackWidow
faith2walk's Avatar
<div class='quotetop'>QUOTE(Charles Suitt @ May 4 2007, 05:22 PM) [snapback]435672[/snapback]</div>
A 40# cat would not fit in the lower glove compartment... That would be a VERY VERY tight squeeze. [/b]
You might have to try a 2-1 conversion (using both glove compartments), but even that would be tight. Probably loose enough for the cat to catch it's breath and then howl loud enough to make you shorten your trip or let it out!!!
faith2walk is offline
Old 05-04-2007, 06:58 PM   #10
Sufferin' Prius Envy
Platinum Member
Lint rollers.
Works for me.
Works for others too.
http://www1.epinions.com/3M_Lint_Roller_Ho...isplay_~reviews
Pimp My Ride hycamguy07 Fred's House of Pancakes 1 07-23-2007 02:41 PM
Governator Promotes Biodiesel on "Pimp My Ride" Arroyo Prius and Hybrid News 15 04-17-2007 09:56 AM
Pimp My Cat SandMan Gen II Prius Main Forum 0 12-31-1969 07:00 PM
