TOYO oil filter : larger 90915 - YZZF1 : any users ?
| | #31 | |
Friends: 59 | Quote:
| | #32 |
| Member Join Date: Mar 2008 Location: North Carolina
My Car: 2006 Prius Model: Package: #1 Thanks: 26
Friends: 0 | I just changed the oil on my 06 yesterday at 100K miles and I was thinking of switching over the the longer 90915-YZZF1 filter next time in order to make it easier to fit my channel lock pliers around the filter for removal. As it is now with the standard filter I can barely get the pliers on the filter body to twist it loose. (I know I could buy a 65mm 14 flute oil filter wrench for about $5, but money is tight). For those who have switched over to the longer filter, have you found that the longer length of it makes it easier to remove the filter? Thanks! |
| | #33 |
| Senior Member Join Date: Sep 2009 Location: Australia
My Car: 2005 Prius Model: N/A Package: No Package Thanks: 94
Friends: 2 | Does anyone know the difference between 90915-YZZF2 and 90915-YZZE1. I just got a filter from my local Toyota dealer a few weeks ago and it's 90915-YZZE1. It's not the longer size, I believe it's the same size as the standard 90915-YZZF2 that others have mentioned here. Does anyone know why Toyota are using a different part number here. Is this an Australia thing? |
| | #34 | |
| Junior Member Join Date: Feb 2011 Location: Michigan
My Car: 2008 Prius Model: Five Package: #6 Thanks: 0
FYI, my toyota dealer uses this filter on my prius. | |
| filter, larger, oil, toyo, users, yzzf1 |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/32514-toyo-oil-filter-larger-90915-yzzf1-any-users.html | ||||
| Info.com - toyo oil filters - www.Info.com | This thread | Refback | 11-29-2011 12:45 PM | |
| blekko | best oil filter for 2007 prius | This thread | Refback | 01-31-2011 04:34 PM | |
| Opinion on Toyo Tourevo Tires? Les Schwab? | NoMoShocks | Gen II Prius Main Forum | 2 | 08-23-2009 12:50 AM |
| Will using the 90915-YZZF1 Toyota oil filter void my warranty? | Bob64 | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 05-25-2007 08:45 PM |
| Toyo Guard Sealant Cleaner - has anyone used yet ?? | wtfjr | Gen II Prius Main Forum | 3 | 10-05-2006 07:00 PM |
| Toyo 800 Ultra's | Weinerneck | Gen II Prius Modifications | 1 | 08-24-2006 11:08 PM |
| Toyo Guard Sealant | A. B. Hair | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 08-07-2006 02:21 PM |
